SLICES-RI FIT - Future Internet Testbeds R2lab
Shell tools in the gateway
Logging in the gateway
Once you have obtained a slice account on R2LAB (faraday), you can reach the R2lab gateway using ssh
$ ssh your_slicename@faraday.inria.fr
If by any chance your public key is not at its standard location, then place -i option in the command line and inform the path of it.
Listing commands
From your bash account on the gateway, you have a few very simple but handy tools at your disposal for the early steps of your experiment, like seeing the nodes status, turning them on or off, and loading images.
help
Addressing
From the gateway, you can use the following hostnames to refer to nodes
  • fit08 : refers to the control wired interface on node 8; the control interface is configured in all our images to start up automatically at boot-time so the nodes can be reached.
  • data08 : refers to the data wired interface; this one is not automatically turned on, it is up to you to use it or not, you can use DHCP for that purpose.
  • reboot08 : refers to the ethernet interface of the CMC device on the node, that allows for remote management of the motherboard (i.e. turning nodes on and off)
Here's an example of how these names resolve. Beware that the IP address of the reboot interface might occassionnally not be directly bound to the node index.
your_slicename@faraday:~$ host fit08
fit08 has address 192.168.3.8
your_slicename@faraday:~$ host data08
data08 has address 192.168.2.8
your_slicename@faraday:~$ host reboot08
reboot08 has address 192.168.1.8
Checking leases
In case you're unsure about the current status of reservation, you can list reserved timeslots - known as leases - with
rleases
or check that you currently hold a reservation with
rleases --check
This is a poorman's tool, as of course the scheduler will give you that same information in a much nicer way.
Note also that this is in fact equivalent to
rhubarbe leases
rhubarbe (see it on github) being the set of tools that help us run the testbed. Indeed many of the convenience functions starting with r in fact are aliases to a rhubarbe subcommand.
Switch off the testbed when you're done
One very frequently used command, that requires that you have a valid lease - or at least that no lease is currently active - is the one that turns off the nodes when you are done:
all-off
which is an alias for either
rhubarbe bye
or simply
rbye
Please try to make sure to use it, especially when you have many nodes running.
In the next tab we will see how we can focus on a specific set of nodes, and easily control them.<
Monitor what you're doing
Be aware that you can have a global and live view of the testbed status right in the r2lab website. This link works for all visitors, and if you are logged in you can also see this page that will also show you the state of the reservation system.
Selecting nodes
Most of the time, you will want to manage a selected subset of nodes. There's a simple mechanism in place so you don't need to specify your nodes for each and every command, by defining the environment variable NODES. For this the nodes command is your friend
To select nodes, use the nodes command. To select nodes 1 2 4 5 33 and 37 you could do this (~ stands for negation)
nodes 1-5 33,37 ~3
To select all nodes, you could do
all-nodes
To remove all nodes between 3 and 35 from your selection; same with nodes-add for adding nodes
nodes-sub 3-35
To see your selection, just run
nodes
Finally the commands nodes-save and nodes restore let you name selections, and then reinstate them
nodes-save run1
nodes-restore run1
Are these nodes on or off
st
By default - i.e. with no argument - this command and most of the ones we will show here operate on your nodes selection, but you can always specify another set of nodes to operate on, regardless of the overall selection
So this will give you the status of nodes 1 2 and 3, no matter what you have selected
st 1-3
Managing nodes (turning them on or off, or rebooting)
To turn on your selected nodes selection just do
on
Or again, if you want to turn on node 3 only, just do
on 3
Turning them off is of course just
off
You can trigger a reset (reboot) on a node - provided it is already on, with
reset
To see the list of nodes that are ON
show-nodes-on
You can select all the nodes currently ON with
focus-nodes-on -a
To see the linux version running in the nodes (this is less sophisticated than what the livetable would provide)
releases
Loading images
The tool for loading images is called rload. It is in fact a shortcut for rhubarbe load, like most commands described here
rhubarbe --help
See the source code for rhubarbe for more details.
Back to image loading, you will first want to know which images are available:
rimages
Assuming you want to load the latest fedora image, you would just do
rload -i fedora
that would act on all your selected nodes (or as always add a list of nodes to the command)
rload -i fedora 1-10
image loading has a fancier mode that can come in handy for troubleshooting: the --curses mode - -c in short - gives you a live progressbar for each node. Note however that the curses mode is not suitable for scripting, as it will wait for a keystroke before exiting.
Waiting for nodes
You can wait for all the selected nodes to be ssh-ready by running
rwait
This command, like all the rhubarbe-related commands, has a default timeout, that you can change with (-t is the shortcut)
rwait --timeout 30
ssh-ing into nodes
Once you have loaded an image, you can enter all nodes by just doing
ssh root@fit25
or just, if you're really lazy
s1 25
note this shortcut used to be called ss, but ss is also the name of a standard linux tool for inspecting sockets; the name s1 stands for ssh into the 1st selected node
You can run a command on all selected nodes with
map ip addr show
this time of course, you cannot specify another set of nodes than the selection.
Saving images
You have the ablility to save the image - this now of course applies only to one node at a time. To save node 25
rsave 25 -o my-image-name
Your slice can then later on re-use this image using e.g. a simple
rload -i my-image-name 12-15
The image file ends up in your slice's home directory, under a temporary name starting in saving__; if you need to publish these into the common repository /var/lib/rhubarbe-images, get in touch with the admins, who can grant you the right to use rhubarbe-share (not documented here)
Phones
For now we have two commercial phones available right in the room; each phone can be controlled through a dedicated MAC box, called macphone1 and macphone2.
As far as shell commands are concerned, since that is the focus of this tutorial, be aware that you can reach e.g. the second macphone from faraday by doing just
macphone2
and from then, as usual
help
to get a reminder.
Please refer to this page for more details on this offering, and how to manage these phones e.g. through a VNC session.
