SLICES-RI FIT - Future Internet Testbeds R2lab
How to use the latest oaici docker images
Author: Raphael Defosseux raphael.defosseux@openairinterface.org
Summary
This tuto explains how to use latest oaici docker images, which are:
  1. oai-ci-cd-u18-epc-latest for the EPC
  2. oai-ci-u18-lowlatency-enb-ue-docker-latest for the eNB
You have the choice to either deploy them automatically, through the deploy.py nepi-ng script or to launch them manually, step-by-step:
  1. If you choose to deploy them automatically, just run on your local machine: (replace slicename with your slice name)
    oaici-docker $ deploy.py -s slicename
    We assume that you have installed nepi-ng on your host before, see nepi-ng tuto and that you booked a R2lab timeslot with your slice, see R2lab reservation.
    The above script takes about 8mn to complete. It has several options, use deploy.py --help to see all of them. Once it finishes, you can directly go to Step 4 "Logs & Testing".
  2. In the following you will learn how to manually launch, step-by-step, the latest oaici docker images on two R2lab nodes. In this example, fit17 is used for the EPC and fit23 for the eNB.
What you need...
You will need 3 terminals:
  • one for the EPC
  • one for the eNB
  • one for the MACPHONE2
You can have more if you deploy also a UE, another eNB...
In the following, please replace your_slicename with your slice name :-)
EPC terminal
Load the EPC image
ssh your_slicename@faraday.inria.fr
$ rload -i oai-ci-cd-u18-epc-latest 17
Found binary frisbeed as /usr/sbin/frisbeed
Found binary nc as /usr/bin/nc
10:29:25 - +000s: Selection: fit17
10:29:25 - +000s: Loading image saving__fit17__2021-02-11@15-13__oai-ci-cd-u18-epc-docker-2021-02-11.ndz
10:29:25 - +000s: AUTH: checking for a valid lease
10:29:25 - +000s: AUTH: access granted
10:32:08 - +163s: stopped <frisbeed@234.5.6.1:10001 on saving__fit17__2021-02-11@15-13__oai-ci-cd-u18-epc-docker-2021-02-11.ndz at 500 Mibps>
$ rwait 17
<Node fit17>:ssh OK
Do some network manipulations for containers to talk to each other
$ ssh oaici@fit17              # password is `linux`
oaici@fit17$ sudo sysctl net.ipv4.conf.all.forwarding=1
net.ipv4.conf.all.forwarding = 1
oaici@fit17$ sudo iptables -P FORWARD ACCEPT
oaici@fit17$ sudo ip route add 192.168.61.0/26 via 192.168.3.23 dev control
Deploy the EPC
CAUTION: This SHALL be done in 2 steps!
$ ssh oaici@fit17
oaici@fit17$ cd openair-epc-fed/docker-compose/inria-oai-mme/
oaici@fit17$ docker-compose config --service
cassandra
db_init
oai_hss
oai_mme
oai_spgwc
oai_spgwu
trf_gen
oaici@fit17$ docker-compose up -d db_init
Creating network "prod-oai-private-net" with the default driver
Creating network "prod-oai-public-net" with the default driver
Creating prod-cassandra ... done
Creating prod-db-init   ... done
Wait a bit (around 30-50 seconds)
oaici@fit17$ docker logs prod-db-init
Connection error: ('Unable to connect to any servers', {'prod-cassandra': error(111, "Tried connecting to [('192.168.68.2', 9042)]. Last error: Connection refused")})
OK
You can remove the prod-db-init container. It's useless (this step is optional)
oaici@fit17:~/openair-epc-fed/docker-compose/inria-oai-mme$ docker rm prod-db-init
prod-db-init
CAUTION: if you do NOT have the "OK" message as above, no need to go further
oaici@fit17$ docker-compose up -d oai_spgwu trf_gen
Building with native build. Learn about native build in Compose here: https://docs.docker.com/go/compose-native-build/
prod-cassandra is up-to-date
Creating prod-trf-gen ... done
Creating prod-oai-hss ... done
Creating prod-oai-mme ... done
Creating prod-oai-spgwc ... done
Creating prod-oai-spgwu-tiny ... done
After a while (again 20-30 seconds), the EPC shall be ready
oaici@fit17:~/openair-epc-fed/docker-compose/inria-oai-mme$ docker-compose ps -a
       Name                      Command                  State                            Ports
prod-cassandra        docker-entrypoint.sh cassa ...   Up (healthy)   7000/tcp, 7001/tcp, 7199/tcp, 9042/tcp, 9160/tcp
prod-oai-hss          /openair-hss/bin/entrypoin ...   Up (healthy)   5868/tcp, 9042/tcp, 9080/tcp, 9081/tcp
prod-oai-mme          /openair-mme/bin/entrypoin ...   Up (healthy)   2123/udp, 3870/tcp, 5870/tcp
prod-oai-spgwc        /openair-spgwc/bin/entrypo ...   Up (healthy)   2123/udp, 8805/udp
prod-oai-spgwu-tiny   /openair-spgwu-tiny/bin/en ...   Up (healthy)   2152/udp, 8805/udp
prod-trf-gen          /bin/bash -c ip route add  ...   Up (healthy)
Then you can follow live the action on MME:
oaici@fit17$ docker logs prod-oai-mme --follow
eNB terminal
Load the eNB image
$ rload -i oai-ci-u18-lowlatency-enb-ue-docker-latest 23
10:29:48 - +000s: Selection: fit23
10:29:48 - +000s: Loading image saving__fit23__2021-02-11@15-17__docker-oai-u18-lowlatency-enb-ue.ndz
10:29:48 - +000s: AUTH: checking for a valid lease
10:29:48 - +000s: AUTH: access granted
10:33:02 - +193s: fit23 reboot = Sending message 'reset' to CMC reboot23
10:33:04 - +195s: stopped <frisbeed@234.5.6.2:10002 on saving__fit23__2021-02-11@15-17__docker-oai-u18-lowlatency-enb-ue.ndz at 500 Mibps>
$ $ rwait 23
<Node fit23>:ssh OK
$ uon 23
reboot23:ok
$ uon 23
reboot23:ok
ssh inria_oaici@faraday.inria.fr
$ ssh oaici@fit23   # once again password is `linux`
oaici@fit23$ sudo sysctl net.ipv4.conf.all.forwarding=1
oaici@fit23$ sudo iptables -P FORWARD ACCEPT
oaici@fit23$ sudo ip route add 192.168.61.192/26 via 192.168.3.17 dev control
Deploy the eNB
$ ssh oaici@fit23
oaici@fit23$ cd ~/openairinterface5g/ci-scripts/yaml_files/inria_enb_mono_fdd
enb_mono_fdd
oaici@fit23$ docker-compose up -d enb_mono_fdd
Creating prod-enb-mono-fdd ... done
oaici@fit23$ docker logs prod-enb-mono-fdd --follow
[INFO] Images destination: /usr/share/uhd/images
[INFO] No inventory file found at /usr/share/uhd/images/inventory.json. Creating an empty one.
[INFO] Downloading b2xx_b200_fpga_default-gfde2a94e.zip, total size: 478.32 kB
[INFO] Downloading b2xx_b200mini_fpga_default-gfde2a94e.zip, total size: 463.516 kB
[INFO] Downloading b2xx_b210_fpga_default-gfde2a94e.zip, total size: 878.644 kB
[INFO] Downloading b2xx_b205mini_fpga_default-gfde2a94e.zip, total size: 522.303 kB
[INFO] Downloading b2xx_common_fw_default-g2bdad498.zip, total size: 161.492 kB
[INFO] Images download complete.
== Starting eNB soft modem
Additional option(s): --RUs.[0].max_rxgain 115 --RUs.[0].max_pdschReferenceSignalPower -27 --eNBs.[0].component_carriers.[0].pucch_p0_Nominal -96
/opt/oai-enb/bin/lte-softmodem.Rel15 -O /opt/oai-enb/etc/enb.conf --RUs.[0].max_rxgain 115 --RUs.[0].max_pdschReferenceSignalPower -27 --eNBs.[0].component_carriers.[0].pucch_p0_Nominal -96
[LOADER] library libNB_IoT.so is not loaded: libNB_IoT.so: cannot open shared object file: No such file or directory
[CONFIG] get parameters from libconfig /opt/oai-enb/etc/enb.conf , debug flags: 0x00000000
[CONFIG] function config_libconfig_init returned 0
[CONFIG] config module libconfig loaded
[LIBCONFIG] config: 1/1 parameters successfully set, (1 to default value)
# /dev/cpu_dma_latency set to 0us
[SCTP]   sctp_bindx SCTP_BINDX_ADD_ADDR socket bound to : 192.168.61.30
[SCTP]   Converted ipv4 address 192.168.61.195 to network type
[SCTP]   connectx assoc_id  1 in progress..., used 1 addresses
[SCTP]   Inserted new descriptor for sd 95 in list, nb elements 1, assoc_id 1
[SCTP]   Found data for descriptor 95
[SCTP]   Received notification for sd 95, type 32769
[SCTP]   Client association changed: 0
[SCTP]   ----------------------
[SCTP]   Peer addresses:
[SCTP]       - [192.168.61.195]
[SCTP]   SCTP Status:
[SCTP]   assoc id .....: 1
[SCTP]   state ........: 4
[SCTP]   instrms ......: 2
[SCTP]   outstrms .....: 2
[SCTP]   fragmentation : 1452
[SCTP]   pending data .: 0
[SCTP]   unack data ...: 0
[SCTP]   rwnd .........: 106496
[SCTP]   peer info     :
[SCTP]       state ....: 2
[SCTP]       cwnd .....: 4380
[SCTP]       srtt .....: 0
[SCTP]       rto ......: 3000
[SCTP]       mtu ......: 1500
[SCTP]   Comm up notified for sd 95, assigned assoc_id 1
[S1AP]   3584 -> 00e000
[SCTP]   Successfully sent 54 bytes on stream 0 for assoc_id 1
[SCTP]   [1][95] Msg of length 27 received from port 36412, on stream 0, PPID 18
[S1AP]   servedGUMMEIs.list.count 1
[S1AP]   servedPLMNs.list.count 1
[S1AP]   S1AP_FIND_PROTOCOLIE_BY_ID: /oai-ran/openair3/S1AP/s1ap_eNB_handlers.c 380: ie is NULL
[ENB_APP]   [eNB 0] Received S1AP_REGISTER_ENB_CNF: associated MME 1
At that point, the eNB SHOULD be connected with the MME:
000382 00110:853675 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0039    ======================================= STATISTICS ============================================
000383 00110:853696 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0042                   |   Current Status| Added since last display|  Removed since last display |
000384 00110:853703 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0048    Connected eNBs |          0      |              0              |             0               |
000385 00110:853710 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0054    Attached UEs   |          0      |              0              |             0               |
000386 00110:853715 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0060    Connected UEs  |          0      |              0              |             0               |
000387 00110:853721 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0066    Default Bearers|          0      |              0              |             0               |
000388 00110:853728 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0072    S1-U Bearers   |          0      |              0              |             0               |
000389 00110:853734 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0075    ======================================= STATISTICS ============================================
000390 00112:416004 7F81A17FA700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0469    Client association changed: 0
000391 00112:416027 7F81A17FA700 DEBUG SCTP   enair-mme/src/sctp/sctp_common.c:0101    ----------------------
000392 00112:416032 7F81A17FA700 DEBUG SCTP   enair-mme/src/sctp/sctp_common.c:0102    SCTP Status:
000393 00112:416035 7F81A17FA700 DEBUG SCTP   enair-mme/src/sctp/sctp_common.c:0103    assoc id .....: 1
000394 00112:416038 7F81A17FA700 DEBUG SCTP   enair-mme/src/sctp/sctp_common.c:0104    state ........: 4
000395 00112:416041 7F81A17FA700 DEBUG SCTP   enair-mme/src/sctp/sctp_common.c:0105    instrms ......: 2
000396 00112:416044 7F81A17FA700 DEBUG SCTP   enair-mme/src/sctp/sctp_common.c:0106    outstrms .....: 2
000397 00112:416047 7F81A17FA700 DEBUG SCTP   enair-mme/src/sctp/sctp_common.c:0108    fragmentation : 1452
000398 00112:416050 7F81A17FA700 DEBUG SCTP   enair-mme/src/sctp/sctp_common.c:0109    pending data .: 0
000399 00112:416053 7F81A17FA700 DEBUG SCTP   enair-mme/src/sctp/sctp_common.c:0110    unack data ...: 0
000400 00112:416056 7F81A17FA700 DEBUG SCTP   enair-mme/src/sctp/sctp_common.c:0111    rwnd .........: 106496
000401 00112:416059 7F81A17FA700 DEBUG SCTP   enair-mme/src/sctp/sctp_common.c:0112    peer info     :
000402 00112:416061 7F81A17FA700 DEBUG SCTP   enair-mme/src/sctp/sctp_common.c:0114        state ....: 2
000403 00112:416064 7F81A17FA700 DEBUG SCTP   enair-mme/src/sctp/sctp_common.c:0116        cwnd .....: 4380
000404 00112:416067 7F81A17FA700 DEBUG SCTP   enair-mme/src/sctp/sctp_common.c:0118        srtt .....: 0
000405 00112:416070 7F81A17FA700 DEBUG SCTP   enair-mme/src/sctp/sctp_common.c:0120        rto ......: 3000
000406 00112:416073 7F81A17FA700 DEBUG SCTP   enair-mme/src/sctp/sctp_common.c:0122        mtu ......: 1500
000407 00112:416076 7F81A17FA700 DEBUG SCTP   enair-mme/src/sctp/sctp_common.c:0123    ----------------------
000408 00112:416079 7F81A17FA700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0479    New connection
000409 00112:416093 7F81A17FA700 DEBUG SCTP   enair-mme/src/sctp/sctp_common.c:0205    ----------------------
000410 00112:416104 7F81A17FA700 DEBUG SCTP   enair-mme/src/sctp/sctp_common.c:0206    Local addresses:
000411 00112:416110 7F81A17FA700 DEBUG SCTP   enair-mme/src/sctp/sctp_common.c:0217        - [192.168.61.195]
000412 00112:416113 7F81A17FA700 DEBUG SCTP   enair-mme/src/sctp/sctp_common.c:0234    ----------------------
000413 00112:416119 7F81A17FA700 DEBUG SCTP   enair-mme/src/sctp/sctp_common.c:0151    ----------------------
000414 00112:416122 7F81A17FA700 DEBUG SCTP   enair-mme/src/sctp/sctp_common.c:0152    Peer addresses:
000415 00112:416126 7F81A17FA700 DEBUG SCTP   enair-mme/src/sctp/sctp_common.c:0163        - [192.168.3.23]
000416 00112:416128 7F81A17FA700 DEBUG SCTP   enair-mme/src/sctp/sctp_common.c:0178    ----------------------
000417 00112:416141 7F81A17FA700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0554    SCTP RETURNING!!
000418 00112:416196 7F81F9FFB700 DEBUG S1AP   mme/src/s1ap/s1ap_mme_handlers.c:2826    Create eNB context for assoc_id: 1
000419 00112:417350 7F81A17FA700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0547    [1][48] Msg of length 54 received from port 36412, on stream 0, PPID 18
000420 00112:417383 7F81A17FA700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0554    SCTP RETURNING!!
000422 00112:420248 7F81F9FFB700 DEBUG S1AP   mme/src/s1ap/s1ap_mme_handlers.c:0361    S1-Setup-Request macroENB_ID.size 3 (should be 20)
000421 00112:420243 7F81F9FFB700 DEBUG S1AP   mme/src/s1ap/s1ap_mme_handlers.c:0321    New s1 setup request incoming from macro eNB id: 00e00
000423 00112:420263 7F81F9FFB700 DEBUG S1AP   mme/src/s1ap/s1ap_mme_handlers.c:0423    Adding eNB to the list of served eNBs
000424 00112:420266 7F81F9FFB700 DEBUG S1AP   mme/src/s1ap/s1ap_mme_handlers.c:0438    Adding eNB id 3584 to the list of served eNBs
000425 00112:420776 7F81FB7FE700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0283    [48][1] Sending buffer 0x7f8164009f90 of 27 bytes on stream 0 with ppid 18
000426 00112:420815 7F81FB7FE700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0296    Successfully sent 27 bytes on stream 0
000427 00120:853608 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0039    ======================================= STATISTICS ============================================
000428 00120:853628 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0042                   |   Current Status| Added since last display|  Removed since last display |
000429 00120:853633 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0048    Connected eNBs |          1      |              1              |             0               |
000430 00120:853638 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0054    Attached UEs   |          0      |              0              |             0               |
000431 00120:853643 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0060    Connected UEs  |          0      |              0              |             0               |
000432 00120:853647 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0066    Default Bearers|          0      |              0              |             0               |
000433 00120:853652 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0072    S1-U Bearers   |          0      |              0              |             0               |
000434 00120:853656 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0075    ======================================= STATISTICS ============================================
Let the eNB radio start:
[LIBCONFIG] MMEs.[0]: 1/1 parameters successfully set, (1 to default value)
[MCE_APP]   Creating MCE_APP eNB Task
[TMR]   Created Posix thread TASK_MCE_APP
[LIBCONFIG] MCEs.[0]: 1/1 parameters successfully set, (1 to default value)
[ENB_APP]   TYPE <CTRL-C> TO TERMINATE
[ENB_APP]   [MCE 0] MCE_app_register via M3AP for instance 0
[PHY]   RU 0 rf device ready
sleep...
sleep...
sleep...
sleep...
sleep...
sleep...
sleep...
sleep...
sleep...
[RLC]   rlc_tick: discontinuity (expected 0.1, got 0.4)
[MAC]   SCHED_MODE = 0
[PHY]   prach_I0 = 0.1 dB
[PHY]   max_I0 30 (rb 2), min_I0 27 (rb 0), avg I0 27
[PHY]   max_I0 30 (rb 2), min_I0 24 (rb 19), avg I0 27
[PHY]   max_I0 30 (rb 2), min_I0 24 (rb 6), avg I0 27
[PHY]   max_I0 31 (rb 2), min_I0 24 (rb 4), avg I0 27
[PHY]   max_I0 30 (rb 2), min_I0 24 (rb 1), avg I0 27
[PHY]   max_I0 30 (rb 2), min_I0 24 (rb 4), avg I0 27
Logs & Testing
On the MACPHONE2 terminal
$  macphone2
macphone2:~ tester$ phone-status
phone is turned OFF
macphone2:~ tester$ phone-on
Turning ON phone : turning off airplane mode
Broadcasting: Intent { act=android.intent.action.AIRPLANE_MODE (has extras) }
Broadcast completed: result=0
the UE shall connect quickly:
MME logs
000491 00199:803592 7F81A17FA700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0547    [1][48] Msg of length 152 received from port 36412, on stream 1, PPID 18
000492 00199:803678 7F81A17FA700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0554    SCTP RETURNING!!
000493 00199:803783 7F81F9FFB700 INFO  S1AP   c/s1ap/s1ap_mme_nas_procedures.c:0093    Received S1AP INITIAL_UE_MESSAGE eNB_UE_S1AP_ID 06692d
000494 00199:803831 7F81F9FFB700 INFO  S1AP   c/s1ap/s1ap_mme_nas_procedures.c:0112    New Initial UE message received with eNB UE S1AP ID: 06692d
000495 00199:803843 7F81F9FFB700 DEBUG S1AP   c/s1ap/s1ap_mme_nas_procedures.c:0116    S1AP_FIND_PROTOCOLIE_BY_ID: /openair-mme/src/s1ap/s1ap_mme_nas_procedures.c 116: Optional ie is NULL
000496 00199:804042 7F81F9FFB700 DEBUG S1AP   c/s1ap/s1ap_mme_nas_procedures.c:0194    S1AP_FIND_PROTOCOLIE_BY_ID: /openair-mme/src/s1ap/s1ap_mme_nas_procedures.c 194: Optional ie is NULL
000497 00199:804058 7F81F9FFB700 DEBUG S1AP   c/s1ap/s1ap_mme_nas_procedures.c:0203    S1AP_FIND_PROTOCOLIE_BY_ID: /openair-mme/src/s1ap/s1ap_mme_nas_procedures.c 203: Optional ie is NULL
000498 00199:804069 7F81F9FFB700 DEBUG S1AP   c/s1ap/s1ap_mme_itti_messaging.c:0132    S1AP:Initial UE Message- Size 93:
000499 00199:804127 7F81F9704700 TRACE MME-AP mme/src/mme_app/mme_app_bearer.c:0508    Entering mme_app_handle_initial_ue_message()
000500 00199:804157 7F81F9704700 DEBUG MME-AP mme/src/mme_app/mme_app_bearer.c:0515    Received MME_APP_INITIAL_UE_MESSAGE from S1AP
000501 00199:804171 7F81F9704700 DEBUG MME-AP mme/src/mme_app/mme_app_bearer.c:0771    MME_APP_INITIAL_UE_MESSAGE from S1AP,without S-TMSI.
000502 00199:804183 7F81F9704700 DEBUG MME-AP mme/src/mme_app/mme_app_bearer.c:0789    UE context doesn't exist -> create one
000503 00199:809811 7F81F9704700 TRACE MME-AP me/src/mme_app/mme_app_context.c:0136    Entering get_new_ue_context()
000504 00199:809827 7F81F9704700 INFO  MME-AP me/src/mme_app/mme_app_context.c:0162    Clearing received current ue_context 0x5570b59e3858.
000505 00199:809830 7F81F9704700 TRACE MME-AP me/src/mme_app/mme_app_context.c:4034    Entering clear_ue_context()
000506 00199:809833 7F81F9704700 INFO  MME-AP me/src/mme_app/mme_app_context.c:4114    Clearing UE context of UE ffffffff.
000507 00199:809835 7F81F9704700 INFO  MME-AP me/src/mme_app/mme_app_context.c:4126    Successfully cleared UE context for UE ffffffff.
000508 00199:809837 7F81F9704700 TRACE MME-AP me/src/mme_app/mme_app_context.c:4127    Leaving clear_ue_context()
000509 00199:809839 7F81F9704700 DEBUG MME-AP me/src/mme_app/mme_app_context.c:0175    MME_APP_INITIAL_UE_MESSAGE. Allocated new MME UE context and new mme_ue_s1ap_id 1.
000510 00199:809841 7F81F9704700 TRACE MME-AP me/src/mme_app/mme_app_context.c:0650    Entering mme_insert_ue_context()
000511 00199:809844 7F81F9704700 DEBUG MME-AP me/src/mme_app/mme_app_context.c:0677    The received enb_ue_s1ap_id_key is invalid b59e3858. Skipping.
000512 00199:809848 7F81F9704700 TRACE MME-AP me/src/mme_app/mme_app_context.c:0800    Leaving mme_insert_ue_context() (rc=0)
000513 00199:809850 7F81F9704700 TRACE MME-AP me/src/mme_app/mme_app_context.c:0179    Leaving get_new_ue_context() (rc=93942571743320)
000514 00199:809852 7F81F9704700 DEBUG MME-AP mme/src/mme_app/mme_app_bearer.c:0811    Created new MME UE context enb_ue_s1ap_id 06692d
000515 00199:809855 7F81F9704700 TRACE MME-AP me/src/mme_app/mme_app_context.c:2153    Entering mme_ue_context_update_ue_sig_connection_state()
000516 00199:809857 7F81F9704700 DEBUG MME-AP me/src/mme_app/mme_app_context.c:2209    MME_APP: UE Connection State changed to CONNECTED.enb_ue_s1ap_id = 420141, mme_ue_s1ap_id = 1
000517 00199:809860 7F81F9704700 TRACE MME-AP me/src/mme_app/mme_app_context.c:0325    Entering mme_ue_context_update_coll_keys()
000518 00199:809862 7F81F9704700 TRACE MME-AP me/src/mme_app/mme_app_context.c:0334    Update ue context.enb_ue_s1ap_id 06692d ue context.mme_ue_s1ap_id 1 ue context.IMSI 0 ue context.GUTI 000.000|0000|00|00000000
000519 00199:809864 7F81F9704700 TRACE MME-AP me/src/mme_app/mme_app_context.c:0342    Update ue context 0x5570b59e3858 enb_ue_s1ap_id 06692d mme_ue_s1ap_id 1 IMSI 0 GUTI 000.000|0000|00|00000000
000520 00199:809868 7F81F9704700 TRACE MME-AP me/src/mme_app/mme_app_context.c:0605    Leaving mme_ue_context_update_coll_keys()
000521 00199:809870 7F81F9704700 TRACE MME-AP me_app/mme_app_session_context.c:0267    Entering get_new_session_pool()
000522 00199:809873 7F81F9704700 INFO  MME-AP me_app/mme_app_session_context.c:0288    Clearing received current sp 0x5570b5af3868.
000523 00199:809875 7F81F9704700 TRACE MME-AP me_app/mme_app_session_context.c:0850    Entering clear_session_pool()
000524 00199:809877 7F81F9704700 INFO  MME-AP me_app/mme_app_session_context.c:0856    Clearing UE session pool of UE ffffffff.
000525 00199:809879 7F81F9704700 TRACE MME-AP me_app/mme_app_session_context.c:0899    Clearing bearer context with ebi 5 (0x5570b5af3894) for UE ffffffff.
000526 00199:809882 7F81F9704700 TRACE MME-AP me_app/mme_app_session_context.c:0899    Clearing bearer context with ebi 6 (0x5570b5af393b) for UE ffffffff.
000527 00199:809884 7F81F9704700 TRACE MME-AP me_app/mme_app_session_context.c:0899    Clearing bearer context with ebi 7 (0x5570b5af39e2) for UE ffffffff.
000528 00199:809886 7F81F9704700 TRACE MME-AP me_app/mme_app_session_context.c:0899    Clearing bearer context with ebi 8 (0x5570b5af3a89) for UE ffffffff.
000529 00199:809888 7F81F9704700 TRACE MME-AP me_app/mme_app_session_context.c:0899    Clearing bearer context with ebi 9 (0x5570b5af3b30) for UE ffffffff.
000530 00199:809890 7F81F9704700 TRACE MME-AP me_app/mme_app_session_context.c:0899    Clearing bearer context with ebi 10 (0x5570b5af3bd7) for UE ffffffff.
000531 00199:809892 7F81F9704700 TRACE MME-AP me_app/mme_app_session_context.c:0899    Clearing bearer context with ebi 11 (0x5570b5af3c7e) for UE ffffffff.
000532 00199:809894 7F81F9704700 TRACE MME-AP me_app/mme_app_session_context.c:0899    Clearing bearer context with ebi 12 (0x5570b5af3d25) for UE ffffffff.
000533 00199:809896 7F81F9704700 TRACE MME-AP me_app/mme_app_session_context.c:0899    Clearing bearer context with ebi 13 (0x5570b5af3dcc) for UE ffffffff.
000534 00199:809898 7F81F9704700 TRACE MME-AP me_app/mme_app_session_context.c:0899    Clearing bearer context with ebi 14 (0x5570b5af3e73) for UE ffffffff.
000535 00199:809899 7F81F9704700 TRACE MME-AP me_app/mme_app_session_context.c:0899    Clearing bearer context with ebi 15 (0x5570b5af3f1a) for UE ffffffff.
000536 00199:809901 7F81F9704700 INFO  MME-AP me_app/mme_app_session_context.c:0924    Successfully cleared UE session pool of UE ffffffff.
000537 00199:809903 7F81F9704700 TRACE MME-AP me_app/mme_app_session_context.c:0925    Leaving clear_session_pool()
000538 00199:809905 7F81F9704700 TRACE MME-AP me_app/mme_app_session_context.c:0157    Entering mme_insert_ue_session_pool()
000539 00199:809908 7F81F9704700 TRACE MME-AP me_app/mme_app_session_context.c:0212    Leaving mme_insert_ue_session_pool() (rc=0)
000540 00199:809910 7F81F9704700 TRACE MME-AP me_app/mme_app_session_context.c:0297    Leaving get_new_session_pool() (rc=93942572857448)
000541 00199:809912 7F81F9704700 TRACE MME-AP me_app/mme_app_session_context.c:0071    Entering mme_ue_session_pool_update_coll_keys()
000542 00199:809914 7F81F9704700 TRACE MME-AP me_app/mme_app_session_context.c:0077    Update ue_session_pool.mme_ue_s1ap_id 1 teid 0x0.
000543 00199:809916 7F81F9704700 TRACE MME-AP me_app/mme_app_session_context.c:0131    Leaving mme_ue_session_pool_update_coll_keys()
000544 00199:809919 7F81F9704700 TRACE MME-AP mme_app/mme_app_itti_messaging.c:0976    Entering notify_s1ap_new_ue_mme_s1ap_id_association()
000545 00199:809930 7F81F9704700 DEBUG MME-AP mme_app/mme_app_itti_messaging.c:0990     Sent MME_APP_S1AP_MME_UE_ID_NOTIFICATION to S1AP for UE Id 1 and enbUeS1apId 420141
000546 00199:809933 7F81F9704700 TRACE MME-AP mme_app/mme_app_itti_messaging.c:0991    Leaving notify_s1ap_new_ue_mme_s1ap_id_association()
000547 00199:809943 7F81F9704700 TRACE MME-AP mme/src/mme_app/mme_app_bearer.c:0899    Leaving mme_app_handle_initial_ue_message()
000548 00199:809947 7F81F9FFB700 DEBUG S1AP   /openair-mme/src/s1ap/s1ap_mme.c:0718    Associated  sctp_assoc_id 1, enb_ue_s1ap_id 06692d, mme_ue_s1ap_id 1:HASH_TABLE_OK
000549 00199:809984 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0094    Entering nas_proc_establish_ind()
000550 00199:809994 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
000551 00199:810462 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0190    Entering emm_as_send()
000552 00199:810470 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0197    EMMAS-SAP - Received primitive EMMAS_ESTABLISH_REQ (205)
000553 00199:810474 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0697    Entering _emm_as_establish_req()
000554 00199:810477 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0706    EMMAS-SAP - Received AS connection establish request.
000555 00199:810481 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context (nil)
000556 00199:810487 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0360    Entering nas_message_decode()
000557 00199:810489 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:0374    hex stream Incoming NAS message:  17 38 4d 7d 73 02 07 41 02 0b f6 02 f8 59 00 04 01 00 00 00 03 05 f0 70 c0 40 10 00 27 02 2d d0 11 d1 27 20 80 80 21 10 01 00 00 10 81 06 00 00 00 00 83 06 00 00 00 00 00 0d 00 00 0a 00 00 05 00 00 10 00 52 02 f8 59 00 01 5c 0a 00 31 03 e5 e0 34 90 11 03 57 58 a6 5d 01 00 e0 c1
000558 00199:810524 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0694    Entering nas_message_header_decode()
000559 00199:810528 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0751    Leaving nas_message_header_decode() (rc=6)
000560 00199:810532 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:0383    Header seq no of uplink message 2:
000561 00199:810535 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:0386    nas_message_header_decode returned size 6
000562 00199:810539 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0827    Entering _nas_message_protected_decode()
000563 00199:810542 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1049    Entering _nas_message_decrypt()
000564 00199:810550 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:1066    No decryption of message length 87 according to security header type 0x01
000565 00199:810554 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1069    Leaving _nas_message_decrypt() (rc=7)
000566 00199:810557 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0776    Entering _nas_message_plain_decode()
000567 00199:810561 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0101    Entering emm_msg_decode()
000568 00199:810564 7F820083C700 DEBUG NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0121    EMM-MSG   - Message Type 0x41
000569 00199:810568 7F820083C700 TRACE NAS-EM /src/nas/emm/msg/AttachRequest.c:0036    Entering decode_attach_request()
000570 00199:810576 7F820083C700 TRACE NAS-EM /src/nas/ies/EpsMobileIdentity.c:0124    Entering decode_guti_eps_mobile_identity()
000571 00199:810587 7F820083C700 TRACE NAS-EM /src/nas/ies/EpsMobileIdentity.c:0162    Leaving decode_guti_eps_mobile_identity() (rc=11)
000572 00199:810591 7F820083C700 TRACE NAS-EM rc/nas/ies/UeNetworkCapability.c:0044    decode_ue_network_capability len = 5
000573 00199:810594 7F820083C700 TRACE NAS-EM rc/nas/ies/UeNetworkCapability.c:0063    uenetworkcapability decoded UMTS
000574 00199:810597 7F820083C700 TRACE NAS-EM rc/nas/ies/UeNetworkCapability.c:0074    uenetworkcapability decoded misc flags
000575 00199:810600 7F820083C700 TRACE NAS-EM rc/nas/ies/UeNetworkCapability.c:0079    uenetworkcapability decoded=6
000576 00199:810606 7F820083C700 TRACE NAS-EM rc/nas/ies/UeNetworkCapability.c:0083    uenetworkcapability then decoded=6
000577 00199:810610 7F820083C700 TRACE NAS-ES rc/nas/ies/EsmMessageContainer.c:0037    Entering decode_esm_message_container()
000578 00199:810614 7F820083C700 TRACE NAS-ES rc/nas/ies/EsmMessageContainer.c:0054    Leaving decode_esm_message_container() (rc=41)
000579 00199:810619 7F820083C700 TRACE NAS-EM src/common/3gpp_24.008_gmm_ies.c:0277    decode_ms_network_capability_ie len = 3
000580 00199:810629 7F820083C700 TRACE NAS-EM /src/nas/emm/msg/AttachRequest.c:0328    Leaving decode_attach_request() (rc=85)
000581 00199:810633 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0274    Leaving emm_msg_decode() (rc=87)
000582 00199:810636 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0799    Leaving _nas_message_plain_decode() (rc=87)
000583 00199:810639 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0846    Leaving _nas_message_protected_decode() (rc=87)
000584 00199:810642 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0537    Leaving nas_message_decode() (rc=93)
000585 00199:810716 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/sap/emm_recv.c:0148    Entering emm_recv_attach_request()
000586 00199:810723 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/sap/emm_recv.c:0151    EMMAS-SAP - Received Attach Request message
000587 00199:810727 7F820083C700 TRACE NAS-EM openair-mme/src/nas/emm/Attach.c:0199    Entering emm_proc_attach_request()
000588 00199:810730 7F820083C700 INFO  NAS-EM openair-mme/src/nas/emm/Attach.c:0217    EMM-PROC  ATTACH - EPS attach type = IMSI (1) requested (ue_id=1)
000589 00199:810734 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context (nil)
000590 00199:810738 7F820083C700 WARNI NAS-EM openair-mme/src/nas/emm/Attach.c:0336    EMM-PROC  - No old EMM context exists. Continuing with new EMM context for 1.
000591 00199:810741 7F820083C700 INFO  NAS-EM openair-mme/src/nas/emm/Attach.c:0344    EMM-PROC  - Continuing for Attach Request for UE_ID 1 after validation of the attach request.
000592 00199:810744 7F820083C700 INFO  NAS-EM openair-mme/src/nas/emm/Attach.c:0350    EMM-PROC  - No old EMM context was found for UE_ID 1.
000593 00199:810747 7F820083C700 NOTIC NAS-EM openair-mme/src/nas/emm/Attach.c:0379    EMM-PROC  - Create EMM context ue_id = 1
000594 00199:810751 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:1067    UE 1 Init EMM-CTX
000595 00199:810754 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0109    ue_id=1 GUTI cleared
000596 00199:810757 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0137    ue_id=1 old GUTI cleared
000597 00199:810760 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0168    ue_id=1 cleared IMSI
000598 00199:810763 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0210    ue_id=1 IMEI cleared
000599 00199:810766 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0246    ue_id=1 cleared IMEI_SV
000600 00199:810769 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0277    ue_id=1 cleared last visited registered TAI
000601 00199:810773 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0368    ue_id=1 set security context security type 0
000602 00199:810781 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0377    ue_id=1 set security context eksi 7
000603 00199:810784 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0358    ue_id=1 cleared security context
000604 00199:810787 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0415    ue_id=1 cleared non current security context
000605 00199:810790 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0387    ue_id=1 clear security context vector index
000606 00199:810793 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0317    ue_id=1 cleared auth vectors
000607 00199:810796 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0465    ue_id=1 cleared MS network capability IE
000608 00199:810799 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0428    ue_id=1 cleared UE network capability IE
000609 00199:810802 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0499    ue_id=1 cleared current DRX parameter
000610 00199:810805 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0377    ue_id=1 set security context eksi 0
000611 00199:810809 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:1979    EMM-CTX - Add in context 0x7f81680011b0 UE id 1
000612 00199:810813 7F820083C700 TRACE NAS-EM src/nas/emm/nas_emm_procedures.c:0790    New EMM_SPEC_PROC_TYPE_ATTACH
000613 00199:810817 7F820083C700 DEBUG NAS-EM openair-mme/src/nas/emm/Attach.c:1217     CREATED NEW ATTACH PROC 0x7f8168001a90.
 000614 00199:810820 7F820083C700 TRACE NAS-EM openair-mme/src/nas/emm/Attach.c:1455    Entering _emm_attach_run_procedure()
000615 00199:810823 7F820083C700 NOTIC NAS    openair-mme/src/nas/emm/Attach.c:1461    Hit 3GPP TS 24_301R10_5_5_1_2_3__1 : EMM common procedure initiation during attach procedure
000616 00199:810827 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0440    ue_id=1 set UE network capability IE (present)
000617 00199:810830 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0477    ue_id=1 set MS network capability IE (present)
000618 00199:810832 7F820083C700 INFO  NAS-EM openair-mme/src/nas/emm/Attach.c:1522    EMM-PROC  - Received an GUTI 208.95 |0004|01|00000003 in the attach request IE for ue_id=1. Continuing with identification procedure.
000619 00199:810841 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Identification.c:0132    Entering emm_proc_identification()
000620 00199:810845 7F820083C700 NOTIC NAS    mme/src/nas/emm/Identification.c:0138    Hit 3GPP TS 24_301R10_5_4_4_1 : Identification procedure
000621 00199:810847 7F820083C700 INFO  NAS-EM mme/src/nas/emm/Identification.c:0144    EMM-PROC  - Initiate identification type = IMSI (1), ctx = 0x7f81680011b0
000622 00199:810851 7F820083C700 TRACE NAS-EM src/nas/emm/nas_emm_procedures.c:0912    New EMM_COMM_PROC_IDENT
000623 00199:810855 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Identification.c:0573    Entering _identification_request()
000624 00199:810858 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000625 00199:810862 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/LowerLayer.c:0670    Entering emm_as_set_security_data()
000626 00199:810865 7F820083C700 DEBUG NAS-EM air-mme/src/nas/emm/LowerLayer.c:0727    NO Valid Security Context Available
000627 00199:810868 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/LowerLayer.c:0734    Leaving emm_as_set_security_data()
000628 00199:810871 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
000629 00199:810874 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0190    Entering emm_as_send()
000630 00199:810879 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0197    EMMAS-SAP - Received primitive EMMAS_SECURITY_REQ (201)
000631 00199:810882 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1095    Entering _emm_as_send()
000632 00199:810887 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1599    Entering _emm_as_security_req()
000633 00199:810890 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1602    EMMAS-SAP - Send AS security request
000634 00199:810893 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0903    Entering _emm_as_set_header()
000635 00199:810897 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0959    Leaving _emm_as_set_header() (rc=140196331095328)
000636 00199:810900 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/sap/emm_send.c:0942    Entering emm_send_identity_request()
000637 00199:810904 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/sap/emm_send.c:0945    EMMAS-SAP - Send Identity Request message
000638 00199:810907 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/sap/emm_send.c:0968    Leaving emm_send_identity_request() (rc=3)
000639 00199:810910 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000640 00199:810913 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0987    Entering _emm_as_encode()
000641 00199:810916 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0561    Entering nas_message_encode()
000642 00199:810919 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0877    Entering _nas_message_header_encode()
000643 00199:810922 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0913    Leaving _nas_message_header_encode() (rc=1)
000644 00199:810925 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0938    Entering _nas_message_plain_encode()
000645 00199:810927 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0295    Entering emm_msg_encode()
000646 00199:810929 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0465    Leaving emm_msg_encode() (rc=3)
000647 00199:810931 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0963    Leaving _nas_message_plain_encode() (rc=3)
000648 00199:810933 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0656    Leaving nas_message_encode() (rc=3)
000649 00199:810935 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1023    Leaving _emm_as_encode() (rc=3)
000650 00199:810937 7F820083C700 TRACE NAS-ES ir-mme/src/nas/emm/msg/emm_msg.c:0483    Entering emm_msg_free()
000651 00199:810938 7F820083C700 DEBUG NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0493    EMM-MSG   - Message Type 0x55
000652 00199:810940 7F820083C700 TRACE NAS-ES ir-mme/src/nas/emm/msg/emm_msg.c:0592    Leaving emm_msg_free()
000653 00199:810942 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000654 00199:810944 7F820083C700 TRACE NAS-EM src/nas/emm/nas_emm_procedures.c:1059    Found emm_common_proc UID 0x2
000655 00199:810946 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1704    Leaving _emm_as_security_req() (rc=263)
000656 00199:810948 7F820083C700 DEBUG NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1229    EMMAS-SAP - Sending msg with id 0x107, primitive EMMAS_SECURITY_REQ (201) to S1AP layer for transmission
000657 00199:810955 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1236    Leaving _emm_as_send() (rc=0)
000658 00199:810958 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0234    Leaving emm_as_send() (rc=0)
000659 00199:810960 7F820083C700 NOTIC NAS    mme/src/nas/emm/Identification.c:0610    Hit 3GPP TS 24_301R10_5_4_4_2 : Identification initiation by the network
000660 00199:810960 7F81F9704700 TRACE MME-AP /src/mme_app/mme_app_transport.c:0051    Entering mme_app_handle_nas_dl_req()
000661 00199:810967 7F81F9704700 DEBUG MME-AP /src/mme_app/mme_app_transport.c:0064    DOWNLINK NAS TRANSPORT Found enb_ue_s1ap_id 06692d mme_ue_s1ap_id 1
000662 00199:810974 7F81F9704700 TRACE MME-AP /src/mme_app/mme_app_transport.c:0095     MME_APP:DOWNLINK NAS TRANSPORT. MME_UE_S1AP_ID 1 and ENB_UE_S1AP_ID 06692d.
000663 00199:810975 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:1339    T3470 started UE 1
000664 00199:810983 7F81F9704700 TRACE MME-AP /src/mme_app/mme_app_transport.c:0189    Leaving mme_app_handle_nas_dl_req() (rc=0)
000665 00199:810992 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Identification.c:0620    Leaving _identification_request() (rc=0)
000666 00199:810997 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
000667 00199:811000 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_reg.c:0104    Entering emm_reg_send()
000668 00199:811003 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0274    Entering emm_fsm_process()
000669 00199:811007 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000670 00199:811011 7F820083C700 INFO  NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0282    EMM-FSM   - Received event COMMON_PROC_REQ (1) in state EMM-DEREGISTERED
000671 00199:811015 7F820083C700 TRACE NAS-EM rc/nas/emm/sap/EmmDeregistered.c:0097    Entering EmmDeregistered()
000672 00199:811022 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000673 00199:811025 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0176    Entering emm_fsm_set_state()
000674 00199:811028 7F820083C700 INFO  NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0185    UE 1 EMM-FSM   - Status changed: EMM-DEREGISTERED ===> EMM-COMMON-PROCEDURE-INITIATED
000675 00199:811032 7F820083C700 TRACE MME-AP me/src/mme_app/mme_app_context.c:2251    Entering mme_ue_context_update_ue_emm_state()
000676 00199:811036 7F820083C700 TRACE MME-AP me/src/mme_app/mme_app_context.c:2276    Leaving mme_ue_context_update_ue_emm_state()
000677 00199:811041 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0213    Leaving emm_fsm_set_state() (rc=0)
000678 00199:811045 7F820083C700 TRACE NAS-EM rc/nas/emm/sap/EmmDeregistered.c:0424    Leaving EmmDeregistered() (rc=0)
000679 00199:811048 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0293    Leaving emm_fsm_process() (rc=0)
000680 00199:811051 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_reg.c:0117    Leaving emm_reg_send() (rc=0)
000682 00199:811058 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Identification.c:0195    Leaving emm_proc_identification() (rc=0)
000681 00199:811056 7F81F9FFB700 DEBUG S1AP   c/s1ap/s1ap_mme_nas_procedures.c:0452    SEARCHING UE REFERENCE for SCTP association id 1,  enbUeS1apId 06692d and enbId 3584.
000683 00199:811062 7F820083C700 TRACE NAS-EM openair-mme/src/nas/emm/Attach.c:1532    Leaving _emm_attach_run_procedure() (rc=0)
000684 00199:811075 7F820083C700 TRACE NAS-EM openair-mme/src/nas/emm/Attach.c:0609    Leaving emm_proc_attach_request() (rc=0)
000685 00199:811079 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/sap/emm_recv.c:0364    Leaving emm_recv_attach_request() (rc=0)
000686 00199:811083 7F820083C700 TRACE NAS-ES ir-mme/src/nas/emm/msg/emm_msg.c:0483    Entering emm_msg_free()
000687 00199:811086 7F820083C700 DEBUG NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0493    EMM-MSG   - Message Type 0x41
000688 00199:811089 7F820083C700 TRACE NAS-ES ir-mme/src/nas/emm/msg/emm_msg.c:0592    Leaving emm_msg_free()
000689 00199:811092 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0865    Leaving _emm_as_establish_req() (rc=0)
000690 00199:811096 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0234    Leaving emm_as_send() (rc=0)
000691 00199:811100 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0117    Leaving nas_proc_establish_ind() (rc=0)
000692 00199:811103 7F81F9FFB700 NOTIC S1AP   c/s1ap/s1ap_mme_nas_procedures.c:0543    Send S1AP DOWNLINK_NAS_TRANSPORT message ue_id = 1 MME_UE_S1AP_ID = 1 eNB_UE_S1AP_ID = 06692d
000693 00199:811121 7F81FB7FE700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0283    [48][1] Sending buffer 0x7f816400a0e0 of 29 bytes on stream 1 with ppid 18
000694 00199:811183 7F81FB7FE700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0296    Successfully sent 29 bytes on stream 1
000695 00199:831420 7F81A17FA700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0547    [1][48] Msg of length 65 received from port 36412, on stream 1, PPID 18
000696 00199:831440 7F81A17FA700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0554    SCTP RETURNING!!
000697 00199:831472 7F81F9FFB700 INFO  S1AP   c/s1ap/s1ap_mme_nas_procedures.c:0295    Received S1AP UPLINK_NAS_TRANSPORT message MME_UE_S1AP_ID 1
000698 00199:831543 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0250    Entering nas_proc_ul_transfer_ind()
000699 00199:831550 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
000700 00199:831553 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0190    Entering emm_as_send()
000701 00199:831557 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0197    EMMAS-SAP - Received primitive EMMAS_DATA_IND (211)
000702 00199:831560 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0557    Entering _emm_as_data_ind()
000703 00199:831562 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0565    EMMAS-SAP - Received AS data transfer indication (ue_id=1, delivered=true, length=17)
000704 00199:831565 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000705 00199:831574 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0260    Entering nas_message_decrypt()
000706 00199:831576 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0694    Entering nas_message_header_decode()
000707 00199:831578 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0751    Leaving nas_message_header_decode() (rc=6)
000708 00199:831580 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1392    Entering _nas_message_get_mac()
000709 00199:831582 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:1397    No security context set for integrity protection algorithm
000710 00199:831584 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1398    Leaving _nas_message_get_mac() (rc=0)
000711 00199:831586 7F820083C700 CRITI NAS    rc/nas/api/network/nas_message.c:0311    MAC Failure MSG:88FABE31(2298134065) <> INT ALGO:00000000(0) Type of security context 0
000712 00199:831591 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1049    Entering _nas_message_decrypt()
000713 00199:831593 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:1066    No decryption of message length 11 according to security header type 0x01
000714 00199:831595 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1069    Leaving _nas_message_decrypt() (rc=7)
000715 00199:831597 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0335    Leaving nas_message_decrypt() (rc=11)
000716 00199:831599 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0269    Entering _emm_as_recv()
000717 00199:831601 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0285    EMMAS-SAP - Received EMM message (length=11) integrity protected 1 ciphered 0 mac matched 0 security context 0
000718 00199:831604 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000719 00199:831607 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0360    Entering nas_message_decode()
000720 00199:831611 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:0374    hex stream Incoming NAS message:  07 56 08 29 80 59 00 00 00 00 40
000721 00199:831620 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0694    Entering nas_message_header_decode()
000722 00199:831624 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0751    Leaving nas_message_header_decode() (rc=1)
000723 00199:831627 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:0386    nas_message_header_decode returned size 1
000724 00199:831630 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0776    Entering _nas_message_plain_decode()
000725 00199:831633 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0101    Entering emm_msg_decode()
000726 00199:831636 7F820083C700 DEBUG NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0121    EMM-MSG   - Message Type 0x56
000727 00199:831639 7F820083C700 TRACE NAS-EM /common/3gpp_24.008_common_ies.c:0296    Entering decode_imsi_mobile_identity()
000728 00199:831642 7F820083C700 TRACE NAS-EM /common/3gpp_24.008_common_ies.c:0364    Leaving decode_imsi_mobile_identity() (rc=8)
000729 00199:831645 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0274    Leaving emm_msg_decode() (rc=11)
000730 00199:831648 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0799    Leaving _nas_message_plain_decode() (rc=11)
000731 00199:831650 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0539    Leaving nas_message_decode() (rc=11)
000732 00199:831652 7F820083C700 NOTIC NAS    air-mme/src/nas/emm/sap/emm_as.c:0355    Hit 3GPP TS 24_301R10_4_4_4_3__1 : Integrity checking of NAS signalling messages exception in the MME
000733 00199:831654 7F820083C700 NOTIC NAS    air-mme/src/nas/emm/sap/emm_as.c:0358    Hit 3GPP TS 24_301R10_4_4_4_3__2 : Process NAS signalling message in the MME, even if it fails the integrity check or MAC cannot be verified
000734 00199:831656 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/sap/emm_recv.c:0893    Entering emm_recv_identity_response()
000735 00199:831658 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/sap/emm_recv.c:0896    EMMAS-SAP - Received Identity Response message
000736 00199:831660 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Identification.c:0224    Entering emm_proc_identification_complete()
000737 00199:831663 7F820083C700 INFO  NAS-EM mme/src/nas/emm/Identification.c:0232    EMM-PROC  - Identification complete (ue_id=1)
000738 00199:831667 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000739 00199:831670 7F820083C700 NOTIC NAS    mme/src/nas/emm/Identification.c:0241    Hit 3GPP TS 24_301R10_5_4_4_4 : Identification completion by the network
000740 00199:831677 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:1446    T3470 stopped UE 1
000741 00199:831683 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0197    ue_id=1 set IMSI 208950000000004 (valid)
000742 00199:831686 7F820083C700 TRACE NAS    ir-mme/src/nas/api/mme/mme_api.c:0365    Entering mme_api_notify_imsi()
000743 00199:831690 7F820083C700 TRACE MME-AP me/src/mme_app/mme_app_context.c:0325    Entering mme_ue_context_update_coll_keys()
000744 00199:831696 7F820083C700 TRACE MME-AP me/src/mme_app/mme_app_context.c:0334    Update ue context.enb_ue_s1ap_id 06692d ue context.mme_ue_s1ap_id 1 ue context.IMSI 0 ue context.GUTI 000.000|0000|00|00000000
000745 00199:831700 7F820083C700 TRACE MME-AP me/src/mme_app/mme_app_context.c:0342    Update ue context 0x5570b59e3858 enb_ue_s1ap_id 06692d mme_ue_s1ap_id 1 IMSI 208950000000004 GUTI 000.000|0000|00|00000000
000746 00199:831705 7F820083C700 TRACE MME-AP me/src/mme_app/mme_app_context.c:0605    Leaving mme_ue_context_update_coll_keys()
000747 00199:831709 7F820083C700 DEBUG MME-AP ir-mme/src/nas/api/mme/mme_api.c:0394    MME_APP context for ue_id=1 has a registered valid IMSI 208950000000004 (valid)
000748 00199:831712 7F820083C700 TRACE NAS    ir-mme/src/nas/api/mme/mme_api.c:0395    Leaving mme_api_notify_imsi() (rc=0)
000749 00199:831717 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:2116    EMM-CTX - Upsert in context UE id 1 with IMSI 208950000000004
000750 00199:831721 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000751 00199:831723 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0896    EMM-CTX - get UE id 1 context 0x7f81680011b0 by imsi 208950000000004
000752 00199:831726 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
000753 00199:831729 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_reg.c:0104    Entering emm_reg_send()
000754 00199:831732 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0274    Entering emm_fsm_process()
000755 00199:831735 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000756 00199:831738 7F820083C700 INFO  NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0282    EMM-FSM   - Received event COMMON_PROC_CNF (2) in state EMM-COMMON-PROCEDURE-INITIATED
000757 00199:831741 7F820083C700 TRACE NAS-EM ap/EmmCommonProcedureInitiated.c:0093    Entering EmmCommonProcedureInitiated()
000758 00199:831747 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000759 00199:831750 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0176    Entering emm_fsm_set_state()
000760 00199:831753 7F820083C700 INFO  NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0185    UE 1 EMM-FSM   - Status changed: EMM-COMMON-PROCEDURE-INITIATED ===> EMM-DEREGISTERED
000761 00199:831757 7F820083C700 TRACE MME-AP me/src/mme_app/mme_app_context.c:2251    Entering mme_ue_context_update_ue_emm_state()
000762 00199:831760 7F820083C700 TRACE MME-AP me/src/mme_app/mme_app_context.c:2276    Leaving mme_ue_context_update_ue_emm_state()
000763 00199:831763 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0213    Leaving emm_fsm_set_state() (rc=0)
000764 00199:831767 7F820083C700 TRACE NAS-EM openair-mme/src/nas/emm/Attach.c:1630    Entering _emm_attach_success_identification_cb()
000765 00199:831772 7F820083C700 NOTIC NAS    openair-mme/src/nas/emm/Attach.c:1637    Hit 3GPP TS 24_301R10_5_5_1_2_3__1 : EMM common procedure initiation during attach procedure
000766 00199:831775 7F820083C700 TRACE NAS-EM openair-mme/src/nas/emm/Attach.c:1658    Entering _emm_start_attach_proc_authentication()
000767 00199:831779 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:0250    Entering emm_proc_authentication()
000768 00199:831783 7F820083C700 TRACE NAS-EM src/nas/emm/nas_emm_procedures.c:0942    New EMM_COMM_PROC_AUTH
000769 00199:831789 7F820083C700 TRACE NAS-EM src/nas/emm/nas_emm_procedures.c:0999    New CN_PROC_AUTH_INFO
000770 00199:831792 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:0335    Entering _start_authentication_information_procedure()
000771 00199:831801 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:1360    Ts6a_auth_info started UE 1
000772 00199:831805 7F820083C700 TRACE NAS    mme/src/nas/nas_itti_messaging.c:0469    Entering nas_itti_auth_info_req()
000773 00199:831819 7F820083C700 TRACE NAS    mme/src/nas/nas_itti_messaging.c:0502    Leaving nas_itti_auth_info_req()
000774 00199:831822 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:0374    Leaving _start_authentication_information_procedure() (rc=0)
000775 00199:831826 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:0328    Leaving emm_proc_authentication() (rc=0)
000776 00199:831829 7F820083C700 TRACE NAS-EM openair-mme/src/nas/emm/Attach.c:1666    Leaving _emm_start_attach_proc_authentication() (rc=0)
000777 00199:831832 7F820083C700 TRACE NAS-EM openair-mme/src/nas/emm/Attach.c:1643    Leaving _emm_attach_success_identification_cb() (rc=0)
000778 00199:831835 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000779 00199:831839 7F820083C700 TRACE NAS-EM src/nas/emm/nas_emm_procedures.c:0405    Delete IDENT procedure 2
000780 00199:831845 7F820083C700 TRACE NAS-EM ap/EmmCommonProcedureInitiated.c:0577    Leaving EmmCommonProcedureInitiated() (rc=0)
000781 00199:831848 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0293    Leaving emm_fsm_process() (rc=0)
000782 00199:831851 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_reg.c:0117    Leaving emm_reg_send() (rc=0)
000783 00199:831854 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Identification.c:0439    Leaving emm_proc_identification_complete() (rc=0)
000784 00199:831858 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/sap/emm_recv.c:0999    Leaving emm_recv_identity_response() (rc=0)
000785 00199:831862 7F820083C700 TRACE NAS-ES ir-mme/src/nas/emm/msg/emm_msg.c:0483    Entering emm_msg_free()
000786 00199:831866 7F820083C700 DEBUG NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0493    EMM-MSG   - Message Type 0x56
000787 00199:831870 7F820083C700 TRACE NAS-ES ir-mme/src/nas/emm/msg/emm_msg.c:0592    Leaving emm_msg_free()
000788 00199:831875 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0536    Leaving _emm_as_recv() (rc=0)
000789 00199:831878 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0673    Leaving _emm_as_data_ind() (rc=0)
000790 00199:831881 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0234    Leaving emm_as_send() (rc=0)
000791 00199:831884 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0270    Leaving nas_proc_ul_transfer_ind() (rc=0)
000792 00199:831939 7F81A2FFD700 DEBUG S6A    nair-mme/src/s6a/s6a_auth_info.c:0382    s6a_generate_authentication_info_req plmn: 02F859
000793 00199:831952 7F81A2FFD700 DEBUG S6A    nair-mme/src/s6a/s6a_auth_info.c:0384    s6a_generate_authentication_info_req visited_plmn: 02F859
000794 00199:833784 7F81F17FA700 DEBUG S6A    nair-mme/src/s6a/s6a_auth_info.c:0202    Received S6A Authentication Information Answer (AIA)
000795 00199:833799 7F81F17FA700 DEBUG S6A    nair-mme/src/s6a/s6a_auth_info.c:0234    Received S6A Result code 2001:DIAMETER_SUCCESS
000796 00199:833823 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0275    Entering nas_proc_authentication_info_answer()
000797 00199:833830 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0283    Handling imsi 208950000000004
000798 00199:833837 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000799 00199:833841 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0896    EMM-CTX - get UE id 1 context 0x7f81680011b0 by imsi 208950000000004
000800 00199:833844 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0307    INFORMING NAS ABOUT AUTH RESP SUCCESS got 1 vector(s)
000801 00199:833846 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0335    Entering nas_proc_auth_param_res()
000802 00199:833847 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
000803 00199:833849 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_cn.c:0388    Entering emm_cn_send()
000804 00199:833851 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_cn.c:0390    EMMCN-SAP - Received primitive EMM_CN_AUTHENTICATION_PARAM_RES (401)
000805 00199:833854 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_cn.c:0089    Entering _emm_cn_authentication_res()
000806 00199:833856 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000807 00199:833858 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:0399    Entering _auth_info_proc_success_cb()
000808 00199:833860 7F820083C700 NOTIC NAS    mme/src/nas/emm/Authentication.c:0411    Hit 3GPP TS 24_301R10_5_4_2_4__2 : authentication procedure is success, new eKSI for new authentication procedure
000809 00199:833862 7F820083C700 INFO  NAS-EM mme/src/nas/emm/Authentication.c:0432    EMM-PROC  - Received Vector 0:
000810 00199:833864 7F820083C700 INFO  NAS-EM mme/src/nas/emm/Authentication.c:0435    EMM-PROC  - Received XRES ..: 0d,27,29,ae,7f,6c,8f,d7,00,00,00,00,00,00,00,00
000811 00199:833867 7F820083C700 INFO  NAS-EM mme/src/nas/emm/Authentication.c:0438    EMM-PROC  - Received RAND ..: fd,79,d7,04,3d,91,2c,18,87,aa,38,40,fc,07,69,11
000812 00199:833869 7F820083C700 INFO  NAS-EM mme/src/nas/emm/Authentication.c:0441    EMM-PROC  - Received AUTN ..: 2e,12,c5,bd,f8,5e,80,00,9f,24,ee,77,19,fd,d3,3c
000813 00199:833872 7F820083C700 INFO  NAS-EM mme/src/nas/emm/Authentication.c:0446    EMM-PROC  - Received KASME .: 0a,c7,e4,9d,d5,15,79,55,3d,95,2c,0c,d1,36,23,5d 2f,8a,fd,c5,cd,30,c8,77,a4,84,1d,c8,60,b9,68,e9
000814 00199:833875 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
000815 00199:833877 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_reg.c:0104    Entering emm_reg_send()
000816 00199:833879 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0274    Entering emm_fsm_process()
000817 00199:833881 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000818 00199:833883 7F820083C700 INFO  NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0282    EMM-FSM   - Received event COMMON_PROC_ABORT (4) in state EMM-DEREGISTERED
000819 00199:833885 7F820083C700 TRACE NAS-EM rc/nas/emm/sap/EmmDeregistered.c:0097    Entering EmmDeregistered()
000820 00199:833889 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000821 00199:833892 7F820083C700 WARNI NAS-EM rc/nas/emm/sap/EmmDeregistered.c:0149    EMM-FSM state EMM_DEREGISTERED - Primitive _EMMREG_COMMON_PROC_ABORT is not valid
000822 00199:833895 7F820083C700 TRACE NAS-EM rc/nas/emm/sap/EmmDeregistered.c:0424    Leaving EmmDeregistered() (rc=-1)
000823 00199:833898 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0293    Leaving emm_fsm_process() (rc=-1)
000824 00199:833901 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_reg.c:0117    Leaving emm_reg_send() (rc=-1)
000825 00199:833903 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:0167    Entering emm_proc_authentication_ksi()
000826 00199:833906 7F820083C700 INFO  NAS-EM mme/src/nas/emm/Authentication.c:0176    ue_id=1 EMM-PROC  - Initiate authentication KSI = 1
000827 00199:833910 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:1082    Entering _authentication_request()
000828 00199:833914 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000829 00199:833917 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/LowerLayer.c:0670    Entering emm_as_set_security_data()
000830 00199:833920 7F820083C700 DEBUG NAS-EM air-mme/src/nas/emm/LowerLayer.c:0727    NO Valid Security Context Available
000831 00199:833923 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/LowerLayer.c:0734    Leaving emm_as_set_security_data()
000832 00199:833925 7F820083C700 NOTIC NAS    mme/src/nas/emm/Authentication.c:1119    Hit 3GPP TS 24_301R10_5_4_2_2 : Authentication initiation by the network
000833 00199:833927 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
000834 00199:833929 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0190    Entering emm_as_send()
000835 00199:833931 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0197    EMMAS-SAP - Received primitive EMMAS_SECURITY_REQ (201)
000836 00199:833933 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1095    Entering _emm_as_send()
000837 00199:833936 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1599    Entering _emm_as_security_req()
000838 00199:833938 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1602    EMMAS-SAP - Send AS security request
000839 00199:833941 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0903    Entering _emm_as_set_header()
000840 00199:833942 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0959    Leaving _emm_as_set_header() (rc=140196331099824)
000841 00199:833945 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/sap/emm_send.c:0990    Entering emm_send_authentication_request()
000842 00199:833946 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/sap/emm_send.c:0993    EMMAS-SAP - Send Authentication Request message
000843 00199:833948 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/sap/emm_send.c:1022    Leaving emm_send_authentication_request() (rc=38)
000844 00199:833950 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000845 00199:833952 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0987    Entering _emm_as_encode()
000846 00199:833955 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0561    Entering nas_message_encode()
000847 00199:833957 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0877    Entering _nas_message_header_encode()
000848 00199:833958 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0913    Leaving _nas_message_header_encode() (rc=1)
000849 00199:833960 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0938    Entering _nas_message_plain_encode()
000850 00199:833963 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0295    Entering emm_msg_encode()
000851 00199:833966 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0465    Leaving emm_msg_encode() (rc=36)
000852 00199:833970 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0963    Leaving _nas_message_plain_encode() (rc=36)
000853 00199:833972 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0656    Leaving nas_message_encode() (rc=36)
000854 00199:833974 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1023    Leaving _emm_as_encode() (rc=36)
000855 00199:833976 7F820083C700 TRACE NAS-ES ir-mme/src/nas/emm/msg/emm_msg.c:0483    Entering emm_msg_free()
000856 00199:833977 7F820083C700 DEBUG NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0493    EMM-MSG   - Message Type 0x52
000857 00199:833979 7F820083C700 TRACE NAS-ES ir-mme/src/nas/emm/msg/emm_msg.c:0592    Leaving emm_msg_free()
000858 00199:833981 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000859 00199:833984 7F820083C700 TRACE NAS-EM src/nas/emm/nas_emm_procedures.c:1059    Found emm_common_proc UID 0x3
000860 00199:833989 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1704    Leaving _emm_as_security_req() (rc=263)
000861 00199:833992 7F820083C700 DEBUG NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1229    EMMAS-SAP - Sending msg with id 0x107, primitive EMMAS_SECURITY_REQ (201) to S1AP layer for transmission
000862 00199:834003 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1236    Leaving _emm_as_send() (rc=0)
000863 00199:834007 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0234    Leaving emm_as_send() (rc=0)
000864 00199:834017 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:1321    T3460 started UE 1
000865 00199:834020 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:1144    Leaving _authentication_request() (rc=0)
000866 00199:834023 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
000867 00199:834029 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_reg.c:0104    Entering emm_reg_send()
000868 00199:834032 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0274    Entering emm_fsm_process()
000869 00199:834035 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000870 00199:834038 7F820083C700 INFO  NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0282    EMM-FSM   - Received event COMMON_PROC_REQ (1) in state EMM-DEREGISTERED
000871 00199:834042 7F820083C700 TRACE NAS-EM rc/nas/emm/sap/EmmDeregistered.c:0097    Entering EmmDeregistered()
000872 00199:834045 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000873 00199:834048 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0176    Entering emm_fsm_set_state()
000874 00199:834051 7F820083C700 INFO  NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0185    UE 1 EMM-FSM   - Status changed: EMM-DEREGISTERED ===> EMM-COMMON-PROCEDURE-INITIATED
000875 00199:834055 7F820083C700 TRACE MME-AP me/src/mme_app/mme_app_context.c:2251    Entering mme_ue_context_update_ue_emm_state()
000876 00199:834059 7F820083C700 TRACE MME-AP me/src/mme_app/mme_app_context.c:2276    Leaving mme_ue_context_update_ue_emm_state()
000877 00199:834064 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0213    Leaving emm_fsm_set_state() (rc=0)
000878 00199:834068 7F820083C700 TRACE NAS-EM rc/nas/emm/sap/EmmDeregistered.c:0424    Leaving EmmDeregistered() (rc=0)
000879 00199:834073 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0293    Leaving emm_fsm_process() (rc=0)
000880 00199:834077 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_reg.c:0117    Leaving emm_reg_send() (rc=0)
000881 00199:834080 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:0243    Leaving emm_proc_authentication_ksi() (rc=0)
000882 00199:834084 7F820083C700 TRACE NAS-EM src/nas/emm/nas_emm_procedures.c:0614    UE 1 Delete AUTH INFO procedure
000883 00199:834091 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:1460    Ts6a_auth_info stopped UE 1
000884 00199:834095 7F820083C700 TRACE NAS-EM src/nas/emm/nas_emm_procedures.c:0684    UE 1 Delete CN procedure 0x7f8168001e90
000885 00199:834099 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:0525    Leaving _auth_info_proc_success_cb() (rc=0)
000886 00199:834103 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_cn.c:0116    Leaving _emm_cn_authentication_res() (rc=0)
000887 00199:834106 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_cn.c:0438    Leaving emm_cn_send() (rc=0)
000888 00199:834109 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0352    Leaving nas_proc_auth_param_res() (rc=0)
000889 00199:834112 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0329    Leaving nas_proc_authentication_info_answer() (rc=0)
000890 00199:834122 7F81F9704700 TRACE MME-AP /src/mme_app/mme_app_transport.c:0051    Entering mme_app_handle_nas_dl_req()
000891 00199:834129 7F81F9704700 DEBUG MME-AP /src/mme_app/mme_app_transport.c:0064    DOWNLINK NAS TRANSPORT Found enb_ue_s1ap_id 06692d mme_ue_s1ap_id 1
000892 00199:834136 7F81F9704700 TRACE MME-AP /src/mme_app/mme_app_transport.c:0095     MME_APP:DOWNLINK NAS TRANSPORT. MME_UE_S1AP_ID 1 and ENB_UE_S1AP_ID 06692d.
000893 00199:834141 7F81F9704700 TRACE MME-AP /src/mme_app/mme_app_transport.c:0189    Leaving mme_app_handle_nas_dl_req() (rc=0)
000894 00199:834151 7F81F9FFB700 DEBUG S1AP   c/s1ap/s1ap_mme_nas_procedures.c:0452    SEARCHING UE REFERENCE for SCTP association id 1,  enbUeS1apId 06692d and enbId 3584.
000895 00199:834180 7F81F9FFB700 NOTIC S1AP   c/s1ap/s1ap_mme_nas_procedures.c:0543    Send S1AP DOWNLINK_NAS_TRANSPORT message ue_id = 1 MME_UE_S1AP_ID = 1 eNB_UE_S1AP_ID = 06692d
000896 00199:834199 7F81FB7FE700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0283    [48][1] Sending buffer 0x7f8168003cf0 of 62 bytes on stream 1 with ppid 18
000897 00199:834244 7F81FB7FE700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0296    Successfully sent 62 bytes on stream 1
000898 00199:927465 7F81A17FA700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0547    [1][48] Msg of length 73 received from port 36412, on stream 1, PPID 18
000899 00199:927502 7F81A17FA700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0554    SCTP RETURNING!!
000900 00199:927565 7F81F9FFB700 INFO  S1AP   c/s1ap/s1ap_mme_nas_procedures.c:0295    Received S1AP UPLINK_NAS_TRANSPORT message MME_UE_S1AP_ID 1
000901 00199:927697 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0250    Entering nas_proc_ul_transfer_ind()
000902 00199:927711 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
000903 00199:927716 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0190    Entering emm_as_send()
000904 00199:927720 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0197    EMMAS-SAP - Received primitive EMMAS_DATA_IND (211)
000905 00199:927724 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0557    Entering _emm_as_data_ind()
000906 00199:927727 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0565    EMMAS-SAP - Received AS data transfer indication (ue_id=1, delivered=true, length=25)
000907 00199:927732 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000908 00199:927736 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0260    Entering nas_message_decrypt()
000909 00199:927740 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0694    Entering nas_message_header_decode()
000910 00199:927743 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0751    Leaving nas_message_header_decode() (rc=6)
000911 00199:927747 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1392    Entering _nas_message_get_mac()
000912 00199:927751 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:1397    No security context set for integrity protection algorithm
000913 00199:927754 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1398    Leaving _nas_message_get_mac() (rc=0)
000914 00199:927757 7F820083C700 CRITI NAS    rc/nas/api/network/nas_message.c:0311    MAC Failure MSG:E67DF12E(3867013422) <> INT ALGO:00000000(0) Type of security context 0
000915 00199:927761 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1049    Entering _nas_message_decrypt()
000916 00199:927764 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:1066    No decryption of message length 19 according to security header type 0x01
000917 00199:927768 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1069    Leaving _nas_message_decrypt() (rc=7)
000918 00199:927771 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0335    Leaving nas_message_decrypt() (rc=19)
000919 00199:927776 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0269    Entering _emm_as_recv()
000920 00199:927783 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0285    EMMAS-SAP - Received EMM message (length=19) integrity protected 1 ciphered 0 mac matched 0 security context 0
000921 00199:927787 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000922 00199:927790 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0360    Entering nas_message_decode()
000923 00199:927793 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:0374    hex stream Incoming NAS message:  07 5c 15 30 0e ba 78 3b e6 96 6f 74 c7 50 ff c4 39 18 fb
000924 00199:927805 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0694    Entering nas_message_header_decode()
000925 00199:927808 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0751    Leaving nas_message_header_decode() (rc=1)
000926 00199:927812 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:0386    nas_message_header_decode returned size 1
000927 00199:927815 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0776    Entering _nas_message_plain_decode()
000928 00199:927818 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0101    Entering emm_msg_decode()
000929 00199:927821 7F820083C700 DEBUG NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0121    EMM-MSG   - Message Type 0x5c
000930 00199:927825 7F820083C700 TRACE NAS    /src/common/3gpp_24.008_mm_ies.c:0243    Entering decode_authentication_failure_parameter_ie()
000931 00199:927829 7F820083C700 TRACE NAS    /src/common/3gpp_24.008_mm_ies.c:0268    Leaving decode_authentication_failure_parameter_ie() (rc=16)
000932 00199:927832 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0274    Leaving emm_msg_decode() (rc=19)
000933 00199:927836 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0799    Leaving _nas_message_plain_decode() (rc=19)
000934 00199:927839 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0539    Leaving nas_message_decode() (rc=19)
000935 00199:927842 7F820083C700 NOTIC NAS    air-mme/src/nas/emm/sap/emm_as.c:0377    Hit 3GPP TS 24_301R10_4_4_4_3__1 : Integrity checking of NAS signalling messages exception in the MME
000936 00199:927845 7F820083C700 NOTIC NAS    air-mme/src/nas/emm/sap/emm_as.c:0380    Hit 3GPP TS 24_301R10_4_4_4_3__2 : Process NAS signalling message in the MME, even if it fails the integrity check or MAC cannot be verified
000937 00199:927849 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/sap/emm_recv.c:1076    Entering emm_recv_authentication_failure()
000938 00199:927852 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/sap/emm_recv.c:1080    EMMAS-SAP - Received Authentication Failure message
000939 00199:927858 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:0579    Entering emm_proc_authentication_failure()
000940 00199:927863 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000941 00199:927869 7F820083C700 INFO  NAS-EM mme/src/nas/emm/Authentication.c:0597    EMM-PROC  - Authentication failure (ue_id=1, cause=21)
000942 00199:927874 7F820083C700 NOTIC NAS    mme/src/nas/emm/Authentication.c:0603    Hit 3GPP TS 24_301R10_5_4_2_4__3 : AUTHENTICATION FAILURE received with EMM cause sync failure, renegociate with HSS.
000943 00199:927885 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:1433    T3460 stopped UE 1
000944 00199:927891 7F820083C700 NOTIC NAS    mme/src/nas/emm/Authentication.c:0613    Hit 3GPP TS 24_301R10_5_4_2_4__3 : AUTHENTICATION FAILURE received with EMM cause sync failure, renegociate with HSS.
000945 00199:927896 7F820083C700 DEBUG NAS-EM mme/src/nas/emm/Authentication.c:0622    EMM-PROC  - USIM has detected a mismatch in SQN Ask for new vector(s)
000946 00199:927901 7F820083C700 NOTIC NAS    mme/src/nas/emm/Authentication.c:0624    Hit 3GPP TS 24_301R10_5_4_2_7_e__3 : Re-synchronisation, new vectors
000947 00199:927906 7F820083C700 NOTIC NAS    mme/src/nas/emm/Authentication.c:0626    Hit 3GPP TS 24_301R10_5_4_2_7_e__2 : Re-synchronise with AUTS parameter
000948 00199:927912 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:0381    Entering _start_authentication_information_procedure_synch()
000949 00199:927919 7F820083C700 TRACE NAS-EM src/nas/emm/nas_emm_procedures.c:0999    New CN_PROC_AUTH_INFO
000950 00199:927924 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:0335    Entering _start_authentication_information_procedure()
000951 00199:927937 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:1360    Ts6a_auth_info started UE 1
000952 00199:927950 7F820083C700 TRACE NAS    mme/src/nas/nas_itti_messaging.c:0469    Entering nas_itti_auth_info_req()
000953 00199:927967 7F820083C700 TRACE NAS    mme/src/nas/nas_itti_messaging.c:0502    Leaving nas_itti_auth_info_req()
000954 00199:927972 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:0374    Leaving _start_authentication_information_procedure() (rc=0)
000955 00199:927977 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:0392    Leaving _start_authentication_information_procedure_synch() (rc=0)
000956 00199:927982 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0387    ue_id=1 clear security context vector index
000957 00199:927987 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0317    ue_id=1 cleared auth vectors
000958 00199:927992 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:0648    Leaving emm_proc_authentication_failure() (rc=0)
000959 00199:927997 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/sap/emm_recv.c:1112    Leaving emm_recv_authentication_failure() (rc=0)
000960 00199:928002 7F820083C700 TRACE NAS-ES ir-mme/src/nas/emm/msg/emm_msg.c:0483    Entering emm_msg_free()
000961 00199:928007 7F820083C700 DEBUG NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0493    EMM-MSG   - Message Type 0x5c
000962 00199:928012 7F820083C700 TRACE NAS-ES ir-mme/src/nas/emm/msg/emm_msg.c:0592    Leaving emm_msg_free()
000963 00199:928017 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0536    Leaving _emm_as_recv() (rc=0)
000964 00199:928023 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0673    Leaving _emm_as_data_ind() (rc=0)
000966 00199:928028 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0234    Leaving emm_as_send() (rc=0)
000965 00199:928023 7F81A2FFD700 DEBUG S6A    nair-mme/src/s6a/s6a_auth_info.c:0382    s6a_generate_authentication_info_req plmn: 02F859
000967 00199:928033 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0270    Leaving nas_proc_ul_transfer_ind() (rc=0)
000968 00199:928053 7F81A2FFD700 DEBUG S6A    nair-mme/src/s6a/s6a_auth_info.c:0384    s6a_generate_authentication_info_req visited_plmn: 02F859
000969 00199:928073 7F81A2FFD700 DEBUG S6A    nair-mme/src/s6a/s6a_auth_info.c:0417    Added Re-Synchronistaion for UE
000970 00199:931362 7F81F17FA700 DEBUG S6A    nair-mme/src/s6a/s6a_auth_info.c:0202    Received S6A Authentication Information Answer (AIA)
000971 00199:931388 7F81F17FA700 DEBUG S6A    nair-mme/src/s6a/s6a_auth_info.c:0234    Received S6A Result code 2001:DIAMETER_SUCCESS
000972 00199:931443 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0275    Entering nas_proc_authentication_info_answer()
000973 00199:931468 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0283    Handling imsi 208950000000004
000974 00199:931484 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000975 00199:931494 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0896    EMM-CTX - get UE id 1 context 0x7f81680011b0 by imsi 208950000000004
000976 00199:931508 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0307    INFORMING NAS ABOUT AUTH RESP SUCCESS got 1 vector(s)
000977 00199:931518 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0335    Entering nas_proc_auth_param_res()
000978 00199:931527 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
000979 00199:931535 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_cn.c:0388    Entering emm_cn_send()
000980 00199:931549 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_cn.c:0390    EMMCN-SAP - Received primitive EMM_CN_AUTHENTICATION_PARAM_RES (401)
000981 00199:931558 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_cn.c:0089    Entering _emm_cn_authentication_res()
000982 00199:931566 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000983 00199:931574 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:0399    Entering _auth_info_proc_success_cb()
000984 00199:931583 7F820083C700 NOTIC NAS    mme/src/nas/emm/Authentication.c:0411    Hit 3GPP TS 24_301R10_5_4_2_4__2 : authentication procedure is success, new eKSI for new authentication procedure
000985 00199:931591 7F820083C700 INFO  NAS-EM mme/src/nas/emm/Authentication.c:0432    EMM-PROC  - Received Vector 0:
000986 00199:931600 7F820083C700 INFO  NAS-EM mme/src/nas/emm/Authentication.c:0435    EMM-PROC  - Received XRES ..: 06,3c,b8,c1,68,93,3a,60,00,00,00,00,00,00,00,00
000987 00199:931612 7F820083C700 INFO  NAS-EM mme/src/nas/emm/Authentication.c:0438    EMM-PROC  - Received RAND ..: 80,8c,95,7c,c0,69,7e,5a,4d,e9,8f,74,e9,d7,a0,50
000988 00199:931619 7F820083C700 INFO  NAS-EM mme/src/nas/emm/Authentication.c:0441    EMM-PROC  - Received AUTN ..: a6,86,81,cf,05,b4,80,00,d2,f6,bf,99,fb,fe,1c,44
000989 00199:931626 7F820083C700 INFO  NAS-EM mme/src/nas/emm/Authentication.c:0446    EMM-PROC  - Received KASME .: 16,78,a1,64,c3,af,15,be,a3,da,48,6a,7e,8e,e5,0e 7a,95,bc,95,08,78,d3,dc,f6,64,6b,95,06,6e,23,ce
000990 00199:931638 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
000991 00199:931645 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_reg.c:0104    Entering emm_reg_send()
000992 00199:931651 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0274    Entering emm_fsm_process()
000993 00199:931656 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000994 00199:931661 7F820083C700 INFO  NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0282    EMM-FSM   - Received event COMMON_PROC_ABORT (4) in state EMM-COMMON-PROCEDURE-INITIATED
000995 00199:931667 7F820083C700 TRACE NAS-EM ap/EmmCommonProcedureInitiated.c:0093    Entering EmmCommonProcedureInitiated()
000996 00199:931672 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
000997 00199:931677 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:1266    Entering _authentication_abort()
000998 00199:931682 7F820083C700 INFO  NAS-EM mme/src/nas/emm/Authentication.c:1274    EMM-PROC  - Abort authentication procedure (ue_id=1)
000999 00199:931687 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:1283    Leaving _authentication_abort() (rc=-1)
001000 00199:931694 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001001 00199:931702 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0176    Entering emm_fsm_set_state()
001002 00199:931709 7F820083C700 INFO  NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0185    UE 1 EMM-FSM   - Status changed: EMM-COMMON-PROCEDURE-INITIATED ===> EMM-DEREGISTERED
001003 00199:931718 7F820083C700 TRACE MME-AP me/src/mme_app/mme_app_context.c:2251    Entering mme_ue_context_update_ue_emm_state()
001004 00199:931728 7F820083C700 TRACE MME-AP me/src/mme_app/mme_app_context.c:2276    Leaving mme_ue_context_update_ue_emm_state()
001005 00199:931735 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0213    Leaving emm_fsm_set_state() (rc=0)
001006 00199:931744 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001007 00199:931752 7F820083C700 TRACE NAS-EM ap/EmmCommonProcedureInitiated.c:0577    Leaving EmmCommonProcedureInitiated() (rc=0)
001008 00199:931760 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0293    Leaving emm_fsm_process() (rc=0)
001009 00199:931768 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_reg.c:0117    Leaving emm_reg_send() (rc=0)
001010 00199:931776 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:0167    Entering emm_proc_authentication_ksi()
001011 00199:931783 7F820083C700 INFO  NAS-EM mme/src/nas/emm/Authentication.c:0176    ue_id=1 EMM-PROC  - Initiate authentication KSI = 2
001012 00199:931792 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:1082    Entering _authentication_request()
001013 00199:931800 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001014 00199:931807 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/LowerLayer.c:0670    Entering emm_as_set_security_data()
001015 00199:931815 7F820083C700 DEBUG NAS-EM air-mme/src/nas/emm/LowerLayer.c:0727    NO Valid Security Context Available
001016 00199:931821 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/LowerLayer.c:0734    Leaving emm_as_set_security_data()
001017 00199:931829 7F820083C700 NOTIC NAS    mme/src/nas/emm/Authentication.c:1119    Hit 3GPP TS 24_301R10_5_4_2_2 : Authentication initiation by the network
001018 00199:931837 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
001019 00199:931844 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0190    Entering emm_as_send()
001020 00199:931852 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0197    EMMAS-SAP - Received primitive EMMAS_SECURITY_REQ (201)
001021 00199:931860 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1095    Entering _emm_as_send()
001022 00199:931869 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1599    Entering _emm_as_security_req()
001023 00199:931876 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1602    EMMAS-SAP - Send AS security request
001024 00199:931884 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0903    Entering _emm_as_set_header()
001025 00199:931892 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0959    Leaving _emm_as_set_header() (rc=140196331099824)
001026 00199:931901 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/sap/emm_send.c:0990    Entering emm_send_authentication_request()
001027 00199:931908 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/sap/emm_send.c:0993    EMMAS-SAP - Send Authentication Request message
001028 00199:931917 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/sap/emm_send.c:1022    Leaving emm_send_authentication_request() (rc=38)
001029 00199:931925 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001030 00199:931933 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0987    Entering _emm_as_encode()
001031 00199:931941 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0561    Entering nas_message_encode()
001032 00199:931949 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0877    Entering _nas_message_header_encode()
001033 00199:931957 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0913    Leaving _nas_message_header_encode() (rc=1)
001034 00199:931965 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0938    Entering _nas_message_plain_encode()
001035 00199:931972 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0295    Entering emm_msg_encode()
001036 00199:931979 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0465    Leaving emm_msg_encode() (rc=36)
001037 00199:931984 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0963    Leaving _nas_message_plain_encode() (rc=36)
001038 00199:931990 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0656    Leaving nas_message_encode() (rc=36)
001039 00199:931997 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1023    Leaving _emm_as_encode() (rc=36)
001040 00199:932005 7F820083C700 TRACE NAS-ES ir-mme/src/nas/emm/msg/emm_msg.c:0483    Entering emm_msg_free()
001041 00199:932013 7F820083C700 DEBUG NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0493    EMM-MSG   - Message Type 0x52
001042 00199:932021 7F820083C700 TRACE NAS-ES ir-mme/src/nas/emm/msg/emm_msg.c:0592    Leaving emm_msg_free()
001043 00199:932028 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001044 00199:932034 7F820083C700 TRACE NAS-EM src/nas/emm/nas_emm_procedures.c:1059    Found emm_common_proc UID 0x3
001045 00199:932039 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1704    Leaving _emm_as_security_req() (rc=263)
001046 00199:932044 7F820083C700 DEBUG NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1229    EMMAS-SAP - Sending msg with id 0x107, primitive EMMAS_SECURITY_REQ (201) to S1AP layer for transmission
001047 00199:932060 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1236    Leaving _emm_as_send() (rc=0)
001048 00199:932068 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0234    Leaving emm_as_send() (rc=0)
001049 00199:932077 7F81F9704700 TRACE MME-AP /src/mme_app/mme_app_transport.c:0051    Entering mme_app_handle_nas_dl_req()
001050 00199:932087 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:1321    T3460 started UE 1
001051 00199:932091 7F81F9704700 DEBUG MME-AP /src/mme_app/mme_app_transport.c:0064    DOWNLINK NAS TRANSPORT Found enb_ue_s1ap_id 06692d mme_ue_s1ap_id 1
001052 00199:932096 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:1144    Leaving _authentication_request() (rc=0)
001053 00199:932105 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
001054 00199:932106 7F81F9704700 TRACE MME-AP /src/mme_app/mme_app_transport.c:0095     MME_APP:DOWNLINK NAS TRANSPORT. MME_UE_S1AP_ID 1 and ENB_UE_S1AP_ID 06692d.
001055 00199:932113 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_reg.c:0104    Entering emm_reg_send()
001056 00199:932116 7F81F9704700 TRACE MME-AP /src/mme_app/mme_app_transport.c:0189    Leaving mme_app_handle_nas_dl_req() (rc=0)
001057 00199:932126 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0274    Entering emm_fsm_process()
001058 00199:932133 7F81F9FFB700 DEBUG S1AP   c/s1ap/s1ap_mme_nas_procedures.c:0452    SEARCHING UE REFERENCE for SCTP association id 1,  enbUeS1apId 06692d and enbId 3584.
001059 00199:932141 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001060 00199:932163 7F820083C700 INFO  NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0282    EMM-FSM   - Received event COMMON_PROC_REQ (1) in state EMM-DEREGISTERED
001061 00199:932176 7F820083C700 TRACE NAS-EM rc/nas/emm/sap/EmmDeregistered.c:0097    Entering EmmDeregistered()
001062 00199:932182 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001063 00199:932184 7F81F9FFB700 NOTIC S1AP   c/s1ap/s1ap_mme_nas_procedures.c:0543    Send S1AP DOWNLINK_NAS_TRANSPORT message ue_id = 1 MME_UE_S1AP_ID = 1 eNB_UE_S1AP_ID = 06692d
001064 00199:932189 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0176    Entering emm_fsm_set_state()
001065 00199:932197 7F820083C700 INFO  NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0185    UE 1 EMM-FSM   - Status changed: EMM-DEREGISTERED ===> EMM-COMMON-PROCEDURE-INITIATED
001066 00199:932205 7F820083C700 TRACE MME-AP me/src/mme_app/mme_app_context.c:2251    Entering mme_ue_context_update_ue_emm_state()
001067 00199:932214 7F820083C700 TRACE MME-AP me/src/mme_app/mme_app_context.c:2276    Leaving mme_ue_context_update_ue_emm_state()
001069 00199:932222 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0213    Leaving emm_fsm_set_state() (rc=0)
001068 00199:932220 7F81FB7FE700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0283    [48][1] Sending buffer 0x7f81640099b0 of 62 bytes on stream 1 with ppid 18
001070 00199:932230 7F820083C700 TRACE NAS-EM rc/nas/emm/sap/EmmDeregistered.c:0424    Leaving EmmDeregistered() (rc=0)
001071 00199:932250 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0293    Leaving emm_fsm_process() (rc=0)
001072 00199:932256 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_reg.c:0117    Leaving emm_reg_send() (rc=0)
001073 00199:932261 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:0243    Leaving emm_proc_authentication_ksi() (rc=0)
001074 00199:932266 7F820083C700 TRACE NAS-EM src/nas/emm/nas_emm_procedures.c:0614    UE 1 Delete AUTH INFO procedure
001075 00199:932297 7F81FB7FE700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0296    Successfully sent 62 bytes on stream 1
001076 00199:932323 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:1460    Ts6a_auth_info stopped UE 1
001077 00199:932332 7F820083C700 TRACE NAS-EM src/nas/emm/nas_emm_procedures.c:0684    UE 1 Delete CN procedure 0x7f8168002120
001078 00199:932341 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:0525    Leaving _auth_info_proc_success_cb() (rc=0)
001079 00199:932350 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_cn.c:0116    Leaving _emm_cn_authentication_res() (rc=0)
001080 00199:932359 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_cn.c:0438    Leaving emm_cn_send() (rc=0)
001081 00199:932368 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0352    Leaving nas_proc_auth_param_res() (rc=0)
001082 00199:932376 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0329    Leaving nas_proc_authentication_info_answer() (rc=0)
001083 00200:077398 7F81A17FA700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0547    [1][48] Msg of length 65 received from port 36412, on stream 1, PPID 18
001084 00200:077429 7F81A17FA700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0554    SCTP RETURNING!!
001085 00200:077477 7F81F9FFB700 INFO  S1AP   c/s1ap/s1ap_mme_nas_procedures.c:0295    Received S1AP UPLINK_NAS_TRANSPORT message MME_UE_S1AP_ID 1
001086 00200:077643 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0250    Entering nas_proc_ul_transfer_ind()
001087 00200:077655 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
001088 00200:077661 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0190    Entering emm_as_send()
001089 00200:077666 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0197    EMMAS-SAP - Received primitive EMMAS_DATA_IND (211)
001090 00200:077671 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0557    Entering _emm_as_data_ind()
001091 00200:077676 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0565    EMMAS-SAP - Received AS data transfer indication (ue_id=1, delivered=true, length=17)
001092 00200:077683 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001093 00200:077688 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0260    Entering nas_message_decrypt()
001094 00200:077696 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0694    Entering nas_message_header_decode()
001095 00200:077704 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0751    Leaving nas_message_header_decode() (rc=6)
001096 00200:077711 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1392    Entering _nas_message_get_mac()
001097 00200:077716 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:1397    No security context set for integrity protection algorithm
001098 00200:077724 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1398    Leaving _nas_message_get_mac() (rc=0)
001099 00200:077732 7F820083C700 CRITI NAS    rc/nas/api/network/nas_message.c:0311    MAC Failure MSG:7AFF8449(2063565897) <> INT ALGO:00000000(0) Type of security context 0
001100 00200:077742 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1049    Entering _nas_message_decrypt()
001101 00200:077749 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:1066    No decryption of message length 11 according to security header type 0x01
001102 00200:077757 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1069    Leaving _nas_message_decrypt() (rc=7)
001103 00200:077765 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0335    Leaving nas_message_decrypt() (rc=11)
001104 00200:077774 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0269    Entering _emm_as_recv()
001105 00200:077781 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0285    EMMAS-SAP - Received EMM message (length=11) integrity protected 1 ciphered 0 mac matched 0 security context 0
001106 00200:077790 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001107 00200:077799 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0360    Entering nas_message_decode()
001108 00200:077806 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:0374    hex stream Incoming NAS message:  07 53 08 06 3c b8 c1 68 93 3a 60
001109 00200:077858 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0694    Entering nas_message_header_decode()
001110 00200:077869 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0751    Leaving nas_message_header_decode() (rc=1)
001111 00200:077879 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:0386    nas_message_header_decode returned size 1
001112 00200:077891 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0776    Entering _nas_message_plain_decode()
001113 00200:077901 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0101    Entering emm_msg_decode()
001114 00200:077912 7F820083C700 DEBUG NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0121    EMM-MSG   - Message Type 0x53
001115 00200:077923 7F820083C700 TRACE NAS    /src/common/3gpp_24.008_mm_ies.c:0177    Entering decode_authentication_response_parameter_ie()
001116 00200:077935 7F820083C700 TRACE NAS    /src/common/3gpp_24.008_mm_ies.c:0202    Leaving decode_authentication_response_parameter_ie() (rc=9)
001117 00200:077946 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0274    Leaving emm_msg_decode() (rc=11)
001118 00200:077957 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0799    Leaving _nas_message_plain_decode() (rc=11)
001119 00200:077968 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0539    Leaving nas_message_decode() (rc=11)
001120 00200:077979 7F820083C700 NOTIC NAS    air-mme/src/nas/emm/sap/emm_as.c:0366    Hit 3GPP TS 24_301R10_4_4_4_3__1 : Integrity checking of NAS signalling messages exception in the MME
001121 00200:077989 7F820083C700 NOTIC NAS    air-mme/src/nas/emm/sap/emm_as.c:0369    Hit 3GPP TS 24_301R10_4_4_4_3__2 : Process NAS signalling message in the MME, even if it fails the integrity check or MAC cannot be verified
001122 00200:078000 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/sap/emm_recv.c:1020    Entering emm_recv_authentication_response()
001123 00200:078010 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/sap/emm_recv.c:1024    EMMAS-SAP - Received Authentication Response message
001124 00200:078021 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:0821    Entering emm_proc_authentication_complete()
001125 00200:078054 7F820083C700 INFO  NAS-EM mme/src/nas/emm/Authentication.c:0826    EMM-PROC  - Authentication complete (ue_id=1)
001126 00200:078065 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001127 00200:078076 7F820083C700 INFO  NAS-EM mme/src/nas/emm/Authentication.c:0840    EMM-PROC  - Authentication complete (ue_id=1, cause=-1)
001128 00200:078087 7F820083C700 NOTIC NAS    mme/src/nas/emm/Authentication.c:0846    Hit 3GPP TS 24_301R10_5_4_2_4__1 : AUTHENTICATION RESPONSE received, stop T3460, check RES
001129 00200:078105 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:1433    T3460 stopped UE 1
001130 00200:078120 7F820083C700 NOTIC NAS    mme/src/nas/emm/Authentication.c:0854    Hit 3GPP TS 24_301R10_5_4_2_4__2 : authentication procedure is success, new eKSI for new authentication procedure
001131 00200:078130 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0377    ue_id=1 set security context eksi 2
001132 00200:078141 7F820083C700 DEBUG NAS-EM mme/src/nas/emm/Authentication.c:0858    EMM-PROC  - Success to authentify the UE  RESP XRES == XRES UE CONTEXT
001133 00200:078152 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
001134 00200:078162 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_reg.c:0104    Entering emm_reg_send()
001135 00200:078180 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0274    Entering emm_fsm_process()
001136 00200:078190 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001137 00200:078200 7F820083C700 INFO  NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0282    EMM-FSM   - Received event COMMON_PROC_CNF (2) in state EMM-COMMON-PROCEDURE-INITIATED
001138 00200:078211 7F820083C700 TRACE NAS-EM ap/EmmCommonProcedureInitiated.c:0093    Entering EmmCommonProcedureInitiated()
001139 00200:078221 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001140 00200:078232 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0176    Entering emm_fsm_set_state()
001141 00200:078241 7F820083C700 INFO  NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0185    UE 1 EMM-FSM   - Status changed: EMM-COMMON-PROCEDURE-INITIATED ===> EMM-DEREGISTERED
001142 00200:078252 7F820083C700 TRACE MME-AP me/src/mme_app/mme_app_context.c:2251    Entering mme_ue_context_update_ue_emm_state()
001143 00200:078263 7F820083C700 TRACE MME-AP me/src/mme_app/mme_app_context.c:2276    Leaving mme_ue_context_update_ue_emm_state()
001144 00200:078281 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0213    Leaving emm_fsm_set_state() (rc=0)
001145 00200:078292 7F820083C700 TRACE NAS-EM openair-mme/src/nas/emm/Attach.c:1672    Entering _emm_attach_success_authentication_cb()
001146 00200:078303 7F820083C700 NOTIC NAS    openair-mme/src/nas/emm/Attach.c:1686    Hit 3GPP TS 24_301R10_5_5_1_2_3__1 : EMM common procedure initiation during attach procedure
001147 00200:078322 7F820083C700 TRACE NAS-EM openair-mme/src/nas/emm/Attach.c:1722    Entering _emm_start_attach_proc_security()
001148 00200:078332 7F820083C700 NOTIC NAS    openair-mme/src/nas/emm/Attach.c:1726    Hit 3GPP TS 24_301R10_5_5_1_2_3__1 : EMM common procedure initiation during attach procedure
001149 00200:078343 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0368    ue_id=1 set security context security type 0
001150 00200:078360 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0377    ue_id=1 set security context eksi 7
001151 00200:078370 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0358    ue_id=1 cleared security context
001152 00200:078381 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0377    ue_id=1 set security context eksi 2
001153 00200:078421 7F820083C700 TRACE NAS-EM rc/nas/emm/SecurityModeControl.c:0165    Entering emm_proc_security_mode_control()
001154 00200:078434 7F820083C700 INFO  NAS-EM rc/nas/emm/SecurityModeControl.c:0177    EMM-PROC  - Initiate security mode control procedure KSI = 2
001155 00200:078447 7F820083C700 TRACE NAS-EM src/nas/emm/nas_emm_procedures.c:0972    New EMM_COMM_PROC_SMC
001156 00200:078457 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0377    ue_id=1 set security context eksi 2
001157 00200:078467 7F820083C700 NOTIC NAS    rc/nas/emm/SecurityModeControl.c:0216    Hit 3GPP TS 24_301R10_5_4_3_2__2 : SMC initiation, reset DL NAS count, use SC
001158 00200:078476 7F820083C700 TRACE NAS-EM rc/nas/emm/SecurityModeControl.c:0858    Entering _security_select_algorithms()
001159 00200:078486 7F820083C700 DEBUG NAS-EM rc/nas/emm/SecurityModeControl.c:0872    Selected  NAS_SECURITY_ALGORITHMS_EIA2 (choice num 0)
001160 00200:078496 7F820083C700 DEBUG NAS-EM rc/nas/emm/SecurityModeControl.c:0886    Selected  NAS_SECURITY_ALGORITHMS_EEA0 (choice num 0)
001161 00200:078506 7F820083C700 TRACE NAS-EM rc/nas/emm/SecurityModeControl.c:0892    Leaving _security_select_algorithms() (rc=0)
001162 00200:078517 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0368    ue_id=1 set security context security type 2
001163 00200:078561 7F820083C700 INFO  NAS-EM rc/nas/emm/SecurityModeControl.c:0322    EMM-PROC  - SMC gprs_present 1 gea bits 70
001164 00200:078574 7F820083C700 TRACE NAS-EM rc/nas/emm/SecurityModeControl.c:0690    Entering _security_request()
001165 00200:078584 7F820083C700 NOTIC NAS    rc/nas/emm/SecurityModeControl.c:0700    Hit 3GPP TS 24_301R10_5_4_3_2__14 : SMC initiation, include replayed security capabilities, eKSI, algos
001166 00200:078595 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001167 00200:078606 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/LowerLayer.c:0670    Entering emm_as_set_security_data()
001168 00200:078616 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/LowerLayer.c:0688    EPS security context exists is new 1 KSI 2 SQN 0 count 0
001169 00200:078627 7F820083C700 DEBUG NAS-EM air-mme/src/nas/emm/LowerLayer.c:0690    hex stream knas_int: 3d 40 c1 8e 32 36 d6 3a a0 21 09 07 3a dd 31 2f
001170 00200:078655 7F820083C700 DEBUG NAS-EM air-mme/src/nas/emm/LowerLayer.c:0692    hex stream knas_enc: 63 ea 72 08 d9 f2 18 14 72 e7 bc 9d cd e2 23 4c
001171 00200:078689 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/LowerLayer.c:0734    Leaving emm_as_set_security_data()
001172 00200:078700 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
001173 00200:078711 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0190    Entering emm_as_send()
001174 00200:078721 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0197    EMMAS-SAP - Received primitive EMMAS_SECURITY_REQ (201)
001175 00200:078732 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1095    Entering _emm_as_send()
001176 00200:078744 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1599    Entering _emm_as_security_req()
001177 00200:078754 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1602    EMMAS-SAP - Send AS security request
001178 00200:078765 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0903    Entering _emm_as_set_header()
001179 00200:078775 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0929    Leaving _emm_as_set_header() (rc=140196331095536)
001180 00200:078786 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/sap/emm_send.c:1074    Entering emm_send_security_mode_command()
001181 00200:078796 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/sap/emm_send.c:1077    EMMAS-SAP - Send Security Mode Command message
001182 00200:078806 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/sap/emm_send.c:1114    imeisvrequest                               1
001183 00200:078816 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/sap/emm_send.c:1117    replayeduesecuritycapabilities.gprs_present 1
001184 00200:078826 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/sap/emm_send.c:1119    replayeduesecuritycapabilities.gea          112
001185 00200:078836 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/sap/emm_send.c:1121    Leaving emm_send_security_mode_command() (rc=13)
001186 00200:078847 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001187 00200:078858 7F820083C700 DEBUG NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1689    Set nas_msg.header.sequence_number -> 0
001188 00200:078868 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0987    Entering _emm_as_encode()
001189 00200:078879 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0561    Entering nas_message_encode()
001190 00200:078889 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0877    Entering _nas_message_header_encode()
001191 00200:078899 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0913    Leaving _nas_message_header_encode() (rc=6)
001192 00200:078926 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0987    Entering _nas_message_protected_encode()
001193 00200:078937 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0938    Entering _nas_message_plain_encode()
001194 00200:078948 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0295    Entering emm_msg_encode()
001195 00200:078961 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0465    Leaving emm_msg_encode() (rc=11)
001196 00200:078972 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0963    Leaving _nas_message_plain_encode() (rc=11)
001197 00200:078983 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1241    Entering _nas_message_encrypt()
001198 00200:078993 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:1258    No encryption of message according to security header type 0x03
001199 00200:079004 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1260    Leaving _nas_message_encrypt() (rc=11)
001200 00200:079015 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1016    Leaving _nas_message_protected_encode() (rc=11)
001201 00200:079026 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:0596    offset 5 = 6 - 1, hdr encode = 6, length = 19 bytes = 11
001202 00200:079038 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1392    Entering _nas_message_get_mac()
001203 00200:079049 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:1469    NAS_SECURITY_ALGORITHMS_EIA2 dir DOWNLINK count.seq_num 0 count 0
001204 00200:079076 7F820083C700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0076    Byte length: 20, Zero bits: 0:
001205 00200:079098 7F820083C700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0077    hex stream m: 00 00 00 00 04 00 00 00 00 07 5d 02 02 05 f0 70 c0 40 70 c1
001206 00200:079130 7F820083C700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0079    hex stream Key: 3d 40 c1 8e 32 36 d6 3a a0 21 09 07 3a dd 31 2f
001207 00200:079156 7F820083C700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0081    hex stream Message: 00 07 5d 02 02 05 f0 70 c0 40 70 c1
001208 00200:079240 7F820083C700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0089    hex stream Out: fd f2 c3 eb 1f cc a9 47 e1 2c ad 27 8f f8 8d 9b
001209 00200:079277 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:1485    NAS_SECURITY_ALGORITHMS_EIA2 returned MAC fd.f2.c3.eb(3955487485) for length 12 direction 1, count 0
001210 00200:079292 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1487    Leaving _nas_message_get_mac() (rc=4260545515)
001211 00200:079302 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:0627    Incremented emm_security_context.dl_count.seq_num -> 1
001212 00200:079312 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0653    Leaving nas_message_encode() (rc=17)
001213 00200:079323 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1023    Leaving _emm_as_encode() (rc=17)
001214 00200:079334 7F820083C700 TRACE NAS-ES ir-mme/src/nas/emm/msg/emm_msg.c:0483    Entering emm_msg_free()
001215 00200:079344 7F820083C700 DEBUG NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0493    EMM-MSG   - Message Type 0x5d
001216 00200:079354 7F820083C700 TRACE NAS-ES ir-mme/src/nas/emm/msg/emm_msg.c:0592    Leaving emm_msg_free()
001217 00200:079365 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001218 00200:079376 7F820083C700 TRACE NAS-EM src/nas/emm/nas_emm_procedures.c:1059    Found emm_common_proc UID 0x6
001219 00200:079401 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1704    Leaving _emm_as_security_req() (rc=263)
001220 00200:079412 7F820083C700 DEBUG NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1229    EMMAS-SAP - Sending msg with id 0x107, primitive EMMAS_SECURITY_REQ (201) to S1AP layer for transmission
001221 00200:079439 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1236    Leaving _emm_as_send() (rc=0)
001222 00200:079455 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0234    Leaving emm_as_send() (rc=0)
001224 00200:079466 7F820083C700 NOTIC NAS    rc/nas/emm/SecurityModeControl.c:0740    Hit 3GPP TS 24_301R10_5_4_3_2__1 : SMC initiation, start T3460
001223 00200:079463 7F81F9704700 TRACE MME-AP /src/mme_app/mme_app_transport.c:0051    Entering mme_app_handle_nas_dl_req()
001226 00200:079488 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:1321    T3460 started UE 1
001225 00200:079487 7F81F9704700 DEBUG MME-AP /src/mme_app/mme_app_transport.c:0064    DOWNLINK NAS TRANSPORT Found enb_ue_s1ap_id 06692d mme_ue_s1ap_id 1
001227 00200:079514 7F820083C700 TRACE NAS-EM rc/nas/emm/SecurityModeControl.c:0752    Leaving _security_request() (rc=0)
001228 00200:079559 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
001229 00200:079562 7F81F9704700 TRACE MME-AP /src/mme_app/mme_app_transport.c:0095     MME_APP:DOWNLINK NAS TRANSPORT. MME_UE_S1AP_ID 1 and ENB_UE_S1AP_ID 06692d.
001230 00200:079571 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_reg.c:0104    Entering emm_reg_send()
001231 00200:079577 7F81F9704700 TRACE MME-AP /src/mme_app/mme_app_transport.c:0189    Leaving mme_app_handle_nas_dl_req() (rc=0)
001232 00200:079582 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0274    Entering emm_fsm_process()
001233 00200:079604 7F81F9FFB700 DEBUG S1AP   c/s1ap/s1ap_mme_nas_procedures.c:0452    SEARCHING UE REFERENCE for SCTP association id 1,  enbUeS1apId 06692d and enbId 3584.
001234 00200:079607 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001235 00200:079653 7F820083C700 INFO  NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0282    EMM-FSM   - Received event COMMON_PROC_REQ (1) in state EMM-DEREGISTERED
001236 00200:079667 7F820083C700 TRACE NAS-EM rc/nas/emm/sap/EmmDeregistered.c:0097    Entering EmmDeregistered()
001237 00200:079675 7F81F9FFB700 NOTIC S1AP   c/s1ap/s1ap_mme_nas_procedures.c:0543    Send S1AP DOWNLINK_NAS_TRANSPORT message ue_id = 1 MME_UE_S1AP_ID = 1 eNB_UE_S1AP_ID = 06692d
001238 00200:079679 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001239 00200:079733 7F81FB7FE700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0283    [48][1] Sending buffer 0x7f8168002200 of 43 bytes on stream 1 with ppid 18
001240 00200:079738 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0176    Entering emm_fsm_set_state()
001241 00200:079785 7F820083C700 INFO  NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0185    UE 1 EMM-FSM   - Status changed: EMM-DEREGISTERED ===> EMM-COMMON-PROCEDURE-INITIATED
001242 00200:079798 7F820083C700 TRACE MME-AP me/src/mme_app/mme_app_context.c:2251    Entering mme_ue_context_update_ue_emm_state()
001243 00200:079809 7F820083C700 TRACE MME-AP me/src/mme_app/mme_app_context.c:2276    Leaving mme_ue_context_update_ue_emm_state()
001244 00200:079820 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0213    Leaving emm_fsm_set_state() (rc=0)
001245 00200:079831 7F820083C700 TRACE NAS-EM rc/nas/emm/sap/EmmDeregistered.c:0424    Leaving EmmDeregistered() (rc=0)
001246 00200:079834 7F81FB7FE700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0296    Successfully sent 43 bytes on stream 1
001247 00200:079843 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0293    Leaving emm_fsm_process() (rc=0)
001248 00200:079868 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_reg.c:0117    Leaving emm_reg_send() (rc=0)
001249 00200:079885 7F820083C700 TRACE NAS-EM rc/nas/emm/SecurityModeControl.c:0363    Leaving emm_proc_security_mode_control() (rc=0)
001250 00200:079896 7F820083C700 TRACE NAS-EM openair-mme/src/nas/emm/Attach.c:1761    Leaving _emm_start_attach_proc_security() (rc=0)
001251 00200:079907 7F820083C700 TRACE NAS-EM openair-mme/src/nas/emm/Attach.c:1689    Leaving _emm_attach_success_authentication_cb() (rc=0)
001252 00200:079918 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001253 00200:079929 7F820083C700 TRACE NAS-EM src/nas/emm/nas_emm_procedures.c:0393    UE 1 Delete AUTH procedure
001254 00200:079940 7F820083C700 TRACE NAS-EM ap/EmmCommonProcedureInitiated.c:0577    Leaving EmmCommonProcedureInitiated() (rc=0)
001255 00200:079951 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0293    Leaving emm_fsm_process() (rc=0)
001256 00200:079962 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_reg.c:0117    Leaving emm_reg_send() (rc=0)
001257 00200:079973 7F820083C700 TRACE NAS-EM mme/src/nas/emm/Authentication.c:0873    Leaving emm_proc_authentication_complete() (rc=0)
001258 00200:079994 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/sap/emm_recv.c:1054    Leaving emm_recv_authentication_response() (rc=0)
001259 00200:080007 7F820083C700 TRACE NAS-ES ir-mme/src/nas/emm/msg/emm_msg.c:0483    Entering emm_msg_free()
001260 00200:080018 7F820083C700 DEBUG NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0493    EMM-MSG   - Message Type 0x53
001261 00200:080029 7F820083C700 TRACE NAS-ES ir-mme/src/nas/emm/msg/emm_msg.c:0592    Leaving emm_msg_free()
001262 00200:080040 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0536    Leaving _emm_as_recv() (rc=0)
001263 00200:080051 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0673    Leaving _emm_as_data_ind() (rc=0)
001264 00200:080062 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0234    Leaving emm_as_send() (rc=0)
001265 00200:080073 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0270    Leaving nas_proc_ul_transfer_ind() (rc=0)
001266 00200:104394 7F81A17FA700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0547    [1][48] Msg of length 67 received from port 36412, on stream 1, PPID 18
001267 00200:104426 7F81A17FA700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0554    SCTP RETURNING!!
001268 00200:104515 7F81F9FFB700 INFO  S1AP   c/s1ap/s1ap_mme_nas_procedures.c:0295    Received S1AP UPLINK_NAS_TRANSPORT message MME_UE_S1AP_ID 1
001269 00200:104729 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0250    Entering nas_proc_ul_transfer_ind()
001270 00200:104749 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
001271 00200:104758 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0190    Entering emm_as_send()
001272 00200:104764 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0197    EMMAS-SAP - Received primitive EMMAS_DATA_IND (211)
001273 00200:104771 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0557    Entering _emm_as_data_ind()
001274 00200:104779 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0565    EMMAS-SAP - Received AS data transfer indication (ue_id=1, delivered=true, length=19)
001275 00200:104791 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001276 00200:104807 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0260    Entering nas_message_decrypt()
001277 00200:104817 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0694    Entering nas_message_header_decode()
001278 00200:104828 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0751    Leaving nas_message_header_decode() (rc=6)
001279 00200:104839 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1392    Entering _nas_message_get_mac()
001280 00200:104849 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:1469    NAS_SECURITY_ALGORITHMS_EIA2 dir UPLINK count.seq_num 0 count 0
001281 00200:104861 7F820083C700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0076    Byte length: 22, Zero bits: 0:
001282 00200:104873 7F820083C700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0077    hex stream m: 00 00 00 00 00 00 00 00 00 07 5e 23 09 33 35 33 09 46 96 46 17 f0
001283 00200:104913 7F820083C700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0079    hex stream Key: 3d 40 c1 8e 32 36 d6 3a a0 21 09 07 3a dd 31 2f
001284 00200:104940 7F820083C700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0081    hex stream Message: 00 07 5e 23 09 33 35 33 09 46 96 46 17 f0
001285 00200:104978 7F820083C700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0089    hex stream Out: af 82 fb 80 1d 4b 63 05 1f d1 28 59 0c c9 5a 95
001286 00200:105007 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:1485    NAS_SECURITY_ALGORITHMS_EIA2 returned MAC af.82.fb.80(2163966639) for length 14 direction 0, count 0
001287 00200:105022 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1487    Leaving _nas_message_get_mac() (rc=2944596864)
001288 00200:105033 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:0303    Integrity: MAC Success
001289 00200:105044 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1049    Entering _nas_message_decrypt()
001290 00200:105054 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:1175    NAS_SECURITY_ALGORITHMS_EEA0 dir 0 ul_count.seq_num 0 dl_count.seq_num 1
001291 00200:105065 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1183    Leaving _nas_message_decrypt() (rc=7)
001292 00200:105076 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0335    Leaving nas_message_decrypt() (rc=13)
001293 00200:105087 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0269    Entering _emm_as_recv()
001294 00200:105097 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0285    EMMAS-SAP - Received EMM message (length=13) integrity protected 1 ciphered 1 mac matched 1 security context 1
001295 00200:105110 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001296 00200:105121 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0360    Entering nas_message_decode()
001297 00200:105130 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:0374    hex stream Incoming NAS message:  07 5e 23 09 33 35 33 09 46 96 46 17 f0
001298 00200:105165 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0694    Entering nas_message_header_decode()
001299 00200:105175 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0751    Leaving nas_message_header_decode() (rc=1)
001300 00200:105186 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:0386    nas_message_header_decode returned size 1
001301 00200:105196 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0776    Entering _nas_message_plain_decode()
001302 00200:105206 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0101    Entering emm_msg_decode()
001303 00200:105217 7F820083C700 DEBUG NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0121    EMM-MSG   - Message Type 0x5e
001304 00200:105229 7F820083C700 TRACE NAS-EM /common/3gpp_24.008_common_ies.c:0421    Entering decode_imeisv_mobile_identity()
001305 00200:105240 7F820083C700 TRACE NAS-EM /common/3gpp_24.008_common_ies.c:0471    Leaving decode_imeisv_mobile_identity() (rc=9)
001306 00200:105251 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0274    Leaving emm_msg_decode() (rc=13)
001307 00200:105262 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0799    Leaving _nas_message_plain_decode() (rc=13)
001308 00200:105273 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0539    Leaving nas_message_decode() (rc=13)
001309 00200:105284 7F820083C700 NOTIC NAS    air-mme/src/nas/emm/sap/emm_as.c:0387    Hit 3GPP TS 24_301R10_4_4_4_3__1 : Integrity checking of NAS signalling messages exception in the MME
001310 00200:105294 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/sap/emm_recv.c:1134    Entering emm_recv_security_mode_complete()
001311 00200:105305 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/sap/emm_recv.c:1138    EMMAS-SAP - Received Security Mode Complete message
001312 00200:105315 7F820083C700 TRACE NAS-EM rc/nas/emm/SecurityModeControl.c:0390    Entering emm_proc_security_mode_complete()
001313 00200:105325 7F820083C700 INFO  NAS-EM rc/nas/emm/SecurityModeControl.c:0398    EMM-PROC  - Security mode complete (ue_id=1)
001314 00200:105336 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001315 00200:105347 7F820083C700 NOTIC NAS    rc/nas/emm/SecurityModeControl.c:0414    Hit 3GPP TS 24_301R10_5_4_3_4__1 : SMC completion, stop T3460,
001316 00200:105363 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:1433    T3460 stopped UE 1
001317 00200:105391 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0266    ue_id=1 set IMEI_SV (valid)
001318 00200:105403 7F820083C700 NOTIC NAS    rc/nas/emm/SecurityModeControl.c:0464    Hit 3GPP TS 24_301R10_5_4_3_4__2 : SMC completion, integ. cipher. all messages
001319 00200:105414 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
001320 00200:105425 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_reg.c:0104    Entering emm_reg_send()
001321 00200:105435 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0274    Entering emm_fsm_process()
001322 00200:105446 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001323 00200:105456 7F820083C700 INFO  NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0282    EMM-FSM   - Received event COMMON_PROC_CNF (2) in state EMM-COMMON-PROCEDURE-INITIATED
001324 00200:105468 7F820083C700 TRACE NAS-EM ap/EmmCommonProcedureInitiated.c:0093    Entering EmmCommonProcedureInitiated()
001325 00200:105478 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001326 00200:105489 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0176    Entering emm_fsm_set_state()
001327 00200:105499 7F820083C700 INFO  NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0185    UE 1 EMM-FSM   - Status changed: EMM-COMMON-PROCEDURE-INITIATED ===> EMM-DEREGISTERED
001328 00200:105511 7F820083C700 TRACE MME-AP me/src/mme_app/mme_app_context.c:2251    Entering mme_ue_context_update_ue_emm_state()
001329 00200:105523 7F820083C700 TRACE MME-AP me/src/mme_app/mme_app_context.c:2276    Leaving mme_ue_context_update_ue_emm_state()
001330 00200:105533 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0213    Leaving emm_fsm_set_state() (rc=0)
001331 00200:105544 7F820083C700 TRACE NAS-EM openair-mme/src/nas/emm/Attach.c:1767    Entering _emm_attach_success_security_cb()
001332 00200:105572 7F820083C700 TRACE NAS-EM openair-mme/src/nas/emm/Attach.c:1779    Leaving _emm_attach_success_security_cb() (rc=0)
001333 00200:105582 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001334 00200:105594 7F820083C700 TRACE NAS-EM src/nas/emm/nas_emm_procedures.c:0400    Delete SMC procedure 6
001335 00200:105604 7F820083C700 TRACE NAS-EM ap/EmmCommonProcedureInitiated.c:0577    Leaving EmmCommonProcedureInitiated() (rc=0)
001336 00200:105615 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0293    Leaving emm_fsm_process() (rc=0)
001337 00200:105625 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_reg.c:0117    Leaving emm_reg_send() (rc=0)
001338 00200:105634 7F820083C700 TRACE NAS-EM rc/nas/emm/SecurityModeControl.c:0469    Leaving emm_proc_security_mode_complete() (rc=0)
001339 00200:105645 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/sap/emm_recv.c:1150    Leaving emm_recv_security_mode_complete() (rc=0)
001341 00200:105656 7F820083C700 TRACE NAS-ES ir-mme/src/nas/emm/msg/emm_msg.c:0483    Entering emm_msg_free()
001340 00200:105652 7F81FBFFF700 TRACE NAS-ES r-mme/src/nas/esm/nas_esm_proc.c:0159    Entering nas_esm_proc_data_ind()
001342 00200:105666 7F820083C700 DEBUG NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0493    EMM-MSG   - Message Type 0x5e
001343 00200:105680 7F820083C700 TRACE NAS-ES ir-mme/src/nas/emm/msg/emm_msg.c:0592    Leaving emm_msg_free()
001344 00200:105683 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/sap/esm_sap.c:0573    Entering _esm_sap_recv()
001345 00200:105690 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0536    Leaving _emm_as_recv() (rc=0)
001346 00200:105701 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0117    Entering esm_msg_decode()
001347 00200:105702 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0673    Leaving _emm_as_data_ind() (rc=0)
001348 00200:105738 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0261    Leaving esm_msg_decode() (rc=39)
001349 00200:105756 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0234    Leaving emm_as_send() (rc=0)
001350 00200:105764 7F81FBFFF700 DEBUG NAS-ES ir-mme/src/nas/esm/sap/esm_sap.c:0661    ESM-SAP   - PDN_CONNECTIVITY_REQUEST pti 45 ebi 0
001351 00200:105769 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0270    Leaving nas_proc_ul_transfer_ind() (rc=0)
001352 00200:105787 7F81FBFFF700 TRACE NAS-ES r-mme/src/nas/esm/sap/esm_recv.c:0156    Entering esm_recv_pdn_connectivity_request()
001353 00200:105807 7F81FBFFF700 INFO  NAS-ES r-mme/src/nas/esm/sap/esm_recv.c:0163    ESM-SAP   - Received PDN Connectivity Request message (ue_id=1, pti=45, ebi=0)
001354 00200:105826 7F81FBFFF700 TRACE MME-AP mme_app/mme_app_esm_procedures.c:0216    Entering mme_app_nas_esm_get_pdn_connectivity_procedure()
001355 00200:105842 7F81FBFFF700 TRACE MME-AP mme_app/mme_app_esm_procedures.c:0238    Leaving mme_app_nas_esm_get_pdn_connectivity_procedure() (rc=0)
001356 00200:105854 7F81FBFFF700 TRACE MME-AP mme_app/mme_app_esm_procedures.c:0300    Entering mme_app_nas_esm_get_bearer_context_procedure()
001357 00200:105865 7F81FBFFF700 TRACE MME-AP mme_app/mme_app_esm_procedures.c:0325    Leaving mme_app_nas_esm_get_bearer_context_procedure() (rc=0)
001358 00200:105876 7F81FBFFF700 TRACE MME-AP /mme_app/mme_app_apn_selection.c:0051    Entering mme_app_select_apn()
001359 00200:105892 7F81FBFFF700 INFO  MME-AP /mme_app/mme_app_apn_selection.c:0061    No subscription data is received for IMSI 208950000000004.
001360 00200:105907 7F81FBFFF700 TRACE MME-AP /mme_app/mme_app_apn_selection.c:0062    Leaving mme_app_select_apn() (rc=0)
001361 00200:105918 7F81FBFFF700 DEBUG NAS-ES r-mme/src/nas/esm/sap/esm_recv.c:0345    ESM-SAP   - No ESM procedure for UE 1 exists. Proceeding with handling the new ESM request (pti=45) for PDN connectivity.
001362 00200:105929 7F81FBFFF700 TRACE MME-AP mme_app/mme_app_esm_procedures.c:0081    Entering mme_app_nas_esm_create_pdn_connectivity_procedure()
001363 00200:105940 7F81FBFFF700 TRACE MME-AP mme_app/mme_app_esm_procedures.c:0130    Leaving mme_app_nas_esm_create_pdn_connectivity_procedure() (rc=140193571016096)
001364 00200:105947 7F81FBFFF700 TRACE NAS-ES me/src/nas/esm/esm_information.c:0105    Entering esm_proc_esm_information_request()
001365 00200:105955 7F81FBFFF700 TRACE NAS-ES me/src/nas/esm/esm_information.c:0082    Entering esm_send_esm_information_request()
001366 00200:105965 7F81FBFFF700 NOTIC NAS-ES me/src/nas/esm/esm_information.c:0097    ESM-SAP   - Send ESM_INFORMATION_REQUEST message (pti=45, ebi=0)
001367 00200:105976 7F81FBFFF700 TRACE NAS-ES me/src/nas/esm/esm_information.c:0098    Leaving esm_send_esm_information_request()
001368 00200:105987 7F81FBFFF700 INFO  NAS-EM r-mme/src/nas/esm/nas_esm_proc.c:0084    ESM_TIMER stopped UE 1
001369 00200:106007 7F81FBFFF700 TRACE NAS-ES me/src/nas/esm/esm_information.c:0127    Leaving esm_proc_esm_information_request()
001370 00200:106028 7F81FBFFF700 TRACE NAS-ES r-mme/src/nas/esm/sap/esm_recv.c:0379    Leaving esm_recv_pdn_connectivity_request() (rc=-1)
001371 00200:106041 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0282    Entering esm_msg_encode()
001372 00200:106050 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0301    ESM-MSG   - Encoded ESM message header (3)
001373 00200:106062 7F81FBFFF700 TRACE NAS-ES /esm/msg/EsmInformationRequest.c:0052    Entering encode_esm_information_request()
001374 00200:106072 7F81FBFFF700 TRACE NAS-ES /esm/msg/EsmInformationRequest.c:0060    Leaving encode_esm_information_request() (rc=0)
001375 00200:106082 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0429    Leaving esm_msg_encode() (rc=3)
001376 00200:106093 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0447    Entering esm_msg_free()
001377 00200:106104 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0592    Leaving esm_msg_free()
001378 00200:106113 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0447    Entering esm_msg_free()
001379 00200:106123 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0592    Leaving esm_msg_free()
001380 00200:106133 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/sap/esm_sap.c:0949    Leaving _esm_sap_recv()
001381 00200:106143 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/LowerLayer.c:0335    Entering lowerlayer_data_req()
001382 00200:106154 7F81FBFFF700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001383 00200:106166 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/LowerLayer.c:0670    Entering emm_as_set_security_data()
001384 00200:106175 7F81FBFFF700 INFO  NAS-EM air-mme/src/nas/emm/LowerLayer.c:0688    EPS security context exists is new 0 KSI 2 SQN 0 count 0
001385 00200:106186 7F81FBFFF700 DEBUG NAS-EM air-mme/src/nas/emm/LowerLayer.c:0690    hex stream knas_int: 3d 40 c1 8e 32 36 d6 3a a0 21 09 07 3a dd 31 2f
001386 00200:106216 7F81FBFFF700 DEBUG NAS-EM air-mme/src/nas/emm/LowerLayer.c:0692    hex stream knas_enc: 63 ea 72 08 d9 f2 18 14 72 e7 bc 9d cd e2 23 4c
001387 00200:106237 7F81FBFFF700 DEBUG NAS-EM air-mme/src/nas/emm/LowerLayer.c:0722    EPS security context exists knas_enc
001388 00200:106247 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/LowerLayer.c:0734    Leaving emm_as_set_security_data()
001389 00200:106257 7F81FBFFF700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
001390 00200:106267 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0190    Entering emm_as_send()
001391 00200:106277 7F81FBFFF700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0197    EMMAS-SAP - Received primitive EMMAS_DATA_REQ (210)
001392 00200:106288 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1095    Entering _emm_as_send()
001393 00200:106297 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1339    Entering _emm_as_data_req()
001394 00200:106306 7F81FBFFF700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1343    EMMAS-SAP - Send AS data transfer request
001395 00200:106317 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0903    Entering _emm_as_set_header()
001396 00200:106327 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0946    Leaving _emm_as_set_header() (rc=140196255358624)
001397 00200:106337 7F81FBFFF700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001398 00200:106348 7F81FBFFF700 DEBUG NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1407    Set nas_msg.header.sequence_number -> 1
001399 00200:106358 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1046    Entering _emm_as_encrypt()
001400 00200:106368 7F81FBFFF700 TRACE NAS    rc/nas/api/network/nas_message.c:0138    Entering nas_message_encrypt()
001401 00200:106379 7F81FBFFF700 TRACE NAS    rc/nas/api/network/nas_message.c:0877    Entering _nas_message_header_encode()
001402 00200:106389 7F81FBFFF700 TRACE NAS    rc/nas/api/network/nas_message.c:0913    Leaving _nas_message_header_encode() (rc=6)
001403 00200:106437 7F81FBFFF700 TRACE NAS    rc/nas/api/network/nas_message.c:1241    Entering _nas_message_encrypt()
001404 00200:106449 7F81FBFFF700 DEBUG NAS    rc/nas/api/network/nas_message.c:1341    NAS_SECURITY_ALGORITHMS_EEA0 dir 1 ul_count.seq_num 0 dl_count.seq_num 1
001405 00200:106461 7F81FBFFF700 TRACE NAS    rc/nas/api/network/nas_message.c:1343    Leaving _nas_message_encrypt() (rc=3)
001406 00200:106472 7F81FBFFF700 TRACE NAS    rc/nas/api/network/nas_message.c:1392    Entering _nas_message_get_mac()
001407 00200:106483 7F81FBFFF700 DEBUG NAS    rc/nas/api/network/nas_message.c:1469    NAS_SECURITY_ALGORITHMS_EIA2 dir DOWNLINK count.seq_num 1 count 1
001408 00200:106496 7F81FBFFF700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0076    Byte length: 12, Zero bits: 0:
001409 00200:106506 7F81FBFFF700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0077    hex stream m: 00 00 00 01 04 00 00 00 01 02 2d d9
001410 00200:106538 7F81FBFFF700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0079    hex stream Key: 3d 40 c1 8e 32 36 d6 3a a0 21 09 07 3a dd 31 2f
001411 00200:106570 7F81FBFFF700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0081    hex stream Message: 01 02 2d d9
001412 00200:106595 7F81FBFFF700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0089    hex stream Out: 7a e7 bf 1a d4 96 2d 0b 16 df 4f 98 d4 51 8d 5b
001413 00200:106629 7F81FBFFF700 DEBUG NAS    rc/nas/api/network/nas_message.c:1485    NAS_SECURITY_ALGORITHMS_EIA2 returned MAC 7a.e7.bf.1a(448784250) for length 4 direction 1, count 1
001414 00200:106645 7F81FBFFF700 TRACE NAS    rc/nas/api/network/nas_message.c:1487    Leaving _nas_message_get_mac() (rc=2062008090)
001415 00200:106664 7F81FBFFF700 DEBUG NAS    rc/nas/api/network/nas_message.c:0210    Incremented emm_security_context.dl_count.seq_num -> 2
001416 00200:106675 7F81FBFFF700 TRACE NAS    rc/nas/api/network/nas_message.c:0229    Leaving nas_message_encrypt() (rc=9)
001417 00200:106687 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1075    Leaving _emm_as_encrypt() (rc=9)
001418 00200:106697 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/emm/msg/emm_msg.c:0483    Entering emm_msg_free()
001419 00200:106708 7F81FBFFF700 DEBUG NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0493    EMM-MSG   - Message Type 0x00
001420 00200:106719 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/emm/msg/emm_msg.c:0592    Leaving emm_msg_free()
001421 00200:106731 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1451    Leaving _emm_as_data_req() (rc=263)
001422 00200:106742 7F81FBFFF700 DEBUG NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1229    EMMAS-SAP - Sending msg with id 0x107, primitive EMMAS_DATA_REQ (210) to S1AP layer for transmission
001423 00200:106768 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1236    Leaving _emm_as_send() (rc=0)
001424 00200:106775 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0234    Leaving emm_as_send() (rc=0)
001425 00200:106783 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/LowerLayer.c:0361    Leaving lowerlayer_data_req() (rc=0)
001426 00200:106790 7F81FBFFF700 TRACE NAS-ES r-mme/src/nas/esm/nas_esm_proc.c:0178    Leaving nas_esm_proc_data_ind() (rc=0)
001427 00200:106794 7F81F9704700 TRACE MME-AP /src/mme_app/mme_app_transport.c:0051    Entering mme_app_handle_nas_dl_req()
001428 00200:106817 7F81F9704700 DEBUG MME-AP /src/mme_app/mme_app_transport.c:0064    DOWNLINK NAS TRANSPORT Found enb_ue_s1ap_id 06692d mme_ue_s1ap_id 1
001429 00200:106850 7F81F9704700 TRACE MME-AP /src/mme_app/mme_app_transport.c:0095     MME_APP:DOWNLINK NAS TRANSPORT. MME_UE_S1AP_ID 1 and ENB_UE_S1AP_ID 06692d.
001430 00200:106866 7F81F9704700 TRACE MME-AP /src/mme_app/mme_app_transport.c:0189    Leaving mme_app_handle_nas_dl_req() (rc=0)
001431 00200:106870 7F81F9FFB700 DEBUG S1AP   c/s1ap/s1ap_mme_nas_procedures.c:0452    SEARCHING UE REFERENCE for SCTP association id 1,  enbUeS1apId 06692d and enbId 3584.
001432 00200:106929 7F81F9FFB700 NOTIC S1AP   c/s1ap/s1ap_mme_nas_procedures.c:0543    Send S1AP DOWNLINK_NAS_TRANSPORT message ue_id = 1 MME_UE_S1AP_ID = 1 eNB_UE_S1AP_ID = 06692d
001433 00200:106981 7F81FB7FE700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0283    [48][1] Sending buffer 0x7f81680026f0 of 35 bytes on stream 1 with ppid 18
001434 00200:107078 7F81FB7FE700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0296    Successfully sent 35 bytes on stream 1
001435 00200:127350 7F81A17FA700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0547    [1][48] Msg of length 68 received from port 36412, on stream 1, PPID 18
001436 00200:127384 7F81A17FA700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0554    SCTP RETURNING!!
001437 00200:127432 7F81F9FFB700 INFO  S1AP   c/s1ap/s1ap_mme_nas_procedures.c:0295    Received S1AP UPLINK_NAS_TRANSPORT message MME_UE_S1AP_ID 1
001438 00200:127617 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0250    Entering nas_proc_ul_transfer_ind()
001439 00200:127641 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
001440 00200:127652 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0190    Entering emm_as_send()
001441 00200:127661 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0197    EMMAS-SAP - Received primitive EMMAS_DATA_IND (211)
001442 00200:127671 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0557    Entering _emm_as_data_ind()
001443 00200:127680 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0565    EMMAS-SAP - Received AS data transfer indication (ue_id=1, delivered=true, length=20)
001444 00200:127700 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001445 00200:127712 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0260    Entering nas_message_decrypt()
001446 00200:127722 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0694    Entering nas_message_header_decode()
001447 00200:127733 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0751    Leaving nas_message_header_decode() (rc=6)
001448 00200:127739 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1392    Entering _nas_message_get_mac()
001449 00200:127746 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:1469    NAS_SECURITY_ALGORITHMS_EIA2 dir UPLINK count.seq_num 1 count 1
001450 00200:127758 7F820083C700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0076    Byte length: 23, Zero bits: 0:
001451 00200:127767 7F820083C700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0077    hex stream m: 00 00 00 01 00 00 00 00 01 02 2d da 28 09 03 6f 61 69 04 69 70 76 34
001452 00200:127788 7F820083C700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0079    hex stream Key: 3d 40 c1 8e 32 36 d6 3a a0 21 09 07 3a dd 31 2f
001453 00200:127801 7F820083C700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0081    hex stream Message: 01 02 2d da 28 09 03 6f 61 69 04 69 70 76 34
001454 00200:127819 7F820083C700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0089    hex stream Out: f1 52 b4 e6 e4 86 38 18 20 1d d1 a5 6e 70 55 41
001455 00200:127843 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:1485    NAS_SECURITY_ALGORITHMS_EIA2 returned MAC f1.52.b4.e6(3870577393) for length 15 direction 0, count 1
001456 00200:127856 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1487    Leaving _nas_message_get_mac() (rc=4048729318)
001457 00200:127866 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:0303    Integrity: MAC Success
001458 00200:127874 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1049    Entering _nas_message_decrypt()
001459 00200:127879 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:1175    NAS_SECURITY_ALGORITHMS_EEA0 dir 0 ul_count.seq_num 1 dl_count.seq_num 2
001460 00200:127885 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1183    Leaving _nas_message_decrypt() (rc=2)
001461 00200:127891 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0335    Leaving nas_message_decrypt() (rc=14)
001462 00200:127914 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0673    Leaving _emm_as_data_ind() (rc=0)
001463 00200:127925 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0234    Leaving emm_as_send() (rc=0)
001464 00200:127935 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0270    Leaving nas_proc_ul_transfer_ind() (rc=0)
001465 00200:127938 7F81FBFFF700 TRACE NAS-ES r-mme/src/nas/esm/nas_esm_proc.c:0159    Entering nas_esm_proc_data_ind()
001466 00200:127968 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/sap/esm_sap.c:0573    Entering _esm_sap_recv()
001467 00200:127981 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0117    Entering esm_msg_decode()
001468 00200:127992 7F81FBFFF700 TRACE NAS-ES esm/msg/EsmInformationResponse.c:0036    Entering decode_esm_information_response()
001469 00200:128005 7F81FBFFF700 TRACE NAS-ES esm/msg/EsmInformationResponse.c:0094    Leaving decode_esm_information_response() (rc=11)
001470 00200:128022 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0261    Leaving esm_msg_decode() (rc=14)
001471 00200:128032 7F81FBFFF700 TRACE NAS-ES r-mme/src/nas/esm/sap/esm_recv.c:0519    Entering esm_recv_information_response()
001472 00200:128042 7F81FBFFF700 INFO  NAS-ES r-mme/src/nas/esm/sap/esm_recv.c:0524    ESM-SAP   - Received ESM Information response message (ue_id=1, pti=45, ebi=0)
001473 00200:128054 7F81FBFFF700 TRACE MME-AP mme_app/mme_app_esm_procedures.c:0216    Entering mme_app_nas_esm_get_pdn_connectivity_procedure()
001474 00200:128065 7F81FBFFF700 TRACE MME-AP mme_app/mme_app_esm_procedures.c:0234    Leaving mme_app_nas_esm_get_pdn_connectivity_procedure() (rc=140193571016096)
001475 00200:128075 7F81FBFFF700 TRACE MME-AP mme_app/mme_app_esm_procedures.c:0300    Entering mme_app_nas_esm_get_bearer_context_procedure()
001476 00200:128085 7F81FBFFF700 TRACE MME-AP mme_app/mme_app_esm_procedures.c:0325    Leaving mme_app_nas_esm_get_bearer_context_procedure() (rc=0)
001477 00200:128095 7F81FBFFF700 DEBUG NAS-ES r-mme/src/nas/esm/sap/esm_recv.c:0601    ESM-SAP   - Found a valid ESM procedure for UE 1. Proceeding with handling the new ESM request (pti=45) for PDN connectivity.
001478 00200:128106 7F81FBFFF700 TRACE NAS-ES me/src/nas/esm/esm_information.c:0135    Entering esm_proc_esm_information_response()
001479 00200:128121 7F81FBFFF700 INFO  NAS-EM r-mme/src/nas/esm/nas_esm_proc.c:0084    ESM_TIMER stopped UE 1
001480 00200:128132 7F81FBFFF700 TRACE NAS-ES me/src/nas/esm/esm_information.c:0182    Leaving esm_proc_esm_information_response()
001481 00200:128142 7F81FBFFF700 TRACE MME-AP /mme_app/mme_app_apn_selection.c:0051    Entering mme_app_select_apn()
001482 00200:128152 7F81FBFFF700 INFO  MME-AP /mme_app/mme_app_apn_selection.c:0061    No subscription data is received for IMSI 208950000000004.
001483 00200:128161 7F81FBFFF700 TRACE MME-AP /mme_app/mme_app_apn_selection.c:0062    Leaving mme_app_select_apn() (rc=0)
001484 00200:128170 7F81FBFFF700 INFO  NAS-ES r-mme/src/nas/esm/sap/esm_recv.c:0629    ESM-SAP   - Getting subscription profile for IMSI 208950000000004. (ue_id=1, pti=45)
001485 00200:128182 7F81FBFFF700 TRACE NAS    mme/src/nas/nas_itti_messaging.c:0356    Entering nas_itti_pdn_config_req()
001486 00200:128214 7F81FBFFF700 TRACE MME-AP mme/src/nas/nas_itti_messaging.c:0383    Leaving nas_itti_pdn_config_req() (rc=0)
001487 00200:128224 7F81FBFFF700 TRACE NAS-ES r-mme/src/nas/esm/sap/esm_recv.c:0637    Leaving esm_recv_information_response() (rc=-1)
001488 00200:128235 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0447    Entering esm_msg_free()
001489 00200:128245 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0592    Leaving esm_msg_free()
001490 00200:128254 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0447    Entering esm_msg_free()
001491 00200:128263 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0592    Leaving esm_msg_free()
001492 00200:128272 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/sap/esm_sap.c:0949    Leaving _esm_sap_recv()
001493 00200:128338 7F81FBFFF700 TRACE NAS-ES r-mme/src/nas/esm/nas_esm_proc.c:0178    Leaving nas_esm_proc_data_ind() (rc=0)
001494 00200:128407 7F81A2FFD700 DEBUG S6A    openair-mme/src/s6a/s6a_up_loc.c:0310    Sending s6a ulr for imsi=208950000000004
001495 00200:134096 7F81F0FF9700 DEBUG S6A    openair-mme/src/s6a/s6a_up_loc.c:0059    Received s6a ula for imsi=208950000000004
001496 00200:134165 7F81F0FF9700 DEBUG S6A    /src/s6a/s6a_subscription_data.c:0469    AVP code 1446 Regional-Subscription-Zone=Code not processed
001497 00200:134176 7F81F0FF9700 DEBUG S6A    /src/s6a/s6a_subscription_data.c:0469    AVP code 1446 Regional-Subscription-Zone=Code not processed
001498 00200:134184 7F81F0FF9700 DEBUG S6A    /src/s6a/s6a_subscription_data.c:0469    AVP code 1446 Regional-Subscription-Zone=Code not processed
001499 00200:134191 7F81F0FF9700 DEBUG S6A    /src/s6a/s6a_subscription_data.c:0469    AVP code 1446 Regional-Subscription-Zone=Code not processed
001500 00200:134198 7F81F0FF9700 DEBUG S6A    /src/s6a/s6a_subscription_data.c:0469    AVP code 1446 Regional-Subscription-Zone=Code not processed
001501 00200:134205 7F81F0FF9700 DEBUG S6A    /src/s6a/s6a_subscription_data.c:0469    AVP code 1446 Regional-Subscription-Zone=Code not processed
001502 00200:134212 7F81F0FF9700 DEBUG S6A    /src/s6a/s6a_subscription_data.c:0469    AVP code 1446 Regional-Subscription-Zone=Code not processed
001503 00200:134218 7F81F0FF9700 DEBUG S6A    /src/s6a/s6a_subscription_data.c:0469    AVP code 1446 Regional-Subscription-Zone=Code not processed
001504 00200:134225 7F81F0FF9700 DEBUG S6A    /src/s6a/s6a_subscription_data.c:0469    AVP code 1446 Regional-Subscription-Zone=Code not processed
001505 00200:134232 7F81F0FF9700 DEBUG S6A    /src/s6a/s6a_subscription_data.c:0469    AVP code 1446 Regional-Subscription-Zone=Code not processed
001506 00200:134303 7F81F0FF9700 DEBUG S6A    openair-mme/src/s6a/s6a_up_loc.c:0178    Sending S6A_UPDATE_LOCATION_ANS to task MME_APP
001507 00200:134332 7F81F9704700 TRACE MME-AP e/src/mme_app/mme_app_location.c:0049    Entering mme_app_handle_s6a_update_location_ans()
001508 00200:134356 7F81F9704700 DEBUG MME-AP e/src/mme_app/mme_app_location.c:0060    mme_app_handle_s6a_update_location_ans Handling imsi 208950000000004
001509 00200:134373 7F81F9704700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001510 00200:134386 7F81F9704700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0896    EMM-CTX - get UE id 1 context 0x7f81680011b0 by imsi 208950000000004
001511 00200:134414 7F81F9704700 TRACE MME-AP me/src/mme_app/mme_app_context.c:0975    Entering mme_remove_subscription_profile()
001512 00200:134429 7F81F9704700 WARNI MME-AP me/src/mme_app/mme_app_context.c:0983    No subscription data was found for IMSI 208950000000004 in the subscription profile cache.001513 00200:134437 7F81F9704700 TRACE MME-AP me/src/mme_app/mme_app_context.c:0984    Leaving mme_remove_subscription_profile() (rc=0)
001514 00200:134445 7F81F9704700 TRACE MME-AP me/src/mme_app/mme_app_context.c:0932    Entering mme_insert_subscription_profile()
001515 00200:134466 7F81F9704700 TRACE MME-AP me/src/mme_app/mme_app_context.c:0958    Leaving mme_insert_subscription_profile() (rc=0)
001516 00200:134477 7F81F9704700 INFO  MME-AP e/src/mme_app/mme_app_location.c:0096    Updated the subscription profile for IMSI 208950000000004 in the cache.
001517 00200:134485 7F81F9704700 TRACE MME-AP me/src/mme_app/mme_app_context.c:0997    Entering mme_app_update_ue_subscription()
001518 00200:134495 7F81F9704700 TRACE MME-AP me/src/mme_app/mme_app_context.c:1062    Leaving mme_app_update_ue_subscription() (rc=0)
001519 00200:134517 7F81F9704700 TRACE MME-AP e/src/mme_app/mme_app_location.c:0147    Leaving mme_app_handle_s6a_update_location_ans() (rc=0)
001520 00200:134538 7F81FBFFF700 TRACE NAS-ES r-mme/src/nas/esm/nas_esm_proc.c:0205    Entering nas_esm_proc_pdn_config_res()
001521 00200:134561 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/sap/esm_sap.c:0137    Entering esm_sap_signal()
001522 00200:134571 7F81FBFFF700 INFO  NAS-ES ir-mme/src/nas/esm/sap/esm_sap.c:0152    ESM-SAP   - Received primitive ESM_PDN_CONFIG_RES (1)
001523 00200:134580 7F81FBFFF700 TRACE NAS-ES me/src/nas/esm/PdnConnectivity.c:0557    Entering esm_proc_pdn_config_res()
001524 00200:134588 7F81FBFFF700 TRACE MME-AP mme_app/mme_app_esm_procedures.c:0216    Entering mme_app_nas_esm_get_pdn_connectivity_procedure()
001525 00200:134598 7F81FBFFF700 TRACE MME-AP mme_app/mme_app_esm_procedures.c:0234    Leaving mme_app_nas_esm_get_pdn_connectivity_procedure() (rc=140193571016096)
001526 00200:134607 7F81FBFFF700 TRACE MME-AP /mme_app/mme_app_apn_selection.c:0051    Entering mme_app_select_apn()
001527 00200:134617 7F81FBFFF700 DEBUG MME-AP /mme_app/mme_app_apn_selection.c:0101    Selected APN oai.ipv4 for UE 208950000000004
001528 00200:134636 7F81FBFFF700 TRACE MME-AP /mme_app/mme_app_apn_selection.c:0104    Leaving mme_app_select_apn() (rc=0)
001529 00200:134645 7F81FBFFF700 TRACE MME-AP rc/mme_app/mme_app_pdn_context.c:0062    Entering mme_app_get_pdn_context()
001530 00200:134654 7F81FBFFF700 WARNI MME-AP rc/mme_app/mme_app_pdn_context.c:0100    No PDN context for (ebi=0,cid=100,apn="oai.ipv4") was found for UE: 1.
001531 00200:134666 7F81FBFFF700 TRACE MME-AP rc/mme_app/mme_app_pdn_context.c:0101    Leaving mme_app_get_pdn_context()
001532 00200:134674 7F81FBFFF700 TRACE NAS-ES me/src/nas/esm/PdnConnectivity.c:0213    Entering esm_proc_pdn_connectivity_request()
001533 00200:134682 7F81FBFFF700 INFO  NAS-ES me/src/nas/esm/PdnConnectivity.c:0221    ESM-PROC  - PDN connectivity requested by the UE (ue_id=1, pti=45) PDN type = (1), APN = oai.ipv4
001534 00200:134694 7F81FBFFF700 TRACE MME-AP rc/mme_app/mme_app_pdn_context.c:0110    Entering mme_app_esm_create_pdn_context()
001535 00200:134702 7F81FBFFF700 TRACE MME-AP rc/mme_app/mme_app_pdn_context.c:0062    Entering mme_app_get_pdn_context()
001536 00200:134712 7F81FBFFF700 WARNI MME-AP rc/mme_app/mme_app_pdn_context.c:0100    No PDN context for (ebi=0,cid=0,apn="oai.ipv4") was found for UE: 1.
001537 00200:134721 7F81FBFFF700 TRACE MME-AP rc/mme_app/mme_app_pdn_context.c:0101    Leaving mme_app_get_pdn_context()
001538 00200:134729 7F81FBFFF700 INFO  MME-AP rc/mme_app/mme_app_pdn_context.c:0217    Received first default bearer context 0x5570b5af3894 with ebi 5 for apn "oai.ipv4" of UE: 1.
001539 00200:134745 7F81FBFFF700 TRACE MME-AP rc/mme_app/mme_app_pdn_context.c:0308    Leaving mme_app_esm_create_pdn_context() (rc=0)
001540 00200:134754 7F81FBFFF700 TRACE MME-AP mme_app/mme_app_itti_messaging.c:0237    Entering mme_app_send_s11_create_session_req()
001541 00200:134763 7F81FBFFF700 DEBUG MME-AP mme_app/mme_app_itti_messaging.c:0274    Sending CSR for imsi 208950000000004
001542 00200:134790 7F81FBFFF700 DEBUG MME-AP /mme_app/mme_app_wrr_selection.c:0095    Service lookup tac-lb01.tac-hb00.tac.epc.mnc095.mcc208.3gppnetwork.org returned 192.168.61.196
001543 00200:134803 7F81FBFFF700 TRACE MME-AP mme_app/mme_app_bearer_context.c:0143    Entering mme_app_get_bearer_contexts_to_be_created()
001544 00200:134822 7F81FBFFF700 TRACE MME-AP mme_app/mme_app_bearer_context.c:0220    Leaving mme_app_get_bearer_contexts_to_be_created()
001545 00200:134830 7F81FBFFF700 DEBUG MME-AP mme_app/mme_app_itti_messaging.c:0443    Sending CSR for imsi (2) 208950000000004
001546 00200:134852 7F81FBFFF700 TRACE MME-AP mme_app/mme_app_itti_messaging.c:0445    Leaving mme_app_send_s11_create_session_req() (rc=0)
001547 00200:134861 7F81FBFFF700 TRACE NAS-ES me/src/nas/esm/PdnConnectivity.c:0269    Leaving esm_proc_pdn_connectivity_request() (rc=-1)
001548 00200:134869 7F81FBFFF700 TRACE NAS-EM me/src/nas/esm/PdnConnectivity.c:0709    Leaving esm_proc_pdn_config_res() (rc=-1)
001549 00200:134878 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0447    Entering esm_msg_free()
001550 00200:134886 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0592    Leaving esm_msg_free()
001551 00200:134894 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/sap/esm_sap.c:0534    Leaving esm_sap_signal()
001552 00200:134901 7F81FBFFF700 WARNI MME-AP r-mme/src/nas/esm/nas_esm_proc.c:0233    No ESM data received and no attach/tau signaled for UE 1.
001553 00200:134909 7F81FBFFF700 TRACE NAS-ES r-mme/src/nas/esm/nas_esm_proc.c:0237    Leaving nas_esm_proc_pdn_config_res() (rc=0)
001554 00200:134915 7F81FA7FC700 TRACE S11    rc/s11/s11_mme_session_manager.c:0060    Entering s11_mme_create_session_request()
001555 00200:134941 7F81FA7FC700 DEBUG GTPv2- /nwgtpv2c-0.11/src/NwGtpv2cMsg.c:0079    ALLOCATED NEW MESSAGE 0x7f8160000d50!
001556 00200:134958 7F81FA7FC700 DEBUG GTPv2- /nwgtpv2c-0.11/src/NwGtpv2cMsg.c:0092    Created message 0x7f8160000d50!
001557 00200:134979 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:2028    Entering nwGtpv2cProcessUlpReq()
001558 00200:134988 7F81FA7FC700 DEBUG GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:2032    Received initial request from ulp
001559 00200:134996 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:0691    Entering nwGtpv2cHandleUlpInitialReq()
001560 00200:135004 7F81FA7FC700 DEBUG GTPv2- nwgtpv2c-0.11/src/NwGtpv2cTrxn.c:0248    Created not trx without seqNum as transaction 0x7f81600041c0. Head (nil), Next 0x5570b568c7a2
001561 00200:135022 7F81FA7FC700 DEBUG GTPv2- nwgtpv2c-0.11/src/NwGtpv2cTrxn.c:0264    Created transaction 0x7f81600041c0
001562 00200:135030 7F81FA7FC700 WARNI GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:0714    Request message received on non-existent teid 0x1000000 received! Creating new tunnel.
001563 00200:135049 7F81FA7FC700 DEBUG GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:0606    Creating local tunnel with teid '0x1' and peer IPv4 192.168.61.196
001564 00200:135057 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:0615    Entering nwGtpv2cCreateLocalTunnel()
001565 00200:135067 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:0637    Leaving nwGtpv2cCreateLocalTunnel() (rc=0)
001566 00200:135090 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:2229    Entering nwGtpv2cStartTimer()
001568 00200:135110 7F81FA7FC700 DEBUG GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:2294    Started timer 0x7f81600041a0 for info 0x0x7f81600042e0!
001569 00200:135125 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:2300    Leaving nwGtpv2cStartTimer() (rc=0)
001567 00200:135107 7F81FAFFD700 DEBUG UDP    /src/udp/udp_primitives_server.c:0077    Looking for task 9
001570 00200:135135 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:0770    Leaving nwGtpv2cHandleUlpInitialReq() (rc=0)
001571 00200:135141 7F81FAFFD700 DEBUG UDP    /src/udp/udp_primitives_server.c:0093    Found matching port with high port 46468.
001572 00200:135144 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:2074    Leaving nwGtpv2cProcessUlpReq() (rc=0)
001573 00200:135151 7F81FAFFD700 DEBUG UDP    /src/udp/udp_primitives_server.c:0446    [39] Sending message of size 162 to 192.168.61.196 and port 2123
001574 00200:135156 7F81FA7FC700 TRACE S11    rc/s11/s11_mme_session_manager.c:0175    Leaving s11_mme_create_session_request() (rc=0)
001575 00200:135319 7F81FAFFD700 DEBUG UDP    /src/udp/udp_primitives_server.c:0122    Received 1 events
001576 00200:137371 7F81FAFFD700 DEBUG UDP    /src/udp/udp_primitives_server.c:0122    Received 1 events
001577 00200:137378 7F81FAFFD700 DEBUG UDP    /src/udp/udp_primitives_server.c:0108    Looking for sd 39
001578 00200:137382 7F81FAFFD700 DEBUG UDP    /src/udp/udp_primitives_server.c:0147    Inserting new descriptor for task 9, sd 39
001579 00200:137395 7F81FAFFD700 DEBUG UDP    /src/udp/udp_primitives_server.c:0192    Msg of length 97 received from 192.168.61.196:2123
001580 00200:137409 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:1874    Entering nwGtpv2cProcessUdpReq()
001581 00200:137415 7F81FA7FC700 DEBUG GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:1468    RECEIVED GTPV2c  response message of type 33, length 97 and seqNum 8690.
001582 00200:137418 7F81FA7FC700 DEBUG GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:1492    Not removing the initial request transaction for message type 33, seqNo 8690 (altough remove flag set).
001583 00200:137423 7F81FA7FC700 DEBUG GTPv2- /nwgtpv2c-0.11/src/NwGtpv2cMsg.c:0132    Created message 0x7f81600043a0!
001584 00200:137430 7F81FA7FC700 DEBUG GTPv2- .11/src/NwGtpv2cMsgIeParseInfo.c:1314    Received IE 2 with instance 0 of length 2 in msg-type 33!
001585 00200:137433 7F81FA7FC700 DEBUG GTPv2- .11/src/NwGtpv2cMsgIeParseInfo.c:1314    Received IE 87 with instance 0 of length 9 in msg-type 33!
001586 00200:137436 7F81FA7FC700 DEBUG GTPv2- .11/src/NwGtpv2cMsgIeParseInfo.c:1314    Received IE 79 with instance 0 of length 5 in msg-type 33!
001587 00200:137441 7F81FA7FC700 DEBUG GTPv2- .11/src/NwGtpv2cMsgIeParseInfo.c:1314    Received IE 72 with instance 0 of length 8 in msg-type 33!
001588 00200:137444 7F81FA7FC700 WARNI GTPv2- .11/src/NwGtpv2cMsgIeParseInfo.c:1389    Unexpected IE 72 with instance 0 of length 8 received in msg 33!
001589 00200:137448 7F81FA7FC700 DEBUG GTPv2- .11/src/NwGtpv2cMsgIeParseInfo.c:1314    Received IE 78 with instance 0 of length 13 in msg-type 33!
001590 00200:137451 7F81FA7FC700 DEBUG GTPv2- .11/src/NwGtpv2cMsgIeParseInfo.c:1314    Received IE 93 with instance 0 of length 24 in msg-type 33!
001591 00200:137455 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:1140    Entering nwGtpv2cSendTriggeredRspIndToUlp()
001592 00200:137480 7F81FA7FC700 DEBUG GTPv2- v2c-0.11/src/NwGtpv2cMsgParser.c:0211    Received IE 2 of length 2!
001593 00200:137488 7F81FA7FC700 DEBUG GTPv2- matter/src/gtpv2c_ie_formatter.c:0153     - Cause value 16
001594 00200:137491 7F81FA7FC700 DEBUG GTPv2- v2c-0.11/src/NwGtpv2cMsgParser.c:0211    Received IE 87 of length 9!
001595 00200:137495 7F81FA7FC700 DEBUG GTPv2- matter/src/gtpv2c_ie_formatter.c:0232     - F-TEID type 11
001596 00200:137498 7F81FA7FC700 DEBUG GTPv2- matter/src/gtpv2c_ie_formatter.c:0237     - TEID/GRE    00000001
001597 00200:137501 7F81FA7FC700 DEBUG GTPv2- matter/src/gtpv2c_ie_formatter.c:0249     - IPv4 addr   192.168.61.196
001598 00200:137506 7F81FA7FC700 DEBUG GTPv2- v2c-0.11/src/NwGtpv2cMsgParser.c:0211    Received IE 79 of length 5!
001599 00200:137509 7F81FA7FC700 DEBUG S11    matter/src/gtpv2c_ie_formatter.c:0276     - PAA type  1
001600 00200:137513 7F81FA7FC700 DEBUG S11    matter/src/gtpv2c_ie_formatter.c:0309     - IPv4 addr 12.1.1.2
001601 00200:137516 7F81FA7FC700 DEBUG GTPv2- v2c-0.11/src/NwGtpv2cMsgParser.c:0211    Received IE 72 of length 8!
001602 00200:137519 7F81FA7FC700 DEBUG S11    matter/src/gtpv2c_ie_formatter.c:0416     - AMBR UL 50000000
001603 00200:137522 7F81FA7FC700 DEBUG S11    matter/src/gtpv2c_ie_formatter.c:0417     - AMBR DL 100000000
001604 00200:137525 7F81FA7FC700 DEBUG GTPv2- v2c-0.11/src/NwGtpv2cMsgParser.c:0211    Received IE 78 of length 13!
001605 00200:137529 7F81FA7FC700 DEBUG GTPv2- v2c-0.11/src/NwGtpv2cMsgParser.c:0211    Received IE 93 of length 24!
001606 00200:137533 7F81FA7FC700 DEBUG S11    matter/src/gtpv2c_ie_formatter.c:0374     - EBI 5
001607 00200:137536 7F81FA7FC700 DEBUG GTPv2- matter/src/gtpv2c_ie_formatter.c:0153     - Cause value 16
001608 00200:137543 7F81FA7FC700 DEBUG GTPv2- matter/src/gtpv2c_ie_formatter.c:0232     - F-TEID type 1
001609 00200:137546 7F81FA7FC700 DEBUG GTPv2- matter/src/gtpv2c_ie_formatter.c:0237     - TEID/GRE    00000001
001610 00200:137549 7F81FA7FC700 DEBUG GTPv2- matter/src/gtpv2c_ie_formatter.c:0249     - IPv4 addr   192.168.61.197
001611 00200:137554 7F81FA7FC700 DEBUG GTPv2- /nwgtpv2c-0.11/src/NwGtpv2cMsg.c:0144    Purging message 0x7f81600043a0!
001612 00200:137557 7F81FA7FC700 DEBUG GTPv2- /nwgtpv2c-0.11/src/NwGtpv2cMsg.c:0149    Message pool 7f81600043a0! Next element 0!
001613 00200:137565 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:1154    Leaving nwGtpv2cSendTriggeredRspIndToUlp() (rc=0)
001614 00200:137570 7F81FA7FC700 WARNI GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:1535    Removing the initial request transaction for message type 33, seqNo 8690 in conclusion (not late response).
001615 00200:137575 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:2392    Entering nwGtpv2cStopTimer()
001616 00200:137580 7F81FA7FC700 DEBUG GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:2406    Stopping active timer 0x7f81600041a0 for info 0x0x7f81600042e0!
001617 00200:137587 7F81FA7FC700 INFO  GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:2418    Stopped active timer 0x7f81600041a0 for info 0x0x7f81600042e0!
001618 00200:137591 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:2445    Leaving nwGtpv2cStopTimer() (rc=0)
001619 00200:137595 7F81FA7FC700 DEBUG GTPv2- /nwgtpv2c-0.11/src/NwGtpv2cMsg.c:0144    Purging message 0x7f8160000d50!
001620 00200:137598 7F81FA7FC700 DEBUG GTPv2- /nwgtpv2c-0.11/src/NwGtpv2cMsg.c:0149    Message pool 7f8160000d50! Next element 7f81600043a0!
001621 00200:137601 7F81FA7FC700 DEBUG GTPv2- nwgtpv2c-0.11/src/NwGtpv2cTrxn.c:0422    Purging  transaction 0x7f81600041c0 with seqNum 34448. (before) Head (nil), Next (nil).
001622 00200:137605 7F81FA7FC700 DEBUG GTPv2- nwgtpv2c-0.11/src/NwGtpv2cTrxn.c:0429    After purging  transaction 0x7f81600041c0, Head 0x7f81600041c0, Next (nil)
001623 00200:137609 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:2014    Leaving nwGtpv2cProcessUdpReq() (rc=0)
001624 00200:137628 7F81F9704700 TRACE MME-AP mme/src/mme_app/mme_app_bearer.c:1783    Entering mme_app_handle_create_sess_resp()
001625 00200:137637 7F81F9704700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001626 00200:137641 7F81F9704700 TRACE MME-AP me_app/mme_app_session_context.c:0374    Entering mme_app_pdn_process_session_creation()
001627 00200:137649 7F81F9704700 DEBUG MME-AP me_app/mme_app_session_context.c:0638    Received new valid APN_AMBR for APN "oai.ipv4" (ctx_id=0) for UE 1. Updating APN ambr.
001628 00200:137654 7F81F9704700 INFO  MME-AP me_app/mme_app_session_context.c:0736    Processed all 1 bearer contexts for APN "oai.ipv4" for ue_id 1.
001629 00200:137659 7F81F9704700 TRACE MME-AP me_app/mme_app_session_context.c:0737    Leaving mme_app_pdn_process_session_creation() (rc=0)
001630 00200:137664 7F81F9704700 TRACE MME-AP mme_app/mme_app_itti_messaging.c:1264    Entering mme_app_itti_nas_pdn_connectivity_response()
001631 00200:137668 7F81F9704700 INFO  MME-AP mme_app/mme_app_itti_messaging.c:1271    Informing the NAS layer about the received CREATE_SESSION_RESPONSE for UE 1.
001632 00200:137676 7F81F9704700 TRACE MME-AP mme_app/mme_app_itti_messaging.c:1288    Leaving mme_app_itti_nas_pdn_connectivity_response()
001633 00200:137680 7F81F9704700 TRACE MME-AP mme/src/mme_app/mme_app_bearer.c:1867    Leaving mme_app_handle_create_sess_resp() (rc=0)
001634 00200:137690 7F81FBFFF700 TRACE NAS-ES r-mme/src/nas/esm/nas_esm_proc.c:0278    Entering nas_esm_proc_pdn_connectivity_res()
001635 00200:137695 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/sap/esm_sap.c:0137    Entering esm_sap_signal()
001636 00200:137699 7F81FBFFF700 INFO  NAS-ES ir-mme/src/nas/esm/sap/esm_sap.c:0152    ESM-SAP   - Received primitive ESM_PDN_CONNECTIVITY_CNF (3)
001637 00200:137705 7F81FBFFF700 TRACE MME-AP mme_app/mme_app_esm_procedures.c:0216    Entering mme_app_nas_esm_get_pdn_connectivity_procedure()
001638 00200:137708 7F81FBFFF700 TRACE MME-AP mme_app/mme_app_esm_procedures.c:0234    Leaving mme_app_nas_esm_get_pdn_connectivity_procedure() (rc=140193571016096)
001639 00200:137712 7F81FBFFF700 TRACE NAS-ES me/src/nas/esm/PdnConnectivity.c:0392    Entering esm_proc_pdn_connectivity_res()
001640 00200:137715 7F81FBFFF700 TRACE MME-AP mme_app/mme_app_bearer_context.c:0385    Entering mme_app_esm_update_ebr_state()
001641 00200:137719 7F81FBFFF700 TRACE MME-AP rc/mme_app/mme_app_pdn_context.c:0062    Entering mme_app_get_pdn_context()
001642 00200:137723 7F81FBFFF700 TRACE MME-AP rc/mme_app/mme_app_pdn_context.c:0082    Leaving mme_app_get_pdn_context()
001643 00200:137728 7F81FBFFF700 TRACE MME-AP mme_app/mme_app_bearer_context.c:0414    Leaving mme_app_esm_update_ebr_state() (rc=0)
001644 00200:137732 7F81FBFFF700 TRACE NAS-ES me/src/nas/esm/PdnConnectivity.c:0422    Leaving esm_proc_pdn_connectivity_res() (rc=-1)
001645 00200:137736 7F81FBFFF700 TRACE NAS-ES aultEpsBearerContextActivation.c:0238    Entering esm_proc_default_eps_bearer_context()
001646 00200:137739 7F81FBFFF700 INFO  NAS-ES aultEpsBearerContextActivation.c:0245    ESM-PROC  - Default EPS bearer context activation (ue_id=1, context_identifier=0, bc_status 0)
001647 00200:137743 7F81FBFFF700 NOTIC NAS    aultEpsBearerContextActivation.c:0246    Hit 3GPP TS 24_301R10_6_4_1_2 :
001648 00200:137748 7F81FBFFF700 TRACE MME-AP rc/mme_app/mme_app_pdn_context.c:0062    Entering mme_app_get_pdn_context()
001649 00200:137752 7F81FBFFF700 TRACE MME-AP rc/mme_app/mme_app_pdn_context.c:0082    Leaving mme_app_get_pdn_context()
001650 00200:137755 7F81FBFFF700 TRACE NAS-ES aultEpsBearerContextActivation.c:0130    Entering esm_send_activate_default_eps_bearer_context_request()
001651 00200:137759 7F81FBFFF700 INFO  NAS-ES aultEpsBearerContextActivation.c:0160    ESM-SAP   - pdn_type is 1
001652 00200:137765 7F81FBFFF700 INFO  NAS-ES aultEpsBearerContextActivation.c:0207    ESM-SAP   - Send Activate Default EPS Bearer Context Request message (pti=45, ebi=5)
001653 00200:137769 7F81FBFFF700 TRACE NAS-ES aultEpsBearerContextActivation.c:0208    Leaving esm_send_activate_default_eps_bearer_context_request()
001654 00200:137773 7F81FBFFF700 TRACE NAS-ES aultEpsBearerContextActivation.c:0290    Leaving esm_proc_default_eps_bearer_context()
001655 00200:137779 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0282    Entering esm_msg_encode()
001656 00200:137782 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0301    ESM-MSG   - Encoded ESM message header (3)
001657 00200:137798 7F81FBFFF700 INFO  NAS-ES DefaultEpsBearerContextRequest.c:0357    ESM  ENCODED activate_default_eps_bearer_context_request
001658 00200:137803 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0429    Leaving esm_msg_encode() (rc=42)
001659 00200:137806 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0447    Entering esm_msg_free()
001660 00200:137810 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0592    Leaving esm_msg_free()
001661 00200:137813 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/sap/esm_sap.c:0534    Leaving esm_sap_signal()
001662 00200:137817 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_cn.c:0301    Entering _emm_wrapper_esm_accept()
001663 00200:137822 7F81FBFFF700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001664 00200:137825 7F81FBFFF700 TRACE NAS-EM openair-mme/src/nas/emm/Attach.c:1922    Entering _emm_wrapper_attach_accept()
001665 00200:137830 7F81FBFFF700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001666 00200:137833 7F81FBFFF700 TRACE NAS-EM openair-mme/src/nas/emm/Attach.c:2028    Entering _emm_send_attach_accept()
001667 00200:137838 7F81FBFFF700 TRACE NAS-EM openair-mme/src/nas/emm/Attach.c:2692    Entering _emm_attach_update()
001668 00200:137841 7F81FBFFF700 NOTIC NAS    openair-mme/src/nas/emm/Attach.c:2712    Hit 3GPP TS 24_301R10_5_5_1_2_4__4 : Attach accepted by the network, store UE network capability IE or the MS network capability IE or both.
001669 00200:137846 7F81FBFFF700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0452    ue_id=1 set UE network capability IE (valid)
001670 00200:137849 7F81FBFFF700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0489    ue_id=1 set MS network capability IE (valid)
001671 00200:137854 7F81FBFFF700 NOTIC NAS    openair-mme/src/nas/emm/Attach.c:2750    Hit 3GPP TS 24_301R10_5_5_1_2_4__5 : Attach accepted by the network, use DRX parameter for the downlink transfer of signalling and user data
001672 00200:137857 7F81FBFFF700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0510    ue_id=1 set current DRX parameter (present)
001673 00200:137862 7F81FBFFF700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0521    ue_id=1 set current DRX parameter (valid)
001674 00200:137865 7F81FBFFF700 TRACE NAS-EM openair-mme/src/nas/emm/Attach.c:2754    Leaving _emm_attach_update() (rc=0)
001675 00200:137869 7F81FBFFF700 NOTIC NAS    openair-mme/src/nas/emm/Attach.c:2060    #NOT IMPLEMENTED 3GPP TS 24_301R10_5_5_1_2_4__3 : Attach accepted by the network, delete the stored UE radio capability information.
001676 00200:137874 7F81FBFFF700 NOTIC NAS    openair-mme/src/nas/emm/Attach.c:2065    Hit 3GPP TS 24_301R10_5_5_1_2_4__9 :
001677 00200:137877 7F81FBFFF700 TRACE NAS    ir-mme/src/nas/api/mme/mme_api.c:0454    Entering mme_api_new_guti()
001678 00200:137881 7F81FBFFF700 TRACE NAS    ir-mme/src/nas/api/mme/mme_api.c:0416    Entering mme_api_notify_new_guti()
001679 00200:137886 7F81FBFFF700 TRACE MME-AP me/src/mme_app/mme_app_context.c:0325    Entering mme_ue_context_update_coll_keys()
001680 00200:137890 7F81FBFFF700 TRACE MME-AP me/src/mme_app/mme_app_context.c:0334    Update ue context.enb_ue_s1ap_id 06692d ue context.mme_ue_s1ap_id 1 ue context.IMSI 208950000000004 ue context.GUTI 000.000|0000|00|00000000
001681 00200:137896 7F81FBFFF700 TRACE MME-AP me/src/mme_app/mme_app_context.c:0342    Update ue context 0x5570b59e3858 enb_ue_s1ap_id 06692d mme_ue_s1ap_id 1 IMSI 208950000000004 GUTI 208.95 |8000|03|00000001
001682 00200:137904 7F81FBFFF700 TRACE MME-AP me/src/mme_app/mme_app_context.c:0605    Leaving mme_ue_context_update_coll_keys()
001683 00200:137908 7F81FBFFF700 TRACE NAS    ir-mme/src/nas/api/mme/mme_api.c:0428    Leaving mme_api_notify_new_guti() (rc=0)
001684 00200:137911 7F81FBFFF700 INFO  NAS    ir-mme/src/nas/api/mme/mme_api.c:0495    UE 1  with GUTI 208.95 |8000|03|00000001 will only receive its TAC 0x1 in the TAI list to enforce TAU.
001685 00200:137916 7F81FBFFF700 TRACE NAS    ir-mme/src/nas/api/mme/mme_api.c:0520    Leaving mme_api_new_guti() (rc=0)
001686 00200:137920 7F81FBFFF700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0118    ue_id=1 set GUTI 208.95 |8000|03|00000001 (present)
001687 00200:137925 7F81FBFFF700 NOTIC NAS    openair-mme/src/nas/emm/Attach.c:2085    Hit 3GPP TS 24_301R10_5_5_1_2_4__6 :
001688 00200:137927 7F81FBFFF700 NOTIC NAS    openair-mme/src/nas/emm/Attach.c:2086    Hit 3GPP TS 24_301R10_5_5_1_2_4__10 :
001689 00200:137932 7F81FBFFF700 INFO  NAS-EM openair-mme/src/nas/emm/Attach.c:2122    ue_id=1 EMM-PROC  - Include the new assigned GUTI in the Attach Accept message
001690 00200:137936 7F81FBFFF700 NOTIC NAS    openair-mme/src/nas/emm/Attach.c:2128    Hit 3GPP TS 24_301R10_5_5_1_2_4__14 :
001691 00200:137939 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/LowerLayer.c:0670    Entering emm_as_set_security_data()
001692 00200:137945 7F81FBFFF700 INFO  NAS-EM air-mme/src/nas/emm/LowerLayer.c:0688    EPS security context exists is new 0 KSI 2 SQN 1 count 16777216
001693 00200:137949 7F81FBFFF700 DEBUG NAS-EM air-mme/src/nas/emm/LowerLayer.c:0690    hex stream knas_int: 3d 40 c1 8e 32 36 d6 3a a0 21 09 07 3a dd 31 2f
001694 00200:137959 7F81FBFFF700 DEBUG NAS-EM air-mme/src/nas/emm/LowerLayer.c:0692    hex stream knas_enc: 63 ea 72 08 d9 f2 18 14 72 e7 bc 9d cd e2 23 4c
001695 00200:137968 7F81FBFFF700 DEBUG NAS-EM air-mme/src/nas/emm/LowerLayer.c:0722    EPS security context exists knas_enc
001696 00200:137971 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/LowerLayer.c:0734    Leaving emm_as_set_security_data()
001697 00200:137975 7F81FBFFF700 DEBUG NAS-EM openair-mme/src/nas/emm/Attach.c:2153    ue_id=1 EMM-PROC  - encryption = 0x0 (0x0)
001698 00200:137978 7F81FBFFF700 DEBUG NAS-EM openair-mme/src/nas/emm/Attach.c:2158    ue_id=1 EMM-PROC  - integrity  = 0x2 (0x2)
001699 00200:137983 7F81FBFFF700 TRACE NAS-EM openair-mme/src/nas/emm/Attach.c:2169    ue_id=1 EMM-PROC  - nas_msg  src size = 42 nas_msg  dst size = 42
001700 00200:137986 7F81FBFFF700 NOTIC NAS    openair-mme/src/nas/emm/Attach.c:2177    Hit 3GPP TS 24_301R10_5_5_1_2_4__2 :
001701 00200:137990 7F81FBFFF700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
001702 00200:137993 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0190    Entering emm_as_send()
001703 00200:137998 7F81FBFFF700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0197    EMMAS-SAP - Received primitive EMMAS_ESTABLISH_CNF (206)
001704 00200:138001 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1095    Entering _emm_as_send()
001705 00200:138006 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:2074    Entering _emm_as_establish_cnf()
001706 00200:138009 7F81FBFFF700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:2076    EMMAS-SAP - Send AS connection establish confirmation
001707 00200:138012 7F81FBFFF700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001708 00200:138015 7F81FBFFF700 DEBUG NAS-EM air-mme/src/nas/emm/sap/emm_as.c:2110    Set nas_msg.selected_encryption_algorithm -> NBO: 0x0000 (0)
001709 00200:138018 7F81FBFFF700 DEBUG NAS-EM air-mme/src/nas/emm/sap/emm_as.c:2115    Set nas_msg.selected_integrity_algorithm -> NBO: 0x0040 (2)
001710 00200:138022 7F81FBFFF700 DEBUG NAS-EM air-mme/src/nas/emm/sap/emm_as.c:2123    EMMAS-SAP - NAS UL COUNT        0
001711 00200:138027 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0903    Entering _emm_as_set_header()
001712 00200:138030 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0946    Leaving _emm_as_set_header() (rc=140196255356480)
001713 00200:138034 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:2135    EMMAS-SAP - emm_as_establish.nasMSG.length=42
001714 00200:138038 7F81FBFFF700 TRACE NAS-EM r-mme/src/nas/emm/sap/emm_send.c:0227    Entering emm_send_attach_accept()
001715 00200:138042 7F81FBFFF700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001716 00200:138046 7F81FBFFF700 INFO  NAS-EM r-mme/src/nas/emm/sap/emm_send.c:0236    EMMAS-SAP - Send Attach Accept message
001717 00200:138050 7F81FBFFF700 INFO  NAS-EM r-mme/src/nas/emm/sap/emm_send.c:0238    EMMAS-SAP - size = EMM_HEADER_MAXIMUM_LENGTH(2)
001718 00200:138053 7F81FBFFF700 INFO  NAS-EM r-mme/src/nas/emm/sap/emm_send.c:0250    EMMAS-SAP - size += EPS_ATTACH_RESULT_MAXIMUM_LENGTH(1)  (3)
001719 00200:138058 7F81FBFFF700 DEBUG NAS-EM r-mme/src/nas/emm/sap/emm_send.c:0253    EMMAS-SAP - Combined EPS/IMSI attach
001720 00200:138061 7F81FBFFF700 INFO  NAS-EM r-mme/src/nas/emm/sap/emm_send.c:0304    EMMAS-SAP - size += GPRS_TIMER_IE_MAX_LENGTH(2)  (5)
001721 00200:138065 7F81FBFFF700 INFO  NAS-EM r-mme/src/nas/emm/sap/emm_send.c:0315    EMMAS-SAP - size += TRACKING_AREA_IDENTITY_LIST_LENGTH(8*1)  (13)
001722 00200:138069 7F81FBFFF700 INFO  NAS-EM r-mme/src/nas/emm/sap/emm_send.c:0345    EMMAS-SAP - size += ESM_MESSAGE_CONTAINER_MINIMUM_LENGTH(2)  (57)
001723 00200:138073 7F81FBFFF700 INFO  NAS-EM r-mme/src/nas/emm/sap/emm_send.c:0367    EMMAS-SAP - size += EPS_MOBILE_IDENTITY_MAXIMUM_LENGTH(13)  (70)
001724 00200:138077 7F81FBFFF700 TRACE NAS-EM r-mme/src/nas/emm/sap/emm_send.c:0386    Leaving emm_send_attach_accept() (rc=70)
001725 00200:138080 7F81FBFFF700 DEBUG NAS-EM air-mme/src/nas/emm/sap/emm_as.c:2177    Set nas_msg.header.sequence_number -> 2
001726 00200:138083 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0987    Entering _emm_as_encode()
001727 00200:138087 7F81FBFFF700 TRACE NAS    rc/nas/api/network/nas_message.c:0561    Entering nas_message_encode()
001728 00200:138090 7F81FBFFF700 TRACE NAS    rc/nas/api/network/nas_message.c:0877    Entering _nas_message_header_encode()
001729 00200:138093 7F81FBFFF700 TRACE NAS    rc/nas/api/network/nas_message.c:0913    Leaving _nas_message_header_encode() (rc=6)
001730 00200:138098 7F81FBFFF700 TRACE NAS    rc/nas/api/network/nas_message.c:0987    Entering _nas_message_protected_encode()
001731 00200:138102 7F81FBFFF700 TRACE NAS    rc/nas/api/network/nas_message.c:0938    Entering _nas_message_plain_encode()
001732 00200:138105 7F81FBFFF700 TRACE NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0295    Entering emm_msg_encode()
001733 00200:138108 7F81FBFFF700 TRACE NAS-EM e/src/nas/emm/msg/AttachAccept.c:0239    Entering encode_attach_accept()
001734 00200:138114 7F81FBFFF700 TRACE NAS-EM e/src/nas/emm/msg/AttachAccept.c:0402    Leaving encode_attach_accept() (rc=66)
001735 00200:138118 7F81FBFFF700 TRACE NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0465    Leaving emm_msg_encode() (rc=68)
001736 00200:138121 7F81FBFFF700 TRACE NAS    rc/nas/api/network/nas_message.c:0963    Leaving _nas_message_plain_encode() (rc=68)
001737 00200:138125 7F81FBFFF700 TRACE NAS    rc/nas/api/network/nas_message.c:1241    Entering _nas_message_encrypt()
001738 00200:138128 7F81FBFFF700 DEBUG NAS    rc/nas/api/network/nas_message.c:1341    NAS_SECURITY_ALGORITHMS_EEA0 dir 1 ul_count.seq_num 1 dl_count.seq_num 2
001739 00200:138131 7F81FBFFF700 TRACE NAS    rc/nas/api/network/nas_message.c:1343    Leaving _nas_message_encrypt() (rc=68)
001740 00200:138135 7F81FBFFF700 TRACE NAS    rc/nas/api/network/nas_message.c:1016    Leaving _nas_message_protected_encode() (rc=68)
001741 00200:138140 7F81FBFFF700 DEBUG NAS    rc/nas/api/network/nas_message.c:0596    offset 5 = 6 - 1, hdr encode = 6, length = 76 bytes = 68
001742 00200:138143 7F81FBFFF700 TRACE NAS    rc/nas/api/network/nas_message.c:1392    Entering _nas_message_get_mac()
001743 00200:138147 7F81FBFFF700 DEBUG NAS    rc/nas/api/network/nas_message.c:1469    NAS_SECURITY_ALGORITHMS_EIA2 dir DOWNLINK count.seq_num 2 count 2
001744 00200:138151 7F81FBFFF700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0076    Byte length: 77, Zero bits: 0:
001745 00200:138156 7F81FBFFF700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0077    hex stream m: 00 00 00 02 04 00 00 00 02 07 42 02 21 06 20 02 f8 59 00 01 00 2a 52 2d c1 01 09 09 03 6f 61 69 04 69 70 76 34 05 01 0c 01 01 02 5e 04 fe fe 9e 6c 27 0d 80 00 0d 04 c1 33 c4 8a 00 10 02 05 4e 50 0b f6 02 f8 59 80 00 03 00 00 00 01
001746 00200:138187 7F81FBFFF700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0079    hex stream Key: 3d 40 c1 8e 32 36 d6 3a a0 21 09 07 3a dd 31 2f
001747 00200:138195 7F81FBFFF700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0081    hex stream Message: 02 07 42 02 21 06 20 02 f8 59 00 01 00 2a 52 2d c1 01 09 09 03 6f 61 69 04 69 70 76 34 05 01 0c 01 01 02 5e 04 fe fe 9e 6c 27 0d 80 00 0d 04 c1 33 c4 8a 00 10 02 05 4e 50 0b f6 02 f8 59 80 00 03 00 00 00 01
001748 00200:138227 7F81FBFFF700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0089    hex stream Out: 5b cd a7 b5 24 c1 80 cf eb 4f 74 78 d8 9b 17 62
001749 00200:138235 7F81FBFFF700 DEBUG NAS    rc/nas/api/network/nas_message.c:1485    NAS_SECURITY_ALGORITHMS_EIA2 returned MAC 5b.cd.a7.b5(3047673179) for length 69 direction 1, count 2
001750 00200:138239 7F81FBFFF700 TRACE NAS    rc/nas/api/network/nas_message.c:1487    Leaving _nas_message_get_mac() (rc=1540204469)
001751 00200:138243 7F81FBFFF700 DEBUG NAS    rc/nas/api/network/nas_message.c:0627    Incremented emm_security_context.dl_count.seq_num -> 3
001752 00200:138246 7F81FBFFF700 TRACE NAS    rc/nas/api/network/nas_message.c:0653    Leaving nas_message_encode() (rc=74)
001753 00200:138249 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1023    Leaving _emm_as_encode() (rc=74)
001754 00200:138252 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/emm/msg/emm_msg.c:0483    Entering emm_msg_free()
001755 00200:138255 7F81FBFFF700 DEBUG NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0493    EMM-MSG   - Message Type 0x42
001756 00200:138258 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/emm/msg/emm_msg.c:0592    Leaving emm_msg_free()
001757 00200:138261 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:2196    Leaving _emm_as_establish_cnf() (rc=2052)
001758 00200:138265 7F81FBFFF700 DEBUG NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1229    EMMAS-SAP - Sending msg with id 0x804, primitive EMMAS_ESTABLISH_CNF (206) to S1AP layer for transmission
001759 00200:138271 7F81FBFFF700 DEBUG NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1291    EMMAS-SAP - Sending nas_itti_establish_cnf to S1AP UE ID 0x1 sea 0x0000 sia 0x0040, uplink count 0
001760 00200:138274 7F81FBFFF700 TRACE NAS    mme/src/nas/nas_itti_messaging.c:0571    Entering nas_itti_establish_cnf()
001761 00200:138277 7F81FBFFF700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001762 00200:138281 7F81FBFFF700 DEBUG NAS-EM mme/src/nas/nas_itti_messaging.c:0616    EMM-PROC  - KeNB with UL Count 0 for UE 1.
001763 00200:138291 7F81FBFFF700 DEBUG NAS    mme/src/nas/nas_itti_messaging.c:0627    hex stream KENB:  d4 18 fa 6d 1e 24 c7 fa 32 a5 72 98 bd 83 fa a8 84 53 e6 bc 61 03 6b 6f b7 0b e0 5f 05 a4 76 07
001764 00200:138304 7F81FBFFF700 DEBUG NAS-EM mme/src/nas/nas_itti_messaging.c:0636    EMM-PROC  - NH value is 0 as expected. Setting kEnb as NH0
001765 00200:138307 7F81FBFFF700 DEBUG NAS    mme/src/nas/nas_itti_messaging.c:0647    hex stream New NH_CONJ of emmCtx:  d4 18 fa 6d 1e 24 c7 fa 32 a5 72 98 bd 83 fa a8 84 53 e6 bc 61 03 6b 6f b7 0b e0 5f 05 a4 76 07
001766 00200:138325 7F81FBFFF700 TRACE NAS    mme/src/nas/nas_itti_messaging.c:0672    Leaving nas_itti_establish_cnf()
001767 00200:138328 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:1302    Leaving _emm_as_send() (rc=0)
001768 00200:138331 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0234    Leaving emm_as_send() (rc=0)
001769 00200:138335 7F81FBFFF700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001770 00200:138343 7F81FBFFF700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:1303    T3450 started UE 1
001771 00200:138347 7F81FBFFF700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
001772 00200:138350 7F81FBFFF700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_reg.c:0104    Entering emm_reg_send()
001773 00200:138353 7F81FBFFF700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0274    Entering emm_fsm_process()
001774 00200:138356 7F81FBFFF700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001775 00200:138359 7F81FBFFF700 INFO  NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0282    EMM-FSM   - Received event COMMON_PROC_REQ (1) in state EMM-DEREGISTERED
001776 00200:138363 7F81FBFFF700 TRACE NAS-EM rc/nas/emm/sap/EmmDeregistered.c:0097    Entering EmmDeregistered()
001777 00200:138366 7F81FBFFF700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001778 00200:138369 7F81FBFFF700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0176    Entering emm_fsm_set_state()
001779 00200:138372 7F81FBFFF700 INFO  NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0185    UE 1 EMM-FSM   - Status changed: EMM-DEREGISTERED ===> EMM-COMMON-PROCEDURE-INITIATED
001780 00200:138375 7F81FBFFF700 TRACE MME-AP me/src/mme_app/mme_app_context.c:2251    Entering mme_ue_context_update_ue_emm_state()
001781 00200:138378 7F81FBFFF700 TRACE MME-AP me/src/mme_app/mme_app_context.c:2276    Leaving mme_ue_context_update_ue_emm_state()
001782 00200:138381 7F81FBFFF700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0213    Leaving emm_fsm_set_state() (rc=0)
001783 00200:138384 7F81FBFFF700 TRACE NAS-EM rc/nas/emm/sap/EmmDeregistered.c:0424    Leaving EmmDeregistered() (rc=0)
001784 00200:138387 7F81FBFFF700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0293    Leaving emm_fsm_process() (rc=0)
001785 00200:138390 7F81FBFFF700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_reg.c:0117    Leaving emm_reg_send() (rc=0)
001786 00200:138402 7F81FBFFF700 TRACE NAS-EM openair-mme/src/nas/emm/Attach.c:2226    Leaving _emm_send_attach_accept() (rc=0)
001787 00200:138405 7F81FBFFF700 TRACE NAS-EM openair-mme/src/nas/emm/Attach.c:1972    Leaving _emm_wrapper_attach_accept() (rc=0)
001788 00200:138408 7F81FBFFF700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_cn.c:0319    Leaving _emm_wrapper_esm_accept() (rc=0)
001789 00200:138411 7F81FBFFF700 TRACE NAS-ES r-mme/src/nas/esm/nas_esm_proc.c:0316    Leaving nas_esm_proc_pdn_connectivity_res() (rc=0)
001790 00200:138424 7F81F9704700 TRACE MME-AP mme/src/mme_app/mme_app_bearer.c:0265    Entering mme_app_handle_conn_est_cnf()
001791 00200:138427 7F81F9704700 DEBUG MME-AP mme/src/mme_app/mme_app_bearer.c:0272    Received NAS_CONNECTION_ESTABLISHMENT_CNF from NAS
001792 00200:138431 7F81F9704700 DEBUG MME-AP mme/src/mme_app/mme_app_bearer.c:0320    security_capabilities_encryption_algorithms 0x00E0
001793 00200:138434 7F81F9704700 DEBUG MME-AP mme/src/mme_app/mme_app_bearer.c:0323    security_capabilities_integrity_algorithms  0x00E0
001794 00200:138445 7F81F9704700 DEBUG MME-AP mme/src/mme_app/mme_app_bearer.c:0499    MME APP : Sent Initial context Setup Request and Started guard timer for UE id  1
001795 00200:138449 7F81F9704700 TRACE MME-AP mme/src/mme_app/mme_app_bearer.c:0501    Leaving mme_app_handle_conn_est_cnf()
001796 00200:138517 7F81F9FFB700 DEBUG S1AP   c/s1ap/s1ap_mme_nas_procedures.c:1360    security_capabilities_encryption_algorithms 0x00E0
001797 00200:138523 7F81F9FFB700 DEBUG S1AP   c/s1ap/s1ap_mme_nas_procedures.c:1371    security_capabilities_integrity_algorithms 0x00E0
001798 00200:138567 7F81F9FFB700 NOTIC S1AP   c/s1ap/s1ap_mme_nas_procedures.c:1435    Send S1AP_INITIAL_CONTEXT_SETUP_REQUEST message MME_UE_S1AP_ID = 1 eNB_UE_S1AP_ID = 06692d
001799 00200:138586 7F81FB7FE700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0283    [48][1] Sending buffer 0x7f8170000b80 of 179 bytes on stream 1 with ppid 18
001800 00200:138624 7F81FB7FE700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0296    Successfully sent 179 bytes on stream 1
001801 00200:177439 7F81A17FA700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0547    [1][48] Msg of length 75 received from port 36412, on stream 1, PPID 18
001802 00200:177461 7F81A17FA700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0554    SCTP RETURNING!!
001803 00200:177597 7F81F9704700 TRACE MME-AP c/mme_app/mme_app_capabilities.c:0043    Entering mme_app_handle_s1ap_ue_capabilities_ind()
001804 00200:177611 7F81F9704700 DEBUG MME-AP c/mme_app/mme_app_capabilities.c:0069    UE radio capabilities of length 49 found and cached
001805 00200:177616 7F81F9704700 TRACE MME-AP c/mme_app/mme_app_capabilities.c:0072    Leaving mme_app_handle_s1ap_ue_capabilities_ind() (rc=0)
001806 00200:378786 7F81A17FA700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0547    [1][48] Msg of length 40 received from port 36412, on stream 1, PPID 18
001807 00200:378811 7F81A17FA700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0554    SCTP RETURNING!!
001808 00200:378825 7F81A17FA700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0547    [1][48] Msg of length 61 received from port 36412, on stream 1, PPID 18
001809 00200:378837 7F81A17FA700 DEBUG SCTP   rc/sctp/sctp_primitives_server.c:0554    SCTP RETURNING!!
001810 00200:378974 7F81F9FFB700 DEBUG S1AP   mme/src/s1ap/s1ap_mme_handlers.c:0871    S1AP_FIND_PROTOCOLIE_BY_ID: /openair-mme/src/s1ap/s1ap_mme_handlers.c 871: Optional ie is NULL
001811 00200:379028 7F81F9704700 TRACE MME-AP mme/src/mme_app/mme_app_bearer.c:2634    Entering mme_app_handle_initial_context_setup_rsp()
001812 00200:379044 7F81F9FFB700 INFO  S1AP   c/s1ap/s1ap_mme_nas_procedures.c:0295    Received S1AP UPLINK_NAS_TRANSPORT message MME_UE_S1AP_ID 1
001813 00200:379054 7F81F9704700 DEBUG MME-AP mme/src/mme_app/mme_app_bearer.c:2640    Received MME_APP_INITIAL_CONTEXT_SETUP_RSP from S1AP
001814 00200:379067 7F81F9704700 TRACE MME-AP mme_app/mme_app_bearer_context.c:0555    Entering mme_app_release_bearers()
001815 00200:379077 7F81F9704700 TRACE MME-AP mme_app/mme_app_esm_procedures.c:0300    Entering mme_app_nas_esm_get_bearer_context_procedure()
001816 00200:379084 7F81F9704700 TRACE MME-AP mme_app/mme_app_esm_procedures.c:0325    Leaving mme_app_nas_esm_get_bearer_context_procedure() (rc=0)
001817 00200:379089 7F81F9704700 INFO  MME-AP mme_app/mme_app_bearer_context.c:0658    Returning 0 bearer ready to be released for ue_id 1.
001818 00200:379097 7F81F9704700 TRACE MME-AP mme_app/mme_app_bearer_context.c:0659    Leaving mme_app_release_bearers()
001819 00200:379105 7F81F9704700 TRACE MME-AP mme_app/mme_app_bearer_context.c:0422    Entering mme_app_modify_bearers()
001820 00200:379114 7F81F9704700 TRACE MME-AP mme_app/mme_app_bearer_context.c:0486    Leaving mme_app_modify_bearers() (rc=0)
001821 00200:379138 7F81F9704700 TRACE MME-AP mme_app/mme_app_itti_messaging.c:0452    Entering mme_app_send_s11_modify_bearer_req()
001822 00200:379147 7F81F9704700 DEBUG MME-AP mme_app/mme_app_itti_messaging.c:0511    Adding EBI 5 as bearer context to be modified for UE 1.
001823 00200:379166 7F81F9704700 TRACE MME-AP mme_app/mme_app_itti_messaging.c:0598    Leaving mme_app_send_s11_modify_bearer_req()
001824 00200:379189 7F81F9704700 TRACE MME-AP mme/src/mme_app/mme_app_bearer.c:2741    Leaving mme_app_handle_initial_context_setup_rsp()
001825 00200:379201 7F81FA7FC700 DEBUG GTPv2- /nwgtpv2c-0.11/src/NwGtpv2cMsg.c:0092    Created message 0x7f8160000d50!
001826 00200:379237 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:2028    Entering nwGtpv2cProcessUlpReq()
001827 00200:379251 7F81FA7FC700 DEBUG GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:2032    Received initial request from ulp
001828 00200:379257 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:0691    Entering nwGtpv2cHandleUlpInitialReq()
001829 00200:379262 7F81FA7FC700 DEBUG GTPv2- nwgtpv2c-0.11/src/NwGtpv2cTrxn.c:0248    Created not trx without seqNum as transaction 0x7f81600041c0. Head (nil), Next 0x5570b568c7a2
001830 00200:379268 7F81FA7FC700 DEBUG GTPv2- nwgtpv2c-0.11/src/NwGtpv2cTrxn.c:0264    Created transaction 0x7f81600041c0
001831 00200:379281 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:2229    Entering nwGtpv2cStartTimer()
001832 00200:379292 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0250    Entering nas_proc_ul_transfer_ind()
001833 00200:379301 7F81FA7FC700 DEBUG GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:2294    Started timer 0x7f81600041a0 for info 0x0x7f81600042e0!
001836 00200:379340 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:2300    Leaving nwGtpv2cStartTimer() (rc=0)
001837 00200:379355 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:0770    Leaving nwGtpv2cHandleUlpInitialReq() (rc=0)
001838 00200:379361 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:2074    Leaving nwGtpv2cProcessUlpReq() (rc=0)
001834 00200:379301 7F81FAFFD700 DEBUG UDP    /src/udp/udp_primitives_server.c:0077    Looking for task 9
001839 00200:379395 7F81FAFFD700 DEBUG UDP    /src/udp/udp_primitives_server.c:0093    Found matching port with high port 46468.
001840 00200:379408 7F81FAFFD700 DEBUG UDP    /src/udp/udp_primitives_server.c:0446    [39] Sending message of size 47 to 192.168.61.196 and port 2123
001835 00200:379319 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
001841 00200:379465 7F81FAFFD700 DEBUG UDP    /src/udp/udp_primitives_server.c:0122    Received 1 events
001842 00200:379475 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0190    Entering emm_as_send()
001843 00200:379484 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0197    EMMAS-SAP - Received primitive EMMAS_DATA_IND (211)
001844 00200:379492 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0557    Entering _emm_as_data_ind()
001845 00200:379537 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0565    EMMAS-SAP - Received AS data transfer indication (ue_id=1, delivered=true, length=13)
001846 00200:379548 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001847 00200:379557 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0260    Entering nas_message_decrypt()
001848 00200:379565 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0694    Entering nas_message_header_decode()
001849 00200:379580 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0751    Leaving nas_message_header_decode() (rc=6)
001850 00200:379585 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1392    Entering _nas_message_get_mac()
001851 00200:379590 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:1469    NAS_SECURITY_ALGORITHMS_EIA2 dir UPLINK count.seq_num 2 count 2
001852 00200:379599 7F820083C700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0076    Byte length: 16, Zero bits: 0:
001853 00200:379651 7F820083C700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0077    hex stream m: 00 00 00 02 00 00 00 00 02 07 43 00 03 52 00 c2
001854 00200:379682 7F820083C700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0079    hex stream Key: 3d 40 c1 8e 32 36 d6 3a a0 21 09 07 3a dd 31 2f
001855 00200:379705 7F820083C700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0081    hex stream Message: 02 07 43 00 03 52 00 c2
001856 00200:379727 7F820083C700 TRACE NAS    r-mme/src/secu/nas_stream_eia2.c:0089    hex stream Out: 1b e6 d5 cf e7 85 7f 24 a9 6b 7b d5 d9 39 48 42
001857 00200:379746 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:1485    NAS_SECURITY_ALGORITHMS_EIA2 returned MAC 1b.e6.d5.cf(3486901787) for length 8 direction 0, count 2
001858 00200:379756 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1487    Leaving _nas_message_get_mac() (rc=468112847)
001859 00200:379764 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:0303    Integrity: MAC Success
001860 00200:379772 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1049    Entering _nas_message_decrypt()
001861 00200:379780 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:1175    NAS_SECURITY_ALGORITHMS_EEA0 dir 0 ul_count.seq_num 2 dl_count.seq_num 3
001862 00200:379788 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:1183    Leaving _nas_message_decrypt() (rc=7)
001863 00200:379796 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0335    Leaving nas_message_decrypt() (rc=7)
001864 00200:379804 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0269    Entering _emm_as_recv()
001865 00200:379812 7F820083C700 INFO  NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0285    EMMAS-SAP - Received EMM message (length=7) integrity protected 1 ciphered 1 mac matched 1 security context 1
001866 00200:379822 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001867 00200:379839 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0360    Entering nas_message_decode()
001868 00200:379846 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:0374    hex stream Incoming NAS message:  07 43 00 03 52 00 c2
001869 00200:379866 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0694    Entering nas_message_header_decode()
001870 00200:379875 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0751    Leaving nas_message_header_decode() (rc=1)
001871 00200:379905 7F820083C700 DEBUG NAS    rc/nas/api/network/nas_message.c:0386    nas_message_header_decode returned size 1
001872 00200:379919 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0776    Entering _nas_message_plain_decode()
001873 00200:379928 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0101    Entering emm_msg_decode()
001874 00200:379937 7F820083C700 DEBUG NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0121    EMM-MSG   - Message Type 0x43
001875 00200:379945 7F820083C700 TRACE NAS-ES rc/nas/ies/EsmMessageContainer.c:0037    Entering decode_esm_message_container()
001876 00200:379954 7F820083C700 TRACE NAS-ES rc/nas/ies/EsmMessageContainer.c:0054    Leaving decode_esm_message_container() (rc=5)
001877 00200:379962 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0274    Leaving emm_msg_decode() (rc=7)
001878 00200:379970 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0799    Leaving _nas_message_plain_decode() (rc=7)
001879 00200:379979 7F820083C700 TRACE NAS    rc/nas/api/network/nas_message.c:0539    Leaving nas_message_decode() (rc=7)
001880 00200:379988 7F820083C700 NOTIC NAS    air-mme/src/nas/emm/sap/emm_as.c:0414    Hit 3GPP TS 24_301R10_4_4_4_3__1 : Integrity checking of NAS signalling messages exception in the MME
001881 00200:380005 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/sap/emm_recv.c:0415    Entering emm_recv_attach_complete()
001882 00200:380014 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/sap/emm_recv.c:0418    EMMAS-SAP - Received Attach Complete message
001883 00200:380047 7F820083C700 TRACE NAS-EM openair-mme/src/nas/emm/Attach.c:0696    Entering emm_proc_attach_complete()
001884 00200:380060 7F820083C700 INFO  NAS-EM openair-mme/src/nas/emm/Attach.c:0705    EMM-PROC  - EPS attach complete (ue_id=1)
001885 00200:380069 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001886 00200:380078 7F820083C700 NOTIC NAS    openair-mme/src/nas/emm/Attach.c:0722    Hit 3GPP TS 24_301R10_5_5_1_2_4__20 : Attach accepted by the network, ATTACH COMPLETE received, enter state EMM-REGISTERED
001887 00200:380090 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:2042    EMM-CTX - Add in context UE id 1 with GUTI 208.95 |8000|03|00000001
001888 00200:380104 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0137    ue_id=1 old GUTI cleared
001889 00200:380113 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_sap.c:0109    Entering emm_sap_send()
001890 00200:380121 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_reg.c:0104    Entering emm_reg_send()
001891 00200:380129 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0274    Entering emm_fsm_process()
001892 00200:380138 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001893 00200:380152 7F820083C700 INFO  NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0282    EMM-FSM   - Received event ATTACH_CNF (5) in state EMM-COMMON-PROCEDURE-INITIATED
001894 00200:380162 7F820083C700 TRACE NAS-EM ap/EmmCommonProcedureInitiated.c:0093    Entering EmmCommonProcedureInitiated()
001895 00200:380176 7F820083C700 INFO  NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:0872    EMM-CTX - get UE id 1 context 0x7f81680011b0
001896 00200:380185 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0176    Entering emm_fsm_set_state()
001897 00200:380193 7F820083C700 INFO  NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0185    UE 1 EMM-FSM   - Status changed: EMM-COMMON-PROCEDURE-INITIATED ===> EMM-REGISTERED
001898 00200:380202 7F820083C700 TRACE MME-AP me/src/mme_app/mme_app_context.c:2251    Entering mme_ue_context_update_ue_emm_state()
001899 00200:380212 7F820083C700 TRACE MME-AP me/src/mme_app/mme_app_context.c:2279    Leaving mme_ue_context_update_ue_emm_state()
001900 00200:380221 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0213    Leaving emm_fsm_set_state() (rc=0)
001901 00200:380230 7F820083C700 TRACE NAS-EM src/nas/emm/nas_emm_procedures.c:0516    UE 1 Delete ATTACH procedure
001902 00200:380244 7F820083C700 DEBUG NAS-EM r-mme/src/nas/emm/emm_data_ctx.c:1420    T3450 stopped UE 1
001903 00200:380438 7F820083C700 DEBUG NAS-EM src/nas/emm/nas_emm_procedures.c:0534    EMM-PROC (NASx)  -  * * * * * (2) ueREF 0x7f8164009a00 has mmeId 1, enbId 06692d state 2 and eNB_ref 0x7f8164000d50.
001904 00200:380459 7F820083C700 TRACE NAS-EM src/nas/emm/nas_emm_procedures.c:0543    UE 1 stopped the retry timer for attach procedure
001905 00200:380468 7F820083C700 DEBUG NAS-EM src/nas/emm/nas_emm_procedures.c:0550    EMM-PROC (NASx)  -  * * * * * (2.5) ueREF 0x7f8164009a00 has mmeId 1, enbId 06692d state 2 and eNB_ref 0x7f8164000d50
001906 00200:380479 7F820083C700 TRACE NAS-EM ap/EmmCommonProcedureInitiated.c:0577    Leaving EmmCommonProcedureInitiated() (rc=0)
001907 00200:380488 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_fsm.c:0293    Leaving emm_fsm_process() (rc=0)
001908 00200:380497 7F820083C700 TRACE NAS-EM ir-mme/src/nas/emm/sap/emm_reg.c:0117    Leaving emm_reg_send() (rc=0)
001909 00200:380505 7F820083C700 TRACE NAS-EM openair-mme/src/nas/emm/Attach.c:0784    Leaving emm_proc_attach_complete() (rc=0)
001910 00200:380526 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/sap/emm_recv.c:0426    Leaving emm_recv_attach_complete() (rc=0)
001911 00200:380539 7F820083C700 TRACE NAS-ES ir-mme/src/nas/emm/msg/emm_msg.c:0483    Entering emm_msg_free()
001913 00200:380549 7F820083C700 DEBUG NAS-EM ir-mme/src/nas/emm/msg/emm_msg.c:0493    EMM-MSG   - Message Type 0x43
001912 00200:380545 7F81FBFFF700 TRACE NAS-ES r-mme/src/nas/esm/nas_esm_proc.c:0159    Entering nas_esm_proc_data_ind()
001914 00200:380557 7F820083C700 TRACE NAS-ES ir-mme/src/nas/emm/msg/emm_msg.c:0592    Leaving emm_msg_free()
001916 00200:380584 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/sap/esm_sap.c:0573    Entering _esm_sap_recv()
001917 00200:380602 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0536    Leaving _emm_as_recv() (rc=0)
001918 00200:380612 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0673    Leaving _emm_as_data_ind() (rc=0)
001915 00200:380579 7F81FAFFD700 DEBUG UDP    /src/udp/udp_primitives_server.c:0122    Received 1 events
001920 00200:380621 7F820083C700 TRACE NAS-EM air-mme/src/nas/emm/sap/emm_as.c:0234    Leaving emm_as_send() (rc=0)
001919 00200:380621 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0117    Entering esm_msg_decode()
001921 00200:380631 7F81FAFFD700 DEBUG UDP    /src/udp/udp_primitives_server.c:0108    Looking for sd 39
001923 00200:380646 7F81FAFFD700 DEBUG UDP    /src/udp/udp_primitives_server.c:0147    Inserting new descriptor for task 9, sd 39
001922 00200:380632 7F820083C700 TRACE NAS-EM r-mme/src/nas/emm/nas_emm_proc.c:0270    Leaving nas_proc_ul_transfer_ind() (rc=0)
001924 00200:380654 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0261    Leaving esm_msg_decode() (rc=3)
001925 00200:380712 7F81FBFFF700 TRACE NAS-ES r-mme/src/nas/esm/sap/esm_recv.c:0865    Entering esm_recv_activate_default_eps_bearer_context_accept()
001926 00200:380723 7F81FBFFF700 TRACE MME-AP mme_app/mme_app_esm_procedures.c:0216    Entering mme_app_nas_esm_get_pdn_connectivity_procedure()
001928 00200:380732 7F81FBFFF700 TRACE MME-AP mme_app/mme_app_esm_procedures.c:0234    Leaving mme_app_nas_esm_get_pdn_connectivity_procedure() (rc=140193571016096)
001927 00200:380729 7F81FAFFD700 DEBUG UDP    /src/udp/udp_primitives_server.c:0192    Msg of length 46 received from 192.168.61.196:2123
001929 00200:380748 7F81FBFFF700 TRACE NAS-ES aultEpsBearerContextActivation.c:0318    Entering esm_proc_default_eps_bearer_context_accept()
001930 00200:380778 7F81FBFFF700 INFO  NAS-ES aultEpsBearerContextActivation.c:0323    ESM-PROC  - Default EPS bearer context activation accepted by the UE (ue_id=1, ebi=5)
001931 00200:380789 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:1874    Entering nwGtpv2cProcessUdpReq()
001932 00200:380793 7F81FBFFF700 TRACE MME-AP mme_app/mme_app_bearer_context.c:0385    Entering mme_app_esm_update_ebr_state()
001933 00200:380810 7F81FA7FC700 DEBUG GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:1468    RECEIVED GTPV2c  response message of type 35, length 46 and seqNum 8691.
001934 00200:380825 7F81FBFFF700 TRACE MME-AP rc/mme_app/mme_app_pdn_context.c:0062    Entering mme_app_get_pdn_context()
001935 00200:380826 7F81FA7FC700 DEBUG GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:1492    Not removing the initial request transaction for message type 35, seqNo 8691 (altough remove flag set).
001936 00200:380842 7F81FBFFF700 TRACE MME-AP rc/mme_app/mme_app_pdn_context.c:0082    Leaving mme_app_get_pdn_context()
001937 00200:380848 7F81FA7FC700 DEBUG GTPv2- /nwgtpv2c-0.11/src/NwGtpv2cMsg.c:0132    Created message 0x7f81600043a0!
001938 00200:380852 7F81FBFFF700 TRACE MME-AP mme_app/mme_app_bearer_context.c:0414    Leaving mme_app_esm_update_ebr_state() (rc=0)
001939 00200:380857 7F81FA7FC700 DEBUG GTPv2- .11/src/NwGtpv2cMsgIeParseInfo.c:1314    Received IE 2 with instance 0 of length 2 in msg-type 35!
001940 00200:380862 7F81FBFFF700 TRACE NAS-ES aultEpsBearerContextActivation.c:0346    Leaving esm_proc_default_eps_bearer_context_accept()
001941 00200:380867 7F81FA7FC700 DEBUG GTPv2- .11/src/NwGtpv2cMsgIeParseInfo.c:1314    Received IE 93 with instance 0 of length 24 in msg-type 35!
001942 00200:380872 7F81FBFFF700 TRACE NAS-ES r-mme/src/nas/esm/sap/esm_recv.c:0924    Leaving esm_recv_activate_default_eps_bearer_context_accept() (rc=-1)
001943 00200:380877 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:1140    Entering nwGtpv2cSendTriggeredRspIndToUlp()
001944 00200:380882 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0447    Entering esm_msg_free()
001945 00200:380896 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0592    Leaving esm_msg_free()
001946 00200:380904 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0447    Entering esm_msg_free()
001947 00200:380909 7F81FA7FC700 DEBUG GTPv2- v2c-0.11/src/NwGtpv2cMsgParser.c:0211    Received IE 2 of length 2!
001949 00200:380928 7F81FA7FC700 DEBUG GTPv2- matter/src/gtpv2c_ie_formatter.c:0153     - Cause value 16
001948 00200:380912 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/msg/esm_msg.c:0592    Leaving esm_msg_free()
001950 00200:380935 7F81FA7FC700 DEBUG GTPv2- v2c-0.11/src/NwGtpv2cMsgParser.c:0211    Received IE 93 of length 24!
001951 00200:380942 7F81FBFFF700 TRACE NAS-ES ir-mme/src/nas/esm/sap/esm_sap.c:0949    Leaving _esm_sap_recv()
001952 00200:380942 7F81FA7FC700 DEBUG S11    matter/src/gtpv2c_ie_formatter.c:0374     - EBI 5
001953 00200:380956 7F81FBFFF700 TRACE NAS-ES r-mme/src/nas/esm/nas_esm_proc.c:0178    Leaving nas_esm_proc_data_ind() (rc=0)
001954 00200:380962 7F81FA7FC700 DEBUG GTPv2- matter/src/gtpv2c_ie_formatter.c:0153     - Cause value 16
001955 00200:380967 7F81FA7FC700 DEBUG GTPv2- matter/src/gtpv2c_ie_formatter.c:0232     - F-TEID type 1
001956 00200:380972 7F81FA7FC700 DEBUG GTPv2- matter/src/gtpv2c_ie_formatter.c:0237     - TEID/GRE    00000001
001957 00200:380979 7F81FA7FC700 DEBUG GTPv2- matter/src/gtpv2c_ie_formatter.c:0249     - IPv4 addr   192.168.61.197
001958 00200:380989 7F81FA7FC700 DEBUG GTPv2- /nwgtpv2c-0.11/src/NwGtpv2cMsg.c:0144    Purging message 0x7f81600043a0!
001959 00200:380994 7F81FA7FC700 DEBUG GTPv2- /nwgtpv2c-0.11/src/NwGtpv2cMsg.c:0149    Message pool 7f81600043a0! Next element 0!
001960 00200:381027 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:1154    Leaving nwGtpv2cSendTriggeredRspIndToUlp() (rc=0)
001961 00200:381036 7F81FA7FC700 WARNI GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:1535    Removing the initial request transaction for message type 35, seqNo 8691 in conclusion (not late response).
001962 00200:381043 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:2392    Entering nwGtpv2cStopTimer()
001963 00200:381044 7F81F9704700 TRACE MME-AP mme/src/mme_app/mme_app_bearer.c:2008    Entering mme_app_handle_modify_bearer_resp()
001964 00200:381048 7F81FA7FC700 DEBUG GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:2406    Stopping active timer 0x7f81600041a0 for info 0x0x7f81600042e0!
001965 00200:381063 7F81F9704700 DEBUG MME-AP mme/src/mme_app/mme_app_bearer.c:2011    Received S11_MODIFY_BEARER_RESPONSE from S+P-GW
001967 00200:381074 7F81FA7FC700 INFO  GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:2418    Stopped active timer 0x7f81600041a0 for info 0x0x7f81600042e0!
001966 00200:381074 7F81F9704700 TRACE MME-AP rc/mme_app/mme_app_pdn_context.c:0062    Entering mme_app_get_pdn_context()
001968 00200:381093 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:2445    Leaving nwGtpv2cStopTimer() (rc=0)
001969 00200:381108 7F81F9704700 TRACE MME-AP rc/mme_app/mme_app_pdn_context.c:0082    Leaving mme_app_get_pdn_context()
001970 00200:381111 7F81FA7FC700 DEBUG GTPv2- /nwgtpv2c-0.11/src/NwGtpv2cMsg.c:0144    Purging message 0x7f8160000d50!
001971 00200:381122 7F81F9704700 INFO  MME-AP mme/src/mme_app/mme_app_bearer.c:2329    No pending removal of bearers for ueId: 1. Checking any pending bearer requests.
001972 00200:381123 7F81FA7FC700 DEBUG GTPv2- /nwgtpv2c-0.11/src/NwGtpv2cMsg.c:0149    Message pool 7f8160000d50! Next element 7f81600043a0!
001973 00200:381137 7F81F9704700 TRACE MME-AP mme/src/mme_app/mme_app_bearer.c:0904    Entering mme_app_handle_bearer_ctx_retry()
001974 00200:381143 7F81FA7FC700 DEBUG GTPv2- nwgtpv2c-0.11/src/NwGtpv2cTrxn.c:0422    Purging  transaction 0x7f81600041c0 with seqNum 34449. (before) Head (nil), Next (nil).
001975 00200:381147 7F81F9704700 INFO  MME-AP mme/src/mme_app/mme_app_bearer.c:1135    No S11 procedure could be found for UE 1.
001976 00200:381154 7F81FA7FC700 DEBUG GTPv2- nwgtpv2c-0.11/src/NwGtpv2cTrxn.c:0429    After purging  transaction 0x7f81600041c0, Head 0x7f81600041c0, Next (nil)
001977 00200:381156 7F81F9704700 TRACE MME-AP mme/src/mme_app/mme_app_bearer.c:1136    Leaving mme_app_handle_bearer_ctx_retry()
001978 00200:381162 7F81FA7FC700 TRACE GTPv2- 2-c/nwgtpv2c-0.11/src/NwGtpv2c.c:2014    Leaving nwGtpv2cProcessUdpReq() (rc=0)
001979 00200:381167 7F81F9704700 TRACE MME-AP mme/src/mme_app/mme_app_bearer.c:2331    Leaving mme_app_handle_modify_bearer_resp() (rc=0)
001980 00200:853706 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0039    ======================================= STATISTICS ============================================
001981 00200:853730 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0042                   |   Current Status| Added since last display|  Removed since last display |
001982 00200:853738 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0048    Connected eNBs |          1      |              0              |             0               |
001983 00200:853744 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0054    Attached UEs   |          1      |              1              |             0               |
001984 00200:853752 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0060    Connected UEs  |          1      |              1              |             0               |
001985 00200:853757 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0066    Default Bearers|          0      |              0              |             0               |
001986 00200:853765 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0072    S1-U Bearers   |          0      |              0              |             0               |
001987 00200:853772 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0075    ======================================= STATISTICS ============================================
001988 00210:853698 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0039    ======================================= STATISTICS ============================================
001989 00210:853722 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0042                   |   Current Status| Added since last display|  Removed since last display |
001990 00210:853730 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0048    Connected eNBs |          1      |              0              |             0               |
001991 00210:853736 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0054    Attached UEs   |          1      |              0              |             0               |
001992 00210:853743 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0060    Connected UEs  |          1      |              0              |             0               |
001993 00210:853749 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0066    Default Bearers|          0      |              0              |             0               |
001994 00210:853756 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0072    S1-U Bearers   |          0      |              0              |             0               |
001995 00210:853762 7F81F9704700 DEBUG MME-AP src/mme_app/mme_app_statistics.c:0075    ======================================= STATISTICS ============================================
eNB logs:
[RRC]   [FRAME 00128][eNB][MOD 00][RNTI 18b8] Decoding UL CCCH 5c.6b.5b.b2.95.56 (0x55bb9587ab03)
[RRC]   [FRAME 00128][eNB][MOD 00][RNTI 18b8] Accept new connection from UE random UE identity (0x5529bbb5c6000000) MME code 0 TMSI 0 cause 3
[MAC]   UE 0 RNTI 18b8 adding LC 1 idx 0 to scheduling control (total 1)
[MAC]   UE 0 RNTI 18b8 adding LC 2 idx 1 to scheduling control (total 2)
[MAC]   Added physicalConfigDedicated 0x7f9e1c1ca6b0 for 0.0
[RRC]   [FRAME 00128][eNB][MOD 00][RNTI 18b8]CALLING RLC CONFIG SRB1 (rbid 1)
add new uid is 0 18b8
[PDCP]   [FRAME 00128][eNB][MOD 00][RNTI 18b8][SRB 01]  Action ADD  LCID 1 (SRB id 1) configured with SN size 5 bits and RLC AM
[MAC]   generate_Msg4 ra->Msg4_frame SFN/SF: 128.4,  frameP SFN/SF: 128.4 FOR eNB_Mod: 0
[MAC]   [eNB 0][RAPROC] CC_id 0 Frame 128, subframeP 4: Generating Msg4 with RRC Piggyback (RNTI 18b8)
[RRC]   [FRAME 00000][eNB][MOD 00][RNTI 18b8] [RAPROC] Logical Channel UL-DCCH, processing LTE_RRCConnectionSetupComplete from UE (SRB1 Active)
[NAS]    AttachRequest.c:40  EMM  - attach_request len = 85
[NAS]    UeNetworkCapability.c:46  decode_ue_network_capability len = 5
[NAS]    UeNetworkCapability.c:63  uenetworkcapability decoded UMTS
[NAS]    UeNetworkCapability.c:74  uenetworkcapability decoded GPRS
[NAS]    UeNetworkCapability.c:82  uenetworkcapability decoded=6
[NAS]    UeNetworkCapability.c:86  uenetworkcapability then decoded=6
[S1AP]   [eNB 0] Build S1AP_NAS_FIRST_REQ adding in s_TMSI: GUMMEI mme_code 1 mme_group_id 4 ue 18b8
[RRC]   [FRAME 00000][eNB][MOD 00][RNTI 18b8] UE State = RRC_CONNECTED
[S1AP]   [eNB 0] Chose MME '(null)' (assoc_id 1) through selected PLMN Identity index 0 MCC 208 MNC 95
[S1AP]   Found usable eNB_ue_s1ap_id: 0x06692d 420141(10)
[S1AP]   GUMMEI_ID_PRESENT
[SCTP]   Successfully sent 152 bytes on stream 1 for assoc_id 1
[SCTP]   Found data for descriptor 95
[SCTP]   [1][95] Msg of length 29 received from port 36412, on stream 1, PPID 18
[RRC]   [eNB 0] Received S1AP_DOWNLINK_NAS: ue_initial_id 1, eNB_ue_s1ap_id 420141
[RRC]   sent RRC_DCCH_DATA_REQ to TASK_PDCP_ENB
[SCTP]   Successfully sent 65 bytes on stream 1 for assoc_id 1
[SCTP]   [1][95] Msg of length 62 received from port 36412, on stream 1, PPID 18
[SCTP]   Successfully sent 73 bytes on stream 1 for assoc_id 1
[SCTP]   [1][95] Msg of length 43 received from port 36412, on stream 1, PPID 18
[SCTP]   Successfully sent 67 bytes on stream 1 for assoc_id 1
[SCTP]   [1][95] Msg of length 35 received from port 36412, on stream 1, PPID 18
[SCTP]   Successfully sent 68 bytes on stream 1 for assoc_id 1
[SCTP]   [1][95] Msg of length 179 received from port 36412, on stream 1, PPID 18
[S1AP]   Received NAS message with the E_RAB setup procedure
[RRC]   [eNB 0] Received S1AP_INITIAL_CONTEXT_SETUP_REQ: ue_initial_id 1, eNB_ue_s1ap_id 420141, nb_of_e_rabs 1
[GTPV1U]   Configured GTPu address : 1e3da8c0
[GTPV1U]   Copied to create_tunnel_resp tunnel: index 0 target gNB ip 192.168.61.30 length 4 gtp teid 3396329693
[RRC]   [FRAME 00000][eNB][MOD 00][RNTI 18b8] rrc_eNB_process_GTPV1U_CREATE_TUNNEL_RESP tunnel (3396329693, 3396329693) bearer UE context index 0, msg index 0, id 5, gtp addr len 4
[RRC]   [eNB 0][UE 18b8] Selected security algorithms (0x7f9e34005e50): 0, 2, changed
[RRC]   [eNB 0][UE 18b8] Saved security key D418FA6D1E24C7FA32A57298BD83FAA88453E6BC61036B6FB70BE05F05A47607
[RRC]
KeNB:d4 18 fa 6d 1e 24 c7 fa 32 a5 72 98 bd 83 fa a8 84 53 e6 bc 61 03 6b 6f b7 0b e0 5f 05 a4 76 07
[RRC]
KRRCenc:8e a8 01 00 44 4a dd 08 03 8c e5 f7 6e 42 14 68 8a 06 73 56 5e f4 79 8d f0 81 08 29 29 b6 b4 79
[RRC]
KRRCint:8e 8c 7d 76 61 99 e4 da 35 62 96 69 e7 a7 42 8f a5 f7 79 c5 76 24 ec 64 84 78 e6 5b d7 a6 78 db
[RRC]   [FRAME 00000][eNB][MOD 00][RNTI 18b8] Logical Channel DL-DCCH, Generate SecurityModeCommand (bytes 3)
[RRC]   calling rrc_data_req :securityModeCommand
[RRC]   [FRAME 00000][eNB][MOD 00][RNTI 18b8] received securityModeComplete on UL-DCCH 1 from UE
<FreqBandList>
        <bandInformationEUTRA>
            <bandEUTRA>7</bandEUTRA>
        </bandInformationEUTRA>
        <bandInformationNR>
            <bandNR>78</bandNR>
        </bandInformationNR>
</FreqBandList>
[RRC]   [FRAME 00000][eNB][MOD 00][RNTI 18b8] Logical Channel DL-DCCH, Generate UECapabilityEnquiry (bytes 10)
[RRC]   [FRAME 00000][eNB][MOD 00][RNTI 18b8] received ueCapabilityInformation on UL-DCCH 1 from UE
[RRC]   got UE capabilities for UE 18b8
[RRC]   drx_Configuration parameter is NULL, cannot configure local UE parameters or CDRX is deactivated
[RRC]   [eNB 0] frame 0: requesting A2, A3, A4, and A5 event reporting
[RRC]   RRCConnectionReconfiguration Encoded 946 bits (119 bytes)
[RRC]   [eNB 0] Frame 0, Logical Channel DL-DCCH, Generate LTE_RRCConnectionReconfiguration (bytes 119, UE id 18b8)
[PDCP]   [FRAME 00000][eNB][MOD 00][RNTI 18b8][SRB 02]  Action ADD  LCID 2 (SRB id 2) configured with SN size 5 bits and RLC AM
[SCTP]   Successfully sent 75 bytes on stream 1 for assoc_id 1
[PDCP]   [FRAME 00000][eNB][MOD 00][RNTI 18b8][DRB 01]  Action ADD  LCID 3 (DRB id 1) configured with SN size 12 bits and RLC AM
[RRC]   [FRAME 00000][eNB][MOD 00][RNTI 18b8] UE State = RRC_RECONFIGURED (default DRB, xid 0)
[PDCP]   [FRAME 00000][eNB][MOD 00][RNTI 18b8][SRB 02]  Action MODIFY LCID 2 RB id 2 reconfigured with SN size 5 and RLC AM
[PDCP]   [FRAME 00000][eNB][MOD 00][RNTI 18b8][DRB 01]  Action MODIFY LCID 3 RB id 1 reconfigured with SN size 1 and RLC AM
[RRC]   [eNB 0] Frame  0 CC 0 : SRB2 is now active
[RRC]   [eNB 0] Frame  0 : Logical Channel UL-DCCH, Received LTE_RRCConnectionReconfigurationComplete from UE rnti 18b8, reconfiguring DRB 1/LCID 3
[RRC]   [eNB 0] Frame  0 : Logical Channel UL-DCCH, Received LTE_RRCConnectionReconfigurationComplete from UE 0, reconfiguring DRB 1/LCID 3
[MAC]   UE 0 RNTI 18b8 adding LC 3 idx 2 to scheduling control (total 3)
[S1AP]   initial_ctxt_resp_p: e_rab ID 5, enb_addr 192.168.61.30, SIZE 4
[SCTP]   Successfully sent 40 bytes on stream 1 for assoc_id 1
[SCTP]   Successfully sent 61 bytes on stream 1 for assoc_id 1
Test traffic
$ macphone2
macphone2:~ tester$ adb devices
List of devices attached
TA3640BB09  device
macphone2:~ tester$ adb shell
shell@surnia_uds:/ $ ping -c 3 www.lemonde.fr
PING s2.shared.global.fastly.net (151.101.122.217) 56(84) bytes of data.
64 bytes from 151.101.122.217: icmp_seq=1 ttl=53 time=40.2 ms
64 bytes from 151.101.122.217: icmp_seq=2 ttl=53 time=35.1 ms
64 bytes from 151.101.122.217: icmp_seq=3 ttl=53 time=47.5 ms
--- s2.shared.global.fastly.net ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2000ms
rtt min/avg/max/mdev = 35.178/41.006/47.583/5.097 ms
Properly disconnect
$ macphone2
macphone2:~ tester$ phone-off
Turning OFF phone : turning on airplane mode
Broadcasting: Intent { act=android.intent.action.AIRPLANE_MODE (has extras) }
Broadcast completed: result=0
oaici@fit23:~/openairinterface5g/ci-scripts/yaml_files/inria_enb_mono_fdd$ docker-compose down
Stopping prod-enb-mono-fdd ... done
Removing prod-enb-mono-fdd ... done
Removing network prod-oai-public-net
oaici@fit17:~/openair-epc-fed/docker-compose/inria-oai-mme$ docker-compose down
Stopping prod-oai-spgwu-tiny ... done
Stopping prod-oai-spgwc      ... done
Stopping prod-oai-mme        ... done
Stopping prod-oai-hss        ... done
Stopping prod-trf-gen        ... done
Stopping prod-cassandra      ... done
Removing prod-oai-spgwu-tiny ... done
Removing prod-oai-spgwc      ... done
Removing prod-oai-mme        ... done
Removing prod-oai-hss        ... done
Removing prod-trf-gen        ... done
Removing prod-cassandra      ... done
Removing network prod-oai-private-net
